The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 09-05-2006, 02:32 AM   #1
mp31023's Avatar
My Photos: (0)
Dual touch screen
Is it possible to use 2 touch screen monitors at the same time. I have tried this but the touch screen only works on the primary screen. Any ideas?
mp31023 is offline   Reply With Quote
Sponsored Links
Old 09-05-2006, 10:15 AM   #2
FC3S's Avatar
My Photos: (0)
sorry, i cant find any links right now (either im stupid, or my search terms dont pull anything)
but this has been discussed many times before, if your smarter than me (which probably isnt hard, lol) try searching for touch screen or something similar to that
FC3S is offline   Reply With Quote
Old 09-05-2006, 12:04 PM   #3
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
What you want is 2 touch screens (2 mouse) and 2 pointer. Current/default windows only allows 1 pointing devices.
Check out CPNMouse http://cpnmouse.sourceforge.net/
I haven't use it yet, but looking at it. I want to use 2 mouse and a TS to control front screen and headrest screen too.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 09-05-2006, 12:23 PM   #4
Injector's CarPC Specs
My Photos: (2)
i'm sure there is a way to do it, on my laptop i use a wireless mouse because sometime the touchpad ****es me off, and the both work, i can use both the mouse and touchpad
Injector is offline   Reply With Quote
Old 09-05-2006, 01:08 PM   #5
MySQL Error
Scouse Monkey's Avatar
Vehicle: Pug 306 & BMW 325i
My Photos: (0)
Bloody hell, i have been checking in on this thread all day waiting for someone to give the guy the right info.
YES SURE YOU CAN DO IT.
You can have multiple touch controllers set up in the driver software. Then when you map and calibrate each one.
here is the snippet from the help file:
Quote:
[Monitors]
There are three functions in this property page, and they are Multiple Monitors, Split Monitor and One Point Calibration. Such a trendy and yet innovated design provides viewing pleasures, viewing flexibility and convenience to the users.
<Multiple Monitors>
To configure the mapping relationship between the monitors and the touch panels, select the monitor page as below.
Set the check box (Use Multiple Monitors) to enable multiple monitors mapping. Uncheck this box will disable multiple-monitor configuration, and all of the touch panel controllers will be mapped to the primary monitor. The gray shadow area is the monitor mapped the selected controller/panel. The button [Mapping] is used to find the mapping relationships between the monitors and touch panel controllers. Press the [Mapping], the software will guide the users to touch the corresponding monitor to obtain the mapping relationship.
After finish monitor mapping, Press [Apply] to apply the mappingrelation.
<Split Monitors>
To use the Split Monitor function, users need to select which controller you want to launch this function, then check the Multiple Monitors box and Split Monitor at the same time as showing as the follow picture. Press the [Split Setting] button to set up the activate area.
It shows the current resolution of display and users can set up the activate area by inputting the value by yourself or use the default button [Upper Half], [Left Half] or [Quarter]. The default value of panel resolution should be full screen as Left: 0 , Right: 0, Top: 0 and Bottom: 0.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 09-05-2006, 07:05 PM   #6
mp31023's Avatar
My Photos: (0)
Thanks Monkey!!!! I will get it a try tonight.
Old 09-06-2006, 09:28 AM   #7
linkyone's Avatar
Vehicle: 2000 Chrysler Sebring
My Photos: (2)
I think what he is looking for is two completely different pointers in his car. Simultaneous control over the screen in the front and the one in the back using only one computer. One user can control the GPS as the other changes a song and the mice dont go hay-wire! Pretty cool idea if you ask me!
linkyone is offline   Reply With Quote
Old 09-06-2006, 03:49 PM   #8
Jahntassa's CarPC Specs
Jahntassa's Avatar
Vehicle: 2003 Pontiac Vibe GT
My Photos: (0)
I would think the only time you would run into problems is when you're trying to press on BOTH screens at once. No way for the pointer to be in two places at once, right?
Otherwise, the driver software should feed the OS an absolute position on the screen, depending on where your finger is. If it's on the extended desktop, bam! There's the pointer..
Jahntassa is offline   Reply With Quote
Old 09-06-2006, 05:11 PM   #9
Vehicle: 2006/Nissan/Altima
My Photos: (0)
There is a touchscreen controller called "Gunze"....drivers for this controller have built-in setup/configuration if you have dual touchscreens on dual monitor.
i am personally using this and never find any problem.
more info can be found here:
http://www.gunzeusa.com
azhar97 is offline   Reply With Quote
Old 09-12-2006, 11:18 AM   #10
mp31023's Avatar
My Photos: (0)
Monkey,
Worked like a charm thanx!!!!!!!
Sponsored Links
Old 09-14-2006, 06:10 PM   #11
tn6478's Avatar
My Photos: (0)
so where can i get the driver. Will this work on my current touchscreen I have 4 install in my car
tn6478 is offline   Reply With Quote
Old 09-14-2006, 06:45 PM   #12
My Photos: (0)
Drivers are available on there websites...for these drivers to work, you have to use there controller....
you can use your touchscreen panel with this controller if your touchscreen panel is 4 or 8 wires.
these controllers support 4 or 8 wires touchscreen panels. have a look at the picture, just two connectors, one for USB and another for touchpane (4/8 wire)
Old 09-17-2006, 05:08 PM   #13
mp31023's Avatar
My Photos: (0)
Scouse,
Is there a way to have the screens boot with 2 different AP. For example 1 with the front end player and the other with Navigation.
Old 09-27-2006, 01:50 AM   #14
My Photos: (0)
I think you can use UltraMon for that.
Google it.
Un_discovered is offline   Reply With Quote
Old 10-06-2006, 08:29 AM   #15
My Photos: (0)
As Monkey said:
[quote]YES SURE YOU CAN DO IT.
You can have multiple touch controllers set up in the driver software. Then when you map and calibrate each one.[quote]
Here are some pics to go with what Monkey has posted from the help file.
dashboard is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
In-dash touch screen vs touch screen overlay vxcarpc LCD/Display 6 02-20-2008 01:02 PM
Lilliput 8" touch screen backwards - FC4 DJBigShow Linux 9 08-04-2006 02:43 PM
Lilliput touch screen Help..please avn128 LCD/Display 2 08-03-2006 04:20 PM
Need touch screen advice sciff5 LCD/Display 0 05-29-2005 09:58 PM
task switching? touch screen only chuckctv Software & Software Development 5 09-04-2004 09:50 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
