Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 06-17-2006, 09:00 PM   #1
WTF..touch function keeps freezing
after about 3mins of leaving it still, itll freeze on me...then id have to restart the computer to get it to work again or disable/enable device to get it to work....anyone has this problem or know how to fix it?
it works fine if im constantly using it, but leaving it still itll freeze regardless of applications running
and BTW new copy of windows XP installed and no other programs except lilliput
azunboy is offline   Reply With Quote
Old 06-17-2006, 09:35 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
Check the properties and make certain that it's not set to turn off hte device to save power. I've seen this option on a lot of devices and I absolutely hate it.
That may or may not be your problem, but it's certainly worth a shot.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 06-17-2006, 10:32 PM   #3
ahh..got my hopes up..but that wasnt the problem...
Old 06-18-2006, 03:59 PM   #4
anyone?
Old 12-10-2006, 03:10 PM   #5
mine did that too.
i found out that using a shorter usb cable everything works perfect.
initial i had a 6 meters long usb cable...
My second Subaru skin
Full screenshots second skin
My car photos
CarPC Progress
■■■■■■■ - 75%
mugurg is offline   Reply With Quote
Old 12-13-2006, 10:03 AM   #6
mine does that too, but I havn't figured out the problem yet
dyne is offline   Reply With Quote
Old 01-16-2007, 07:33 PM   #7
well, I thought I had fixed the problem by reinstalling windows and turning off winxp's power management of the USB devices.
I took a 3 hour drive without a problem, and then a few days later, 15 minutes into driving the touch screen froze. I had regular mouse that I plugged, and went into device manager. Apparently, the touch screen became an "Unkown Device" under USB devices. Disabling and renabling (which required a reboot) fixed it.
Anyone know why it would do this? I'm using TinyXP rev05 with XP embedded and havent had a problem otherwise
Old 01-16-2007, 07:54 PM   #8
Mine does something similar.
Might be a long shot but see if the usb plugs move when they are pluged in. I have a motorised screen that isn't properly secured (because its moving soon). Whenever I go over speed bumps... the touch screen wont work.
I might try fabricating some sort of fastener or something similar to the plug used for the monitor.
Night Crawler is offline   Reply With Quote
Old 01-16-2007, 07:55 PM   #9
I was wondering about that, but I doubt it since it's in there pretty good a simple reboot fixes the problem.
Old 01-16-2007, 08:00 PM   #10
I thought that at first, because all I have to do is reboot mine. I started playing around with the wires and noticed a bit of movement in the usb plugs. Only a tiny ammount though. Tried to do something on the screen after wiggling the usb plug and nothing happens.
Worth a nosey
Old 01-17-2007, 02:14 PM   #11
what kind of setup are you using? Im just looking for similarities that might be causing it
Old 01-17-2007, 09:00 PM   #12
I just got my 8" touch screen today and was dissapointed when it kept freezing the touch function after 3-5 min of inactivity.
Connecting it to a different USB port on the laptop seems to have solved the problem.
Borisw37 is offline   Reply With Quote
Lilliput 7" (first model) touch function dead holistic LCD/Display 3 09-28-2005 01:27 AM
Touch screen not worky worky (T-View 7") deetap LCD/Display 7 08-22-2005 04:44 PM
Lilliput (FA801 8" Touch) problems - reversed touch optiks LCD/Display 3 08-18-2005 12:03 PM
dual mouse cursers for touch screen beaverpants Input Devices 1 06-21-2004 02:02 AM
Xenarc Touch Panel on Lilliput Controller badandy4you LCD/Display 5 06-04-2004 12:54 PM
