Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 03-09-2005, 11:55 AM   #1
mick0uziel's Avatar
Creative Infra Remote On Girder
hello all, i got the creative infra remote, with the credit card size remote and gigantic reciever like a flying saucer. i am having a problem trying to make it work with girder, does anyone out there use this remote and what did you do to make it work with girder. first of all i barely made it working under xp. now it works but when i use it on girder, the learn command when trying to map the key, it keeps on giving me an error "error com 1 hex=8" or something. when i suppress the errors, it gives out a code but they never work. anyone have a simpler tutorial with girder and this remote? what plugins to i need to put on girder? i just used the generic ir reciever plugin i think. any help is appreciated. thanks btw, i am trying to make this work with road runner. thanks again
7" Lilliput
Opus 150
mini itx 1Ghz
1GB sdram
97 Prelude
mick0uziel is offline   Reply With Quote
Old 03-09-2005, 03:39 PM   #2
nzKAOSnz's Avatar
ummmm. What version of girder?
I will check out when i get home.
You want to see something really weird? Open the case and see how much actually is in there.
92 Subaru Legacy Wagon
Epia MII12000 :D
Morex 80W
120G External HDD
16x2 Charater Display
Creative IR Remote
VIA Sereniti 2000 Mini ITX Case
7.2Ah SLA Tank
PCMCIA 802.11b
256DDR Ram
Diamonds are for girls- wise men follow the stars
nzKAOSnz is offline   Reply With Quote
Old 03-09-2005, 03:59 PM   #3
Curiosity's Avatar
Hehe. Not much in there at all. I chopped mine up and put a USB-serial thing on it, then crammed it into a tiny box with a stereo headphone jack for the remote IR cable.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 03-09-2005, 09:23 PM   #4
mick0uziel's Avatar
wow that is really amazing, that is exactly the remote i have. is it better if you go usb? i got a keyspan remote before and i cant get it to work with girder so i sent it back, now i got this creative infra and i cant make it work too (frustrating), btw the version of girder is 3.3 i think or 3.4. did you make yours work? how do i do it? help thanks
7" Lilliput
Opus 150
mini itx 1Ghz
1GB sdram
97 Prelude
Old 03-09-2005, 09:50 PM   #5
Just plain evil
blasterguy128's Avatar
In order to get my creative infra working with girder I needed a driver.
So here it is, enjoy!
Mobo= Epia V
Ram= 640mb
Ps= m1-atx
Screen= Lilly 7" ts
Hd= 40gig
case= 1/10 scale model of my car (04 Saturn Ion QC)
soundcard= soundblaster mp3+
GPS= Holux gm-210
blasterguy128 is offline   Reply With Quote
Old 03-09-2005, 11:34 PM   #6
Curiosity's Avatar
I didn't use girder. Just wrote my own code because it was easy. I only have 1 com port which is used for OBD-II so had to go USB. It works exactly the same though. No difference, just easier to plug in. The overall cost is a little more though.
You may be able to test it with HyperTerminal, although it's probably going to show garbage. Set it to the right COM port and 2400 baud, then start pressing buttons. You should at least see something if it's working.
Old 03-09-2005, 11:45 PM   #7
LESLIEx317537's Avatar
I have that same remote.
I hacked it up and ran the Rx into a Belkin Serial to USB converter.
I use my SB Audigy NX Series remote on this cause it works with this Rx and has more buttons. I have the same remote for my ZS Pro on my home pc.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
LESLIEx317537 is offline   Reply With Quote
Old 03-10-2005, 12:25 AM   #8
mick0uziel's Avatar
hey thanks for the help, the creative plugin did not work but the com port setting of baud=2400 was the missing answer. got road runner working a bit, i say a bit because i can only open the roadrunner gml file once. after i close girder, and try to open the road runner gml, it gives me an error "cannot open data file". can anyone tell me why i get this error and how can i fix it? thanks again
7" Lilliput
Opus 150
mini itx 1Ghz
1GB sdram
97 Prelude
Old 03-10-2005, 11:19 AM   #9
Curiosity's Avatar
Sweet! I would never have tried that. I was going to run the Audigy 2 NX IR sensor up to where the others are, but it works! I tried a few other remotes. Just the creative ones work with it.
Old 03-10-2005, 11:29 AM   #10
Curiosity's Avatar
I would think that girder has bugs and left the file open so it can't reopen it the next time. Does it work if you reboot?
Old 03-10-2005, 12:37 PM   #11
mick0uziel's Avatar
honestly i forgot to try that, but even if it does work, it shouldnt be like that right? especially rebooting in the car would just seem forever. i will try later thanks
7" Lilliput
Opus 150
mini itx 1Ghz
1GB sdram
97 Prelude
Old 03-10-2005, 02:00 PM   #12
I have had a remote in my new carpc for 1-1/2 years now and haven't used it yet. lol
What's the best way to get it to work with FrodoPlayer? I saw a girder plugin file but didn't do much research on it. Anyone wanna clue me in?
I downloaded and tried girder before. I have a IRMan at home, and the Creative in the car. I can't figure out girder cause I give up after 5 minutes.
Old 07-27-2005, 10:43 PM   #13
TucsonPred's Avatar
NM I got it finally
2K SVT Lightning, Some things and the usual truck pc, now with slot load dvd rom and ECM Data logging.
05 Scion xA
TucsonPred is offline   Reply With Quote
Creative CD Infra... Can I configure the remote control? Pichi Input Devices 6 06-01-2007 01:03 AM
Girder + Creative PC-DVD Remote ddt Software & Software Development 3 08-21-2004 01:22 PM
ps2 pelican remote w/ creative reciever & girder ShinkunoNamida Input Devices 0 04-26-2003 02:00 PM
Creative Infra Remote (Which Frequency?) Willems Input Devices 10 03-13-2003 03:35 AM
Creative Remote and Girder bombboyer Software & Software Development 4 01-04-2003 11:46 AM
