Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 07-30-2005, 06:30 PM   #1
ashbosh's Avatar
How to calibrate in 800X600
How do people calibrate in 800X600 resolution since the bottom 120 pixels get cut off?
Current project ■■■■■■■■■■■■■■■■■■■■■■■■■■___ 85%
Xenarc 700TS, Mobile Athlon 1GHz, Soyo K7VME, 30Gb HD, Slimline DVD drive, TB Santa Cruz, Opus 120W
Holux G210
03 Acura TL, Zapco & Precision Power amps, Adire Koda comps & EDesign 12" sub.
ashbosh is offline   Reply With Quote
Old 07-30-2005, 06:32 PM   #2
Para Laura
thanatos106's Avatar
change refresh rate to 75hz.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 07-30-2005, 08:33 PM   #3
ashbosh's Avatar
I'm sorry, let rephrase my question. How to calibrate the touchscreen in 800X600 mode when the bottom part get cut off?? thx
Holux G210
Old 07-30-2005, 08:35 PM   #4
ashbosh, you can't. I tried that before. Asked several Xenarc tech support guys, too. There's nothing you can do.
b8bboi is offline   Reply With Quote
Old 07-30-2005, 08:46 PM   #5
Para Laura
Did you try the 75hz refresch rate...???
I run 800x600 75hz in my xenarc and the lower part shows just fine.
Nissan Aux-in MOD
Old 08-01-2005, 10:02 AM   #6
ashbosh's Avatar
I did it and it worked... THNAKS A LOT. Amazing or should I say weird??? It reduces the display height, for higher refresh rates, do you know why?? I like to know.
Holux G210
Old 08-01-2005, 02:08 PM   #7
Mine runs in 800x600 at 75hz too. I assume the lower refresh rates just don't get locked onto properly for it to resize the display to the correct aspect ratio...
Old setup
Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
markbuts3 is offline   Reply With Quote
Old 08-01-2005, 10:30 PM   #8
ashbosh's Avatar
Thanks all for the help, especially thanatos106. Otherwise I was going to buy a new video card and agp riser card and run powerstrip and all. Saved me some $$, time(=$$) and headache and wife beating me up for spending too much time on it. :-|)
Holux G210
Old 08-03-2005, 04:25 AM   #9
Maņana's Avatar
In the Touch config program you set the screen as a "split screen", and you tell the ts just to work with the upper shown 800x480 pixels.
My carputer
Old one
Maņana is offline   Reply With Quote
Xenarc locked in 800x480! Want 800x600 aoLhaTer LCD/Display 4 02-18-2005 08:44 PM
[Mediacar] default skin in 800x600 needed! _wd MediaCar 1 11-13-2004 09:35 AM
Probl. embedding FrodoDVD with 800x600 swissRv MediaCar 0 09-14-2004 04:39 AM
"Stretched" 800x600 MediaCar F-CNS skin available febsperanza MediaCar 25 06-08-2004 12:56 AM
BloodBoil and Spaced Out for 800x600 16:9 Screens Confused MediaCar 0 12-10-2003 04:37 AM
