Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Old 08-13-2006, 04:32 PM   #1
linkyone's Avatar
DVD-ROM Power issue
I have a DVD Rom that doesnt want to spin up and operate. It is connected to a usb 2.0 hub in the dash. I am powering the hub from the psu. now the hub works fine (bluetooth, gps, keyboard) but when i plug in the DVD-rom it never really spins up all the way. it only gets so fast then stops and starts again. the dvd-rom is connected to the hub with one usb cable and the power for the drive is coming from the same wire (+5) connected to the PSU for the USB hub. i have pulled the dvd rom from the car and connected to a wall outlet (using the AC\DC converter provided) and it spins up just fine. now clearly i have a power issue (current related) but i dont know where to start. I can only guess my next move is to purchase a 12 to 5 volt regulator rated at 3 amps (same as the AC\DC converter) and try that. The PSU (m1-atx) is rated at 10A for the 5V rail and i dont think i am over that limit. I have only a bluetooth dongle, gps, a mini keyboard, and occasionally a flash drive connected. Any suggestions?
linkyone is offline   Reply With Quote
Old 08-13-2006, 04:50 PM   #2
binary.h4x's Avatar
http://store.mp3car.com/SearchResults.asp?Cat=10
binary.h4x is offline   Reply With Quote
Old 08-13-2006, 05:29 PM   #3
Fusion Brain Creator
2k1Toaster's Avatar
Or just get another powered hub. USB can only provide 500mA total.
Old 08-14-2006, 01:05 AM   #4
linkyone's Avatar
binary - yea thats the same one i was looking at. i tried building one out of some ICs (7805 5 volt regulators) but they just got hot. ill order one today
2K1Toaster - Do you think that would work when the DVD-Rom drive needs 2.5 Amps to spin up?
Old 08-14-2006, 01:39 AM   #5
2k1Toaster's Avatar
What the hell kind of innefficient drive is that?! Laptop or Desktop drive?
Old 08-14-2006, 02:31 AM   #6
linkyone's Avatar
Its a Lacie laptop DVD-DL R/RW in an external usb 2 case. Yea, i didnt think it would be this power hungry when i bought it, boy was i wrong! I just ordered the 5 volt, 3 Amp regulator, actually i bought 2, one for my hub as well. My car pc (where my 5V originates) and the hub (in the dash) are about 20 ft apart (wire length) so i think i am dropping some power across that kind of length. Ill install these regulators and see if anything improves.
Need help with Network DVD rom access inniss777 General Hardware Discussion 5 07-19-2006 06:58 AM
WTB - Slim DVD ROM drive Zebelkhan Classified Archive 4 04-20-2006 01:04 PM
wierd, slim dvd -> USB adaper MUST use ps/2 port for power... mattress General Hardware Discussion 6 04-05-2005 06:15 PM
Curious DVD power problem... MC_Stoo Power Supplies 4 03-30-2005 05:27 PM
Tview power on issue neon_eddy LCD/Display 8 01-10-2005 10:49 AM
