The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 09-08-2006, 09:57 PM   #46
jschrauwen's CarPC Specs
jschrauwen's Avatar
Vehicle: 90 RHD JDM 300ZX TT 2+2 5sp,92 MX3 GS-ZE, '00 Audi A4 2.8 Quattro, Ducati TT2 Replica
My Photos: (0)
Quote: Originally Posted by thanatos106 View Post
This is what I did with mine:
Thanatos.
Where's the eject select?
Waiting on CT650 for +19 months to install my first CarPC 15/7/08
jschrauwen is offline   Reply With Quote
Sponsored Links
Old 09-08-2006, 11:24 PM   #47
Para Laura
thanatos106's CarPC Specs
thanatos106's Avatar
Vehicle: Xterra SE supercharged
My Photos: (0)
Is done by software my friend
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 09-10-2006, 11:46 AM   #48
jschrauwen's Avatar
My Photos: (0)
Thanatos.
Hey thanks for that - I kind of figured that. After seeing your glovebox set-up it's given me the same idea as well since your center console and glovebox have a lot of similarities to mine.
http://www.mp3car.com/vbulletin/show...highlight=mx-3
Thanks again.
Old 10-11-2006, 11:36 PM   #49
My Photos: (0)
I hope it's not too late to ask.
I bought the panasonic slim drive slot load CD/DVD drive with usb enclosure about a year ago.
http://us.st11.yimg.com/us.st.yimg.c..._1915_11866248
I only played with it right after I installed it that time. Until recently, I tried to use it. I found the drive no longer working. I found there is USB error in Device manager. I plug and unplug the USB, the computer responds (New hardware found), but it just doesn't show the drive in window explorer.
It's been so long, I forgot if the drive came with any drivers.
Do you guys remember?
510SX is offline   Reply With Quote
Old 10-11-2006, 11:46 PM   #50
W3bMa5t3r's CarPC Specs
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
Vehicle: 2004 4Runner SR5 V8 4WD
My Photos: (15)
Typically the computer shouldn't need drivers for a cdrom drive, even if plugged in via usb. Are you positive it's getting enough power? I had to use a powered hub and power the slim cdrom for mine to work properly.
W3bMa5t3r is offline   Reply With Quote
Sponsored Links
Old 10-12-2006, 12:24 AM   #51
My Photos: (0)
I have a 5v 6A regulator to feed the CD drive and the powered USB hub.
Also, I've tried bypassing the usb hub plugging into my laptop directly.
Do you recall if the drive or the enclosure came with any CDs?
Old 10-12-2006, 12:30 AM   #52
W3bMa5t3r's Avatar
My Photos: (15)
hmm power should be good then...
well my slim cdrom was salvaged from a laptop, but it's never required any drivers. detected immediately when plugged in. so no... no cds
Old 10-23-2006, 07:52 PM   #53
jschrauwen's Avatar
My Photos: (0)
Mine didn't need any drivers either. Working well on the bench with the barrel plug power cord connected to the 5V rail of my PSU. The usb is routed through a powered usb hub.
Old 08-06-2007, 03:15 PM   #54
volfiregon's Avatar
My Photos: (0)
Quote: Originally Posted by jschrauwen View Post
OK, I'm sold on the case idea. This is really going to not impress people but I guess there may be a missuse in terminology. The slim slot drive I'm intending to use is the the non tray type.
I'm not even sure if there's even a proper term to differentiate this tray type;
I've already seen those cases on ebay that thanatos106 linked to, which are the same as the first pic - TRAY TYPE. Perhaps this is a mute question, but aren't these case dimensions different between the tray and non-tray type slot load units? If appears that they LOOK the same size but hate to order and find out there are subtle differences that set them apart. I imagine it should be a straight forward answer to these questions.
I'll re-iterate, are those slot load cases shown in thanatos106's link good for only the tray type as indicated in the ebay pics or are they the same size/fit/match for the non tray type as as shown in the pic above? Thanks,
John
This is exactly the same one I bought in the picture. I've been reading a lot about similar threads on how to connect a Slim drive DVD burner and I think this is one of the best thread where all of you gave a different opinion.
Thanks a Lot.
volfiregon is offline   Reply With Quote
Old 08-07-2007, 09:16 PM   #55
FLAC is for flacid
parksgm's CarPC Specs
parksgm's Avatar
Vehicle: Mustang GT
My Photos: (4)
I believe the dimensions are the same...I ordered an external case for a slimline CD drive, and my slot-load drive fit perfectly.
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Old 08-08-2007, 05:01 AM   #56
jschrauwen's Avatar
My Photos: (0)
Short Update :)
My unit is still working fine although I did have a few snags for a while. The constant plugging in and removing of different USB devices (including external hard drives apparently confused things and I just ended up uninstalling all of the USB drivers and then rebooting. All of the necessary drivers came back and my slotload was good to go. I don't require the USB to go through a powered USB hub either but then again, as I mentioned earlier, the 5V barrel plug is connected directly to my 5V rail.
Sponsored Links
vB code is On
Trackbacks are Off
FS: M10000, Morex 3688, 40GB 2.5", SLOT Load dvd/cdrw, 512mb ram JuMpMaN6235 Classified Archive 29 07-13-2006 10:53 AM
Hacking Head Unit CD with CD/DVD-ROM slot load drive? pktloss Hardware Development 7 03-25-2006 09:42 PM
WTB: slot load dvd/cd slimline, pc2700 Haystack Classified Archive 0 02-22-2006 08:02 AM
f/s panasonic slot load dvd/cd drive! MONEYTLKS Classified Archive 19 09-21-2005 03:41 PM
wtb: slot load dvd rom full size EsKALad Classified Archive 0 08-29-2005 11:08 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
