The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 02-08-2005, 09:18 PM   #1
My Photos: (0)
Anyone Tried Using the OnStar Mic for Voice Input?
Just wondering if anyone has tried to wire the Onstar Mic into the computer for Voice Activation? Not sure how good it would work or not, but I was just wondering if it had been tried, since it is in quite a few cars now.
I have one in my car, and Don't use the OnStar service, so I was thinking about maybe trying if it was thought that it would work good, or are these cheap mics?
Thanks,
Bryan
2000 Yukon Denali
Shuttle SN65G2
Cel-D 2.4 GHZ 533mhz FSB
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
RF Mini Kb w/Trk Ball
7" Lilliput Touch Screen Monitor
USB 2.0 Hub
Rikaline GPS-6010
PN11 802.11b Wireless
XP Pro
750W Inverter
bry21317 is offline   Reply With Quote
Sponsored Links
Old 02-16-2005, 10:01 AM   #2
The Vauxhall Vectra Project
ccsnet's CarPC Specs
ccsnet's Avatar
Vehicle: Vauxhall Vectra C SRI XPack Auto - v5 ( Via 12000 based ) Sygic & With FreeICE
My Photos: (0)
Thanks,
Bryan
Been in the UK I am guessing thats a GMC car ? Its its any thing like my Vauxhall ( UK GMC ish ) the wiring should be simply enough to connect to. They place the mic for those with the car kits built in above the drivers head...if they dont its left there any way.
Point is if you track it back you should find a connector there some where... and after all its going to be nothing more than a normal mic.
Terran
ccsnet is offline   Reply With Quote
Old 02-18-2005, 09:29 PM   #3
Leddy's Avatar
My Photos: (0)
Per the manual:
Remove the overhead console. Refer to Console Replacement - Overhead in Interior Trim.
Disconnect the microphone (2) connector from the jumper harness.
Unclip the microphone bracket (1) from the overhead console.
Disconnect the microphone 2-way connector (2) from the mating 2-way connector.
Here's some help so GL, and I hold no guarantee of anything. If anything bad happens it's all you
2001 Pontiac Grand Prix GTP Sedan (Sold)
2007 Scion tC
WhereIsMyGPS.net Online Tracker
http://www.cardomain.com/id/leddy
Leddy is offline   Reply With Quote
Old 12-30-2005, 02:14 PM   #4
Banned
RPM_VR4's Avatar
Vehicle: 3000GT VR4
My Photos: (0)
I bought an OnStar mirror for my Mitsubishi. I have everything wired. The mic doesn't seem to be working though. I think it needs a higher bias then the mic on my on-board sound can supply. Does anyone know how I would inject a bias in to it?
RPM_VR4 is offline   Reply With Quote
Old 03-06-2008, 01:41 PM   #5
jeffw's CarPC Specs
Vehicle: 2006 HUMMER H3
My Photos: (0)
I'm using the OnStar mic for voice input into my car pc. I just spliced the wires at 8 and 9 (gray and bare) and plugged them directly into my mic input on my mobo. Works great for both voice control and OnStar.
RPM_VR4, if you are trying to use the OnStar mic without the OnStar module than you need to bias it. I tried biasing with a 1K resister to 9V and that worked fine. I also did a 1k/1k voltage divider to the 12V car supply and that worked, too. I don't know if there will be noise issues with using the car supply, though, so it may be prudent to use a voltage regulator.
jeffw is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
input for panasonic deck dizzytest General MP3Car Discussion 1 08-24-2007 03:47 PM
Weird Mic Problem.. Help! veetid Car Audio 45 09-30-2006 07:05 PM
OnStar GPS Interface Harry5150 GPS 13 08-10-2005 09:07 AM
IBM T42: disable onboard speakers and microphone using port replicator II WhiteRabbit General Hardware Discussion 8 11-18-2004 04:52 AM
What do you use for mic input? Sensor Input Devices 7 09-12-2003 10:36 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
