Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 06-01-2005, 08:13 AM   #1
"Unknown USB device" Fellowes Micro Trac Trackball
I have a Fellowes Micro Trac Trackball (USB connection), when I plugged it into my CarPc (Running Windows XP, SP2) it worked fine (it doesn't come with any drivers). Then I plugged it into a 5 metre USB extension cable and the CarPc tells me that there is an "unknown device," connected and the trackball doesn't work. I have tried uninstalling all of the USB devices in the 'Device Manager,' and then restarting the computer and plugging the exstension cable back in...same problem. I have tried all of the USB ports on the computer...same problem. I have uninstalled SP2...same problem.
I have tried the trackball with the 5M exstension on another computer before using the trackball without the exstension on that computer and it worked fine! Maybe because I used the trackball by itself on my CarPc before the USB exstension the CarPc is getting confused.
If anyone has some advice it would be greatly appreciated
smkau18 is offline   Reply With Quote
Old 06-01-2005, 08:32 AM   #2
evandude's Avatar
sounds like your extension isn't very good. that could cause it to work on some computers, and not others, depending on how good their USB ports were.
You could try an "active" USB extension (those have amplifiers to maintain signal strength on an extension)
Personally I'm running my fellowes trackball off a USB hub, which runs through a 15-foot extension to another USB hub, to the USB port. Both hubs are bus-powered (just cheap $4 things) Perhaps you could get a cheap hub and put it on the end of your extension and run the trackball through that. The hub would condition the signals, and might be enough to get them through the extension.
But don't take it from me! here's a quote from a real, live newbie:
Quote: Originally Posted by Viscouse
I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
eegeek.net
evandude is offline   Reply With Quote
Old 06-01-2005, 08:45 AM   #3
Thanks for the tip 'evandude' I will see if I can get hold of a USB hub or "active" USB exstension.
Cheers
Old 06-01-2005, 08:56 PM   #4
Just bought the active USB exstension and the trackball is working again. Thanks for the advice!
Old 06-01-2005, 10:50 PM   #5
Curiosity's Avatar
You also could have shortened the cable. If it's 5M and the trackball has a 1M cable, that's a bit over spec, so cutting the 5M down to 4 would probably have worked.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 06-02-2005, 07:25 AM   #6
Oh well to late, a bit to much fiddling to cut the cable, I got a refund on it anyway.
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 11:49 AM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 08:35 PM
another lilliput "unknown device" problem Sonicxtacy02 LCD/Display 1 10-01-2005 12:22 AM
USB repeater as "unknown device" sanbas General Hardware Discussion 12 04-25-2005 05:07 PM
Stupidme, USB 1.1 Micro Hub judoGTI General Hardware Discussion 8 08-22-2004 06:42 AM
