Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 05-24-2006, 07:07 PM   #1
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
$10 volume knob fabbed
Well I finally got around to making a volume knob for my PC. I gutted a $10 mouse and made a shaft come out the side where the wheel once was that im going to attach a knob to. Im using Volumouse software and everything works perfect!! Volumouse is highly configurable, and i have it programmed to feel just like an OEM knob. Even in roadrunner it moves the volume slider on my frontend!! I still need to install it in the car but the hardware/software config is complete. Here are some pics of the almost completed hardware hack
blk02si is offline   Reply With Quote
Old 05-24-2006, 07:39 PM   #2
banned - scammer
97GST's Avatar
97GST is on a distinguished road
Haha... My Pioneer deck took a massive dump on me. So I been just ripping the crap outa my car apart... Glassing, fabing, moding, measureing and all of that. I allready had a mouse waiting for doing a volume knob... and I just thought of using the knob off my pioneer stereo! And the perfect spot! My old cigarette lighter port... and its allready setup to have a blue halo around the knob! Which will be located under the screen... kinda not in a good area, but it will fill up that hole that I never use and help out with a nice clean install!
1998 Mitsubishi Eclipse GS-T
ABIT NF-M2 nView | AMD Athlon64 FX62 Windsor | nVidia GeForce 6150 | Realtek ALC883 7.1DTS | Vista x64
RF Power T162S | RF Power T162S | 2x RF Power T212D2 | RF Power T8004 | RF Power T20001bd | RF 3SIXTY.2
97GST is offline   Reply With Quote
Old 06-04-2006, 04:57 PM   #3
TheLlama's Avatar
TheLlama is on a distinguished road
Have you found any good knobs?
TheLlama is offline   Reply With Quote
Old 06-04-2006, 09:20 PM   #4
High Voltage
blk02si's Avatar
I found a few at radio shack but I may hold out for an OEM knob. Ive been looking for a scrapped mustang radio to get it really OEM. Ill be sure to update this thread when I complete the hack. Im busy, plus im working on carPC version 2 myself. Ive got a thread going on that too.
Old 10-15-2007, 10:49 AM   #5
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
I have a mouse very similar to yours with the mechanical wheel. Have you figured out / found anything to use as a knob? Currently I just have the wheel. What is it that you have in yours? Almost looks like a drill bit.
This would by far be the easiest route I think. Some have said to replace a part when doing this with an ALPS part? Is that needed?
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 10-15-2007, 05:17 PM   #6
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
You have many talents BLK Is it just an ordinary mouse ya'll talking about (not optical) ?
That looks like a drill bit you're using as a shaft INVENTIVE!
I'm going to follow this one.
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 10-15-2007, 08:11 PM   #7
fixerofallthing's Avatar
fixerofallthing is on a distinguished road
I just did this mod on an old USB mouse that had been worn out. Volumouse works great and it is in the truck working great. I used a chrome knob off of a bass guitar.
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline   Reply With Quote
Old 10-15-2007, 08:16 PM   #8
d0tech is on a distinguished road
Please take a picture
d0tech is offline   Reply With Quote
Old 10-15-2007, 09:11 PM   #9
Raw Wave
tbird2340's Avatar
Fixer that is SWEEEET! Thanks for the pictures. What did you use here:
I have a similar mouse but I'm wondering what to use for the shaft part..
Old 10-15-2007, 09:22 PM   #10
I used the 13mm 3/8 drive deep piece from one of these socket organizer but in grey. The black part is the original wheel with the rubber coating removed. The shaft is hollow and fit almost perfectly over the end of the original wheel and the 13mm (1/2")is the same size inside the knob.
Old 10-15-2007, 09:36 PM   #11
High Voltage
blk02si's Avatar
I used a drill bit for testing it out on mine but now it has been replaced with 1/8" aluminum rod. The hack is really easy to do, just get volumouse, configure it to work how you want it. Then start tearing down the mouse. I glued the right and left 'click' buttons in open position so they can never be pushed by accident, and in my mouse was able to pry off the little wheel that the sensor reads and put it onto a shaft.
One thing to take into consideration, the sensor needs to be in a dark place to work, while testing I noticed if its near a bright light source it would lose functionality. Put it in the dark and it works again. So it needs to be concealed from light to work correct.
Old 10-15-2007, 11:03 PM   #12
Raw Wave
tbird2340's Avatar
Here is the one I have:
How did you guys get it so the part I'm pointing at stays in place? With out it being in the mouse housing it moves / falls right off when I touch it.
Old 10-18-2007, 10:50 PM   #13
Raw Wave
tbird2340's Avatar
Anyone??
Old 10-18-2007, 11:31 PM   #14
High Voltage
blk02si's Avatar
I used epoxy and fabbed up a holder for it. Kind of hard to explain but you need to mount the PCB then mount a 'tube' for you input shaft. The input shaft needs to turn the mouse wheel and on the other side have a knob. Get creative and it will all come together
are you putting it in a tbird?
Old 10-19-2007, 07:49 AM   #15
Raw Wave
tbird2340's Avatar
Thanks for the reply...
No, a Dodge Ram
Volume Knob DjBac General Hardware Discussion 32 10-15-2007 12:06 PM
USB or Home made volume knob seninha Car Audio 7 01-10-2006 06:27 AM
Custom Volume knob question mbkowns Input Devices 1 05-17-2005 12:09 PM
Volume KNOB!!!! toxsickcity General Hardware Discussion 7 03-23-2005 01:17 AM
griffen powermate usb volume knob e36mp3 Classified Archive 6 08-26-2002 09:08 AM
