Quote: Originally Posted by lez
have you checked the mouse control built in the chip is active ?
I have a ps2 to usb keyboard and a ps2 keyboard and mouse to usb adapter, both use the same chip, but even adding the wiring to the other one to bring it up to mouse and keyboard wont work as it wont see amouse, seems its in the firmware etc and activated at production time.
cy7c63723 on both.
thanks for the tip Lez. I have not even checked it yet. im just remaining hopeful. heh. if the mouse controller is not active, it wqont be much of a big deal because I will just use a usb hub,. the real digger will be if the other "keys" are not active. if they programmed it with none of the other pin s active, it will be a real bummer. there is no way I could solder a NEW one on. but hey, maybe these things are reprogrammable? I havent had time to check out the programming software for these things..
