Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 01-25-2005, 07:33 PM   #16
Sofa King Retarded
nsmoller's Avatar
well is it possible to have like a 6-8' ide cable?
[4Runna]
next - wifi
nsmoller is offline   Reply With Quote
Old 01-25-2005, 07:39 PM   #17
old_lou's Avatar
Quote: Originally Posted by Scouse Monkey
Cheers buddy, got distracted and didnt get time to search before you answered. 1A ont he 12V is quite a lot. Definitely gonna go with a lappy drive.
Ever thought of adapting a hard drive case? You can have your cd in the front with you
http://www.overclock.co.uk/customer/...roductid=18168
EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
old_lou is offline   Reply With Quote
Old 02-01-2005, 07:45 PM   #18
guys is it possible to get a USB hub that doesnt require external power?
camsgs3 is offline   Reply With Quote
Old 02-01-2005, 09:00 PM   #19
old_lou's Avatar
Yes, but you may have a problem driving all the devices from an unpowered one, especially if you are using a low powered PSU
Old 02-01-2005, 09:23 PM   #20
Raw Wave
rando's Avatar
Quote: Originally Posted by vxcarpc
I can't think of any more than 5 devices I would need on the car pc
Here's what I have but only 1-4 are actually in use at this moment. 5-7 are just hooked up whenever I need them. #8 I removed because it sucked. #9 I actually just use the on board COM port but it could be USB would have been more convenient.
1) Audigy 2 NX for sound and Radio Line-Input
2) iMic for microphone
3) Touch screen controller
4) GPS
5) Card reader
6) Keyboard (occasionally)
7) 802.11b dongle
8) USB->RS232->AM/FM Radio
9) USB->RS232 for video interlock / lockout
And then you might also want some of these on USB.
10) OBD2
11) Relay controller
2004 4runner
rando is offline   Reply With Quote
Old 02-01-2005, 09:27 PM   #21
Clover
Grayscale's Avatar
yeah, i actually just made a list + map of all my usb devices, and its crazy. i already had a 4 port 2.0 hub with my 2 ports on mobo used (im not using the mobo header), and heres what i'm going to need now: 1 usb 2.0 4 port, 1 usb 2.0 7 port, and 1 usb 1.1 4 port, and thats going to max me out but i'll have 4 spare ports for the console . don't ask, you'll get to see in show off your project soon enough anyways
CarPC install is starting to come along again...
Grayscale is offline   Reply With Quote
Old 02-01-2005, 11:56 PM   #22
Sofa King Retarded
nsmoller's Avatar
you bring up lots of good points, i was condensing down to 1 4port but i will keep the 7 port
the audigy/radio thing you mentioned - whats up w/that
do you get good reception w/the fm????
whats up w/relay control usb???
[4Runna]
next - wifi
Old 02-02-2005, 02:51 PM   #23
Clover
Grayscale's Avatar
just checked and i'm using 14 usb ports...15 soon 4 are flush mounted in my console and arent always in use.
the usb relay card probably controls his locks/windows or something like that...rando which one do you have? im about to get the velleman kit or whatever, it's nice! unless you have a better one i should know about...
Old 02-02-2005, 08:54 PM   #24
Sofa King Retarded
nsmoller's Avatar
Quote: Originally Posted by Grayscale
just checked and i'm using 14 usb ports...15 soon 4 are flush mounted in my console and arent always in use....
how do you power your setup, how do you power your usbs?
[4Runna]
next - wifi
Old 02-02-2005, 10:29 PM   #25
Clover
Grayscale's Avatar
i take 5v off of my psu and feed it to my first hub that is externally powered (its actually internally powered too, but i cut the 5v line to it. because im using a relay to control its power externally), and then the other 2 hubs are unpowered so they just get their power off of the first one thats switched on and off based on when my comps on or off. cause as some of you know, while your comps in suspend S3 mode, it keeps your usb devices powered...which is very bad
Old 02-03-2005, 08:57 PM   #26
Sofa King Retarded
nsmoller's Avatar
any issus w/un recognized devices?
[4Runna]
next - wifi
Old 02-08-2005, 12:50 PM   #27
Clover
Grayscale's Avatar
no. sorry for the slow response.
Old 02-08-2005, 03:25 PM   #28
Raw Wave
rando's Avatar
It's just a standard Audigy NX USB. I use the line-in port on the Audigy for radio -- isn't that the way everyone does it? Anyhow I stopped using the radio shortly after I first installed it -- because it sucked. It's not even in the truck anymore.
No.
I don't have one. What I wrote was you MIGHT use USB for a relay controller -- not that I do.
2004 4runner
Old 02-08-2005, 03:26 PM   #29
Raw Wave
rando's Avatar
Yes, I used to get this problem frequently but haven't had a problem (yet) following my most recent wiring upgrade.
2004 4runner
Old 02-08-2005, 03:35 PM   #30
Dudes99's Avatar
Quote: Originally Posted by Curiosity
I use a pair of 4-port hubs just so there's more power (both are powered off USB) and if I get any funky conflicts I can just swap them around. Dudes99 posted this about Multi-TT which would be the better hub. Someone else posted an article about 1.1 vs 2.0 and all I remember was 1.1 has a length limit of 9.5ft and 2.0 is ~15ft (that's if both ends are 2.0).
WOW I got quoted!! I'm honored. Anyway, length can be over come by using more powered hubs. I MIGHT have that problem in the suburban when the time comes. Check out USB.ORG, they have alot of good info on their site. Also MOBO headers may only have 1 controller so watch those 1.1 devices! Best bet for me is a 2.0 PCI card (full sized MOBO) unless you get a multi TT rated hub that TRUELY supports streaming 1.1 devices in to the high speed data stream.
PEACE.
SUVputer progress meter:
Planning[----------] - 5%
Aquisition[---] -------] - 30%
Dudes99 is offline   Reply With Quote
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 08:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 03:24 PM
USB Hub does not show HD after cold boot d_sellers1 General Hardware Discussion 9 04-05-2005 01:46 PM
USB HUB problems???? chuckctv Input Devices 7 10-08-2004 11:38 AM
Powering an unpowered USB hub? Squiddy Input Devices 5 09-02-2004 04:37 PM
