The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 10-30-2005, 08:16 AM   #1
sigol's Avatar
Vehicle: 2004 Audi 1.8T S-line
My Photos: (0)
Intermittent touchscreen problem :-(
Hi hope somebody can help...
My project is virtually finished. Will post final pics soon.
I've got a liliput 7" touch screen and the problem is that the touchscreen facility is intermittent. I can hear the sound Windows makes when it loses or finds a USB device.
There seems to be no pattern to this. It can happen at startup, not happen all day or happen just about whenever it feels like it. When Windows loses the connection, it can be down for seconds or for hours.
The connections seem nice and snug. The only thing I can think of is that the USB cable goes in to a USB hub in the glove box so i can't rule out whether the hub is faulty or the screen. (However, when the screen goes down, the backup mouse and keyboard work fine - so probably not the hub then).
Please can you help - it's putting a dampner on an otherwise great install. :-(
Thanks in advance...
Simon Goldstone
Carputer Install
Audi A4 1.8T S-Line
Epia MII 12000 | 512 MB RAM | 300GB HD
Slimline slot CDRW/DVD | Silverstone LC02
WIFI | 3G/GPRS | Bluetooth
Hauppage Digital TV
sigol is offline   Reply With Quote
Sponsored Links
Old 11-01-2005, 08:41 AM   #2
DaKyy's Avatar
Vehicle: -96 Peugeot 406 2.0A & -87 Volvo 480ES
My Photos: (0)
I've got the same problem, this has occured after I installed the carpc permanently to my car. Before I had the case just bumping around the trunk and it worked OK. It usually starts to work when I shut down Lilliput and reconnect the monitor cable (usb&vga). Don't have a solution though.
DaKyy is offline   Reply With Quote
Old 11-01-2005, 09:07 AM   #3
CapitaineFritz's Avatar
Vehicle: 2006 Mazda 3 GT GFX
My Photos: (0)
You can try:
1- Without your usb hub... just to be sure
2- Another computer (like a laptop), again just to be sure it's not the O/S
Via Epia M10000 / 512 DDR / 10gigs 3.5 HD / M1-ATX / Innovatek 7" TS Screen
Trunk fiberglassing in progress...
Need GPS / Aux Input / WiFi
My Corolla Computer
CapitaineFritz is offline   Reply With Quote
Old 11-01-2005, 09:31 AM   #4
IntellaWorks's Avatar
Vehicle: 2005 Toyota Tacoma
My Photos: (0)
Whats the temp. Inside your car when its doing this problem?
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 11-01-2005, 01:48 PM   #5
sigol's Avatar
My Photos: (0)
Guys, thanks for your replies.
DaKyy: I know! it's frustrating. I had the PC in bits for a month to prove it all works and the minute I install it - this! arrghhh!
CapitaineFritz: Will do - good idea about laptop - I will try and report back.
IntellaWorks: I don't have the luxury of being in a nice warm country like you. I live in Manchester where it rains more than in any other city in Europe! It's a constant 19 deg C in my car and no more! It can happen at any time of day and under any environmental conditions.
Best wishes,
Sigol.
Simon Goldstone
Carputer Install
Audi A4 1.8T S-Line
Hauppage Digital TV
Old 11-01-2005, 03:41 PM   #6
volum3rider's CarPC Specs
My Photos: (0)
hmm this happened to me before and the reason for me was that my usb hub was not getting enough power. You can try to power the hub it it isnt already becasue a bus powered hub only gives out 100ma a port where as a powered hub gives out 500ma a port. The touchscreen draws 100 ma so my screen would stop working once in a while also. Hope that helped.
volum3rider is offline   Reply With Quote
Old 11-02-2005, 01:16 AM   #7
sigol's Avatar
My Photos: (0)
Hi colum3rider,
Yes that certainly could be the problem. The hub is bus powered. I'll try powering it and see what happens.
Cheers!
Simon Goldstone
Carputer Install
Audi A4 1.8T S-Line
Hauppage Digital TV
Old 11-02-2005, 12:53 PM   #8
DaKyy's Avatar
My Photos: (0)
I've tried plugging every other device out but still having the same problem...
Old 11-05-2005, 11:36 AM   #9
DaKyy's Avatar
My Photos: (0)
I tried to switch the touchscreen to another USB-port, and only kept the TS connected of my USB devices. Still the same problem occurs. It works for while and then it stops when I start the car next time. If I unplug the power cord from monitor and stick it back in, Windows seems to recognize it(you hear the sound) and instantly you hear the disconnect sound.
Next I'll try the TS drivers, and after that I'll probably verify that the USB-connection is OK from the monitor end. The cable from front to boot is good as the USB keyboard works ok when it is connected.
Old 11-08-2005, 12:06 PM   #10
DaKyy's Avatar
My Photos: (0)
OK, the TS is fixed now - until the next time the problem appears Probable cause is the cord from screen that is connected with that weird, tightening thingie
So, Sigol, Test your USB cable is ok, and after that try reconnecting the screen cable...
Sponsored Links
Old 11-09-2005, 11:18 AM   #11
sct73's Avatar
My Photos: (0)
Did you manage to figure out exactly what this problem was? I have had the same problem, driving around it can be fine for hours and then suddenly just start "boinging" the windows sound every now and again, this afternoon it did it and now the touchscreen wont recognise my touches. It recognizes the touches but not where I touch the screen and it doesnt move the cursor. Also I get the 'calibrate the screen' message everytime I boot up, which asks me to touch the four corners of the screen each time. Do you have any ideas??? I have one of these screens which wonderfully came with no drivers!! which was a problem to start with and I have installed the drivers from http://www.egalax.com.tw/eg/drivers.htm which have been recommended in other thread I have read. Do you have any ideas??
Simon
Ford Fiesta 16v 2000 - Media Engine - 8" Touchscreen - 40gig - XP Pro - DVD - VIA C3/EDEN EBGA Processor - Wireless
Waiting for GPS (need to figure out which software is best for the UK)
sct73 is offline   Reply With Quote
Old 11-09-2005, 11:27 AM   #12
ITL
ITL's Avatar
Vehicle: 2004 Acura TL 6MT
My Photos: (0)
if you're sure you've got enough power to the USB, it could be a bad USB cable...might be hard, but I'd try getting ahold of another cable just to verify. Not to mention first removing and THEN re-installing the driver.
CarPC #3: 99% Complete
Pentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more!
old carPC
ITL is offline   Reply With Quote
Old 11-09-2005, 05:34 PM   #13
DaKyy's Avatar
My Photos: (0)
Yeah, first, get a new/working USB-cable and place it temporarily in your car (yep, put it with the other 254 temporary cables) and test if it acts the same way. If it does act the same way, and for example, the TS USB disconnects (you hear that boing), plug out your TS USB cable, and reconnect it. If you don't hear the connect sound this time, it's probably somewhere in the cable.
My TS is still working, the problem seems to be the touchscreens own cable connector(vga&usb). That connector is awful desing.
I was also suspecting the installed USB-cable, that is ran under panels with other cables, including the main power cable for carpc. Inductance could play up with that kind of tricks. More so if there is poorly(poor quality) shielded cables.
Old 01-29-2008, 08:02 AM   #14
My Photos: (8)
This post is old, but helpful.
I had 2 active USB cables in serial. The power from the computer in the trunk was too low and the screen could not maintain a stable connection with the computer. I assume there's a USB device recognition period because it would work sometimes. I inserted a powered usb hub (without the power) and it solved the problem. I imagine this is because the USB hub can maintain a good connection with the computer by not requiring power to do so, so if the touch screen is flickering in and out of connection, this is smoothed by capacitors in the hub.
My second theory is that the screen likes the hub better than the active usb cables because the hub is sexier.
irhiggs is offline   Reply With Quote
Old 02-12-2008, 10:05 AM   #15
americasfuture2's CarPC Specs
americasfuture2's Avatar
Vehicle: 2008 Chevy Aveo
My Photos: (0)
my lilliput was doing the same thing. it turns out the cable going to the monitor was being pulled on. hit a bumb and its disconnected, but still had video. i had to put some slack in my cable. havent had a problem since. (2 weeks now)
Gathering parts----99% (I'll always want something else, its never 100%)
Using and programming in RR 3.14% (I need tons of help on this one!)
First Actual 98 Blazer LT Install
08 Aveo5 SV and 87 Fiero GT needing carputers
americasfuture2 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Touchscreen driver install problem, HELP! (Lilliput 7") davem LCD/Display 4 07-04-2007 06:07 PM
Lilliput LCD touchscreen problem smartroad Road Runner 6 06-14-2005 02:15 PM
7" Lilliput for sale NO TOUCHSCREEN CDesigns Classified Archive 11 05-24-2004 09:47 PM
Lilliput touchscreen problem samc Input Devices 1 05-09-2004 11:12 AM
ps/2 touchscreen problem Odie LCD/Display 0 02-20-2003 05:27 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
