The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 02-12-2005, 05:17 PM   #1
gizmomkr's Avatar
Vehicle: 2000 Honda Civic
My Photos: (0)
Problems with Touchkit Serial Version (and solution)
The other day I booted my system and my touch screne wouldnt respond.
just out of the blue.... More on that later.
I decided to do a reinstall of the drivers (and an update)
Touchkit is pretty old. I gues not many advances come along in touch screnes.
So I searched and searched, but everyone had the same versions of touchkit. I tried to load it on my Win XP pc, and it failed. It gets right to the end of install, and then starts detecting the controler, and crashes. I tried another PC, same thing.
Finally I found Inotouch. Its still the same shell (all the buttons and windows are the same size and in the same place - It was a newer version number, and it loaded without problems. I think maybe the people that make the chips wrote the original, and distro that out to the OEM's... For those that need it - Visit http://www.inotouch.co.kr/support/software.asp
As for my touchpanel - turns out the root couase was a bad / cold solder joint - I have a DSCustoms / Xenarc 7 inch - The touch control has a 4 wire jumper from the LCD board - one of the pins had almost no solder around it. I touched it up, and now life is good.
Gizmo-
Techonlogy on Wheels
http://www.hjnetworks.com/car
gizmomkr is offline   Reply With Quote
Sponsored Links
Old 02-14-2005, 11:25 AM   #2
wi77iam's Avatar
Vehicle: 2004 Subaru WRX STi
My Photos: (0)
Hey Gizmo,
Thanks for that link. I need to re-install the drivers for my USB touchscreen and it looks like these will work for that also. When my usb hub died and I replaced it, I plugged in the ts and it's not recognized anymore. So I was going to re-install everything anyway - might as well use the most current.
wi77iam is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
