The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 08-25-2005, 09:37 PM   #46
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
I've experienced this as well. It works about 90% of the time but every now and then it gets off and only a reboot fixes it.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Sponsored Links
Old 08-25-2005, 09:54 PM   #47
R32 JUhl's Avatar
Vehicle: 2004 VW R32
My Photos: (0)
Quote: Originally Posted by russian_mafia
I have the same problem. it make me so mad i buy a hub and i powered it and the sucker some times work and some times not i can't figure out whats the problem.
plz help
Did you try this? http://www.mp3car.com/vbulletin/show...0&postcount=40
My first attempt at a carputer.
PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
R32 JUhl is offline   Reply With Quote
Old 08-25-2005, 10:23 PM   #48
My Photos: (0)
Quote: Originally Posted by R32 JUhl
I dont install any drivers exept the touch screen & the powermate
cuze windows have all the drivers. plus my audiio card in onboard so i dont need any drivers
russian_mafia is offline   Reply With Quote
Old 08-26-2005, 09:07 AM   #49
R32 JUhl's Avatar
My Photos: (0)
Then you should definitely go out to ms.com and see if there are later drivers available.
Old 08-27-2005, 11:44 AM   #50
Bugbyte's Avatar
My Photos: (19)
Here's mine.
Sponsored Links
Old 08-27-2005, 09:52 PM   #51
CornToeGoblin's Avatar
Vehicle: 2008 Honda Civic LX
My Photos: (0)
Quote: Originally Posted by Bugbyte
Here's mine.
nice install! i like how you hacked up the button to put some kind of a switch for something.
2008 Civic... Sound system... then carputer install...
WORK IN PROGRESS
If you look at my avatar closely, you can see a chick with two big knockers....
CornToeGoblin is offline   Reply With Quote
Old 08-28-2005, 10:13 AM   #52
Vehicle: '05 Audi A4 3.0q
My Photos: (0)
BugByte, did you end up building a cover for the mac mini slot? I thought it was explosed with the slot dvd and metal retractable handle? good job on the powermate installation.
replicant
Audi A4 (flickr pics)
replicant is offline   Reply With Quote
Old 08-28-2005, 04:02 PM   #53
Vehicle: Mazda RX-8
My Photos: (0)
Hi
Here is one picture of my powermate installation.
Leonardo is offline   Reply With Quote
Old 08-28-2005, 07:35 PM   #54
Vehicle: 2004 Infiniti G35 6mt Coupe
My Photos: (0)
looks wicked, great first post leonardo
wizawuza is offline   Reply With Quote
Old 08-28-2005, 08:29 PM   #55
Bugbyte's Avatar
My Photos: (19)
I got thinking that with the computer just sitting there exposed it was screaming "steal me" so I fashioned a plastic plate over it to make it look like there's no radio. It's directly behind there.
I'll eventually put a vacuum flourescent display in that spot behind smoked plexiglass.
Old 08-28-2005, 08:39 PM   #56
My Photos: (0)
Bug,
That should be really tight. I think it is definitely a good idea to give it the OEM look that you did with the smoked plexi.
BTW, have you found that its very hard to change tracks wwith the "push and turn" method using the powermate? I'm asking this as a general question. Basically I guess I haven't gotten used to the right amount of push and turn to use for changing tracks
it ends up pausing and turning the volume up. Is there a correct method for changing tracks (using the press/turn)?
replicant
Old 08-28-2005, 09:04 PM   #57
Bugbyte's Avatar
My Photos: (19)
It is difficult to use press and turn. I've set mine to change when I do a long click and hold. I set it for 1/2 second and it works fine. If I make a mistake, all that happens is it mutes the sound.
Old 08-28-2005, 09:08 PM   #58
My Photos: (0)
bugbyte,
thats a great idea! thanks for that suggestion. one more powermate question for you. since we both run pretty much everything off our dc-dc powersupplies, i'm using an opus and you a carnetix.. have you found that the powermate keeps power even when everything else is shut off? for some reason it's holding the 5v rail and keeping it pumping juice. this is definitely a bad thing as it could easily drain the battery. i'm just using an unpowered usb 2.0 hub that is plugged into my via m10k. any thoughts on that?
i had wanted to switch to that carnetix 1900 with the extra 5 and 12v rails for lcd and a usb powered hub but i've got other carpc priorities before that
thanks!
replicant
Old 08-29-2005, 08:02 AM   #59
R32 JUhl's Avatar
My Photos: (0)
That's a firmware issue with your Opus. Here's a workaround and a full thread discussion on that topic. I installed the mod and it works perfectly!
Old 08-30-2005, 01:27 PM   #60
My Photos: (0)
my lil custom powermate installation
R32,
Thanks so much man! I'll have to look into building this relay, etc. Also, in the meantime, here is the start of my powermate mod in my 2002 maxima se. Basically taking the same idea as some of the other people here and using a different knob (mostly for size reasons). Here is one I snagged from an old pair of klipsch promedia computer speakers. The faceplate for it is made from abs plastic, it needs finer detailed sanding, bondo, more sanding then a couple coats of flat black and it'll be done, but that is to come after i add a master power switch and possibly some indicator lights. for the geek factor.
I may end up scrapping this location and turning my unused cigarette lighter into the powermate and use hte lighter knob itself as the knob for the powermate.
pic of the current installation after test fitting:
replicant
Sponsored Links
vB code is On
Trackbacks are Off
griffin powermate controlling gps (dest 3)? alanp Input Devices 0 01-24-2005 03:21 PM
FS: Griffin PowerMate USB muldrick Classified Archive 2 01-21-2005 09:15 PM
Device Like Griffin PowerMate TheLlama Input Devices 5 07-27-2004 12:32 AM
Griffin PowerMate? Can't get it to work... help please! coachreed General Hardware Discussion 14 07-03-2004 05:44 PM
The Griffin Powermate tejohnson General Hardware Discussion 16 02-21-2003 04:48 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
