The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 08-11-2005, 01:36 PM   #31
Vehicle: '05 Subaru WRX STi
My Photos: (0)
My ebrake handle isnt actually touching the powermate. Theres about 3-4 mm of clearance. I can rest my hand on top of the ebrake and rotate/click the powermate with ease. I removed the rubber on the bottom of the powermate, and mounted it using 3m mounting tape.
Moondog51 is offline   Reply With Quote
Sponsored Links
Old 08-15-2005, 09:04 PM   #32
fonseca's Avatar
Vehicle: 2000 Tiburon
My Photos: (0)
I'm almost done with fitting a holder for my powermate. I had planned to leave the top edge intact and mold the console around it, but now I'm going to just trim the edges flush, although that might look weird with two high and two low sections. But still better than the alternative.
It's made entirely of ABS, and the inside is sized 2.25", slightly larger than the base, so the LED light will still be visible somewhat. I like that as a visual cue for master volume level. I also have an insert fabricated so the powermate will sit high, but the spacer can be flipped over, and the powermate will slip inside and be flush with the top of the holder if I don't want to use it, or have a mechanic play with it when I have my car worked on.
In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
fonseca is offline   Reply With Quote
Old 08-16-2005, 12:46 AM   #33
Vehicle: 90 VW Corrado G60
My Photos: (0)
As promised..
Barren is offline   Reply With Quote
Old 08-16-2005, 01:12 AM   #34
sivart321's CarPC Specs
Vehicle: 1990 VW Corrado
My Photos: (0)
ooooh looks good...But I've gotta counter it...
sivart321 is offline   Reply With Quote
Old 08-16-2005, 01:19 AM   #35
My Photos: (0)
That's hot! Mine's a slap and stick hackjob compared to yours!
Old 08-16-2005, 01:30 AM   #36
fonseca's Avatar
My Photos: (0)
How do you reach them with the e-brake handle like that? Long fingers I guess. . .
Sivart321, it looks like you have a slimmer aftermarket handle to help with access? And is your powermate still in stock form underneath the console? Just curious if you simply glued it from underneath and then put the knob back on.
Old 08-16-2005, 01:36 AM   #37
moahdib's Avatar
Vehicle: Acura TL 2004
My Photos: (0)
Here is mine enjoy!
Matches perfectly with the blue interior of my car. THe knob even looks exactly the same as my stereo.
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
moahdib is offline   Reply With Quote
Old 08-16-2005, 01:49 AM   #38
My Photos: (0)
The placement is actually rather convinient, not long fingers needed. It is not as easy to push and spin as it was before, but I rarely did that anyhow. Pressing, and turning works just fine. I understand where you are coming from. I did not think it would work there either until I tried it out myself.
As far as installing it, I drilled a 1.5" hole with a hole saw, pulled the knob off, stuck the powermate in from behind, put the knob back on. No glue was needed as the center console ends just behind the plastic panel and supports the back of the powermate just right. I had to remove the clear rubber bottom to make it fit, but had no need for it anyway.
Old 08-16-2005, 02:27 AM   #39
stimps's Avatar
Vehicle: 2002 Ford XR6T
My Photos: (0)
Now i Just have to figure out why the powermate fails to work about 50% of the time. Sometimes when you boot it works, sometimes it doesnt. Plugging it back in doesnt work either. Anyone have a clue? it really peeves me off to have to reboot all the damn time.
Ford XR6T blueprint 4.0 L twin cam turbo.
Xenarc 7" touchscreen M10000 Audigy 2 NX
ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
Griffin Powermate Panasonic DVD-CDW
Pioneer 5x7 Four way, 2x12 pioneer subz
600watt 6chan USA audio AMP
stimps is offline   Reply With Quote
Old 08-16-2005, 03:12 AM   #40
My Photos: (0)
Do you have the newest drivers? Is it plugged into a hub? Is the hub powered? The powermate requires alot of juice for it to work nicely. I would put it on its own USB cable if possible, with an active extension. Or put it on a hub, with the hub connected to power AND with an active extension cable. I have found non-active extensions do not work properly with most devices.
Sponsored Links
Old 08-16-2005, 07:13 PM   #41
R32 JUhl's Avatar
Vehicle: 2004 VW R32
My Photos: (0)
I feel your pain! I installed some drivers for a cheap USB sound card. Afterwards, my powermate behaved just like yours, as did my wireless mouse. A couple of weeks ago, I formatted my hard drive because the problem got to the point my touchscreen was effected, too (plus I had Win2k). I installed XP and reinstalled most of my software and now I'm back to 100% reliable operation again! It probably would be a good idea to follow the advice from sivart321 and go a step further by updating ALL your USB drivers by allowing the software to check for updates automatically on MS's site.
My first attempt at a carputer.
PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
R32 JUhl is offline   Reply With Quote
Old 08-18-2005, 12:45 AM   #42
stimps's Avatar
My Photos: (0)
Yes I still have to update my powermate driver, but the powermate is connected to its own, USB 2 port on the motherboard, no hub.
Funny thing is, this started happening sort of about the same time, I updated my USB audigy sound card's drivers
Old 08-18-2005, 07:17 AM   #43
R32 JUhl's Avatar
My Photos: (0)
That's certainly an amazing coincidence that sound cards drivers on two different computers cause the identical fault. If you're running XP you can do a "restore to XXXX" where XP basically uninstalls the drivers and resets the computer to the way it was before they were installed...
Old 08-22-2005, 01:25 PM   #44
Vehicle: '05 Audi A4 3.0q
My Photos: (0)
Quote: Originally Posted by ApoloV
Here's a pic of my Powermate.. slightly hacked and custom mounted.....
http://filebox.vt.edu/users/avanderb/RSX/IMG_0583.jpg
and
http://filebox.vt.edu/users/avanderb/RSX/IMG_0582.jpg
enjy
Apolo
ApoloV,
I was thinking of doing something similar with my powermate, did that knob that you used just so happen to have the correct knotches? I know the semi-circle knotch is pretty standard for a lot of knobs, but just curious, since that knob you chose looks to fit exactly in the area that I need.
Thanks.
replicant
Audi A4 (flickr pics)
replicant is offline   Reply With Quote
Old 08-25-2005, 09:31 PM   #45
My Photos: (0)
I have the same problem. it make me so mad i buy a hub and i powered it and the sucker some times work and some times not i can't figure out whats the problem.
plz help
russian_mafia is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
griffin powermate controlling gps (dest 3)? alanp Input Devices 0 01-24-2005 03:21 PM
FS: Griffin PowerMate USB muldrick Classified Archive 2 01-21-2005 09:15 PM
Device Like Griffin PowerMate TheLlama Input Devices 5 07-27-2004 12:32 AM
Griffin PowerMate? Can't get it to work... help please! coachreed General Hardware Discussion 14 07-03-2004 05:44 PM
The Griffin Powermate tejohnson General Hardware Discussion 16 02-21-2003 04:48 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
