03-22-2005, 06:10 PM
#1
Vehicle: 2001 Ford Expedition
Slim Type CDROM/DVDROM/CDRW Adapter QUESTION
just bought this adapter from mp3car store but not sure where i can feed the power,can anyone tell me which one is the 5V and ground connection here,thank you
03-22-2005, 06:45 PM
#2
Vehicle: 2004/Chevy/Cavalier
looks like a floppy power connector ... on the left side underneat the IDE pins
03-22-2005, 07:53 PM
#3
so i just need to connect the power cable for floppy drive?
03-22-2005, 07:55 PM
#4
Vehicle: 2002 Trailblazer LS 4x4
yup
03-22-2005, 09:49 PM
#5
thank you
03-03-2006, 05:13 PM
#6
Vehicle: 2004 Infiniti G35 Coupe
what are the jumpers for?
I am trying to set my dvd to the secondary device
03-04-2006, 08:13 AM
#7
jumpers should be labelled, i think i can see the letters but can't quite make them out.
M = master
S = slave (secondary if you want to call it that)
C = cable select (device works out what it is by where it's plugged in the cable, if it's plugged at the end of it's a master, if it's plugged in the middle it's a slave, and if it's plugged in the other end (which is further away from the middle) you've plugged it in wrong that's where the motherboard should be).
03-04-2006, 11:57 AM
#8
The jumpers are not labeled. There are only 4 pins, I am assuming that they might be CD connectors.
Is it true that the slimline drives with an adpater are not capable of having two devices on a single cable? Right now I am trying to use the dvd as a slave device to my boot disk.
08-17-2007, 10:32 PM
#9
Vehicle: 2002 Subaru WRX
Does anyone know the answer to this? I put a jumper across pin 1 & 2, 2 & 3, and 3 & 4 on Jumper 4, but the CD drive detected as a master even when on the slave port. I'd like to run this as a slave.
Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
12-17-2007, 09:24 PM
#10
I have the same problem. This is really poor for this site to sell these devices with ZERO documentation. I am very disappointed. Shipping was fast! This does no good If I cant get specs on the parts I paid for. Googling brought no luck in a manual. If anyone has help, please share it with us unknowing people.
12-17-2007, 09:28 PM
#11
Vehicle: 2004 GMC Canyon
I have never had to install jumpers on the 2 drives I have. I select CS (cable select) on the hard drive and install an 80 pin cable and all of my MB's have found all the drives just fine.
12-18-2007, 06:41 AM
#12
Location: Singapore - Smallest country in Southeast Asia
Vehicle: 2005 Fiat Doblo
is it possible to get digital/optical out from this?
12-18-2007, 09:47 AM
#13
Vehicle: 98 Trans Am
From the picture above, the 3 lower connectors are floppy power, audio out, and audio out. It just supports the 2 different types. Both are stereo analog. There are no jumpers on the adapter.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
12-24-2007, 07:14 AM
#14
I had to plug my slim slot load DVD inot IDE2 and then it worked fine.
Just curious your sig says something about a USB resume? Can you enlighten me on what this is, and what it does exactly?
12-24-2007, 07:17 AM
#15
I need to install my touchscreen drivers now, and am afraid to stick a mini DVD into my slot load drive! Can they handle those?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
