Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 06-29-2006, 11:12 PM   #1
L-U-R-C-H is on a distinguished road
Lilliput Touchscreen Stops Working!!!
Okay I bought a Lilliput 7" Touchscreen not very long ago. It's the 629GL-70NP. I'm using Windows XP SP2 with all updated drivers and firmware. I have tried using a bunch of different drivers for the touchscreen. Every so often when I boot the computer up, the touchscreen doesn't work. I look in the device manager and it's not even listed! It's like sometimes when windows boots, it forgets that the USB cable is even plugged in! I tried pulling out the cable and reinserting it but that doesn't work. I tried using a different USB port and that usually works after reinstalling the drivers. Let me tell you, this has been a huge pain. I've gotten to the point of almost wanting to get rid of the computer setup because not being able to use the touchscreen takes all the fun away! I searched all through the forums and it seems like no one has been able to find a fix for this issue. I found a lot of posts on this problem so it seems to be very common.
Has anyone found a fix for this problem?
L-U-R-C-H is offline   Reply With Quote
Old 06-29-2006, 11:18 PM   #2
Raw Wave
edrex's Avatar
edrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud ofedrex has much to be proud of
Get a Xenarc!
Sorry, I really couldn't help myself...
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
Quote:
Don't mess with Texas.
It's not nice to pick on retards!
edrex is offline   Reply With Quote
Old 06-29-2006, 11:26 PM   #3
Too bad I paid $270 for my Lilliput...that's not gonna happen!
Old 07-02-2006, 02:22 AM   #4
spastik is on a distinguished road
hey i had a simlar problem it says usb dvice failed. realy ****ed me off. try pushing the small vga conector into the screen end or wiggle it a bit worked for me.
spastik is offline   Reply With Quote
Old 07-05-2006, 11:26 PM   #5
Haha! Guess what guys...I fixed the problem!! It was the USB extension I was using! For some reason it didn't like the active USB repeater cable I was using. I tested er out with a regular passive USB extension and it solved all my problems! It works for hibernation just fine now...whoohoo! Sorry, I'm in a good mood lol.
Old 07-09-2006, 06:30 AM   #6
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
Just some info. I have a 10.4" Lilliput Touchscreen LCD. I was having a problem where the cursor/touchscreen would get reallllyyy sluggish. It was really ****ing me off as it would take 4-5 'presses' to move the cursor. I tried numerous usb ports with no luck. It would even prevent Windows from booting at times. Downloading and installing the latest lilliput drivers helped, but it was still lagging quite a bit. I originally had it plugged into a powered hub, which was plugged into the laptop. Once I ran a regular usb extension cable directly from the monitor to the laptop, it worked perfectly. Go figure. Anyways, I'm happy now too :-) Everything works perfectly.
W3bMa5t3r is offline   Reply With Quote
FS:: 7" Lilliput touchscreen lcd carfreak01 Classified Archive 11 08-29-2005 12:47 PM
Lilliput touchscreen driver for custom linux distro immolo LCD/Display 5 04-29-2005 04:47 AM
Lilliput Touchsceen Controller (USB) Stops Responding...?? Mrbmw99 LCD/Display 2 12-03-2004 01:58 PM
Lilliput Touchscreen Problem BrUTaL LCD/Display 12 10-23-2004 11:52 AM
Blew dust off, searched, and still no touchscreen on Lilliput - help! TheSpatulaOfLuv LCD/Display 4 10-13-2004 10:17 AM
