The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Search this Thread Display Modes
Old 06-23-2005, 01:59 AM   #1
My Photos: (0)
touchscreen not working
i have a tview, recently installed it. installed the driver for the touchscreen. it doesnt work for some reason. do i need to unplug the mouse for the t/s to work?
iHATEspeedbumps is offline   Reply With Quote
Sponsored Links
Old 06-23-2005, 02:06 AM   #2
Para Laura
thanatos106's CarPC Specs
thanatos106's Avatar
Vehicle: Xterra SE supercharged
My Photos: (0)
No you don't need to unplug any other input device for the TS to work....
do you have the sound notification from windows when you plug it??
when you open the Touchkit/configure utility do you see the usb device in the active panel windows???
possible fix:
1.reinstall driver
2.Check that the TS is geting power.
3.open the housing and check that the usb cable is tight in to the TS controller conector.
Ckect one by one and narrow the problem down
good luck.
thanatos
thanatos106 is offline   Reply With Quote
Old 06-23-2005, 03:02 AM   #3
techy101's CarPC Specs
techy101's Avatar
Vehicle: '05/Subaru Forester XT
My Photos: (0)
I've been having TS problems with my DWW-700M recently. Not the same unit, but it will just quit working. The best way I've found is to uninstall the device, uninstall the software, unplug the device, reboot, plug in the device, install the software/driver. This has been my formula for the POS TS until I get it replaced
Outside the dawn is breaking on the stage that holds our final destiny...
Dual In-Dash Screen Carputer Installed Check It Out.
techy101 is offline   Reply With Quote
Old 06-23-2005, 03:19 AM   #4
My Photos: (0)
i checked all connections. everything is intact. i will uninstall and reinstall tomorrow. should i unconnect everything and then reconnect after installation?
Old 06-23-2005, 03:28 AM   #5
Para Laura
My Photos: (0)
Yes.... just to be sure.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
BMW 540 Touchscreen Complete! sajid753 Show off your project 58 04-23-2007 04:52 AM
Touchscreen not working Ascension LCD/Display 5 06-01-2005 11:14 AM
Touchscreen problems with nlite and minlogon Ascension WinNT Based 1 06-01-2005 05:18 AM
Honda factory touchscreen to get DVD working? gadget Newbie 1 04-27-2005 03:53 AM
Lilliput touchscreen problem samc Input Devices 1 05-09-2004 11:12 AM
Sponsored Links
Ad Management by RedTyger
