The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Thread Tools Display Modes
Old 02-03-2008, 08:00 AM   #106
bes51659's CarPC Specs
bes51659's Avatar
Vehicle: 01/BMW/325ti
My Photos: (6)
Quote: Originally Posted by Naesstrom View Post
Now I'm having problems how to connect it to my carpc... I can run it directly to my screen and just switch to the AV1 to see it but I want to be able to record it... so I was thinking of getting one of these:
http://www.hauppauge.com/pages/produ...impactvcb.html
What happened Naesstrom? Did you get a framegrabber?
I am curious about the cpu-load. Does it really work?! In my carpc (MII12000) I cannot even get 100% smooth operation out of powerDVD. With an ordenary webcam operation is c*rp, and then I cannot do anything else at the same time.
I've designed a pcb to switch in AV with steering wheel buttons instead. (no recording...)
BTW. If someone's got an idee of where to install my camera. I'd prefer to make the hole where there is acctually room behind :-)
bes51659 is offline   Reply With Quote
Sponsored Links
Old 02-08-2008, 08:27 PM   #107
vull's Avatar
My Photos: (0)
you could stick it into the bumper.
PS: please replace the ugly lights :| - believe me or not, but you've got a higher risk getting into an accident if you upset the BMW fairy
any new cameras out yet?
is this any good?:
http://linitx.com/viewproduct.php?prodid=10951
vull is offline   Reply With Quote
Old 02-09-2008, 05:27 AM   #108
bes51659's Avatar
My Photos: (6)
Which do you prefer
Since I have not tried the camera on the car yet (thanks for your input) I do not dare recommend one, but I use this:
That perticular model is not available anymore, I think that its been impreved because there are other that look the same around.
Night vision NTSC Camera, 0 Lux, 110 degrees. Mirrored image
BTW. Fairy or not. I want the camera beause once I reversed into a bicycle with a 10-year-old on. He came from the side at the same time as I started to move. No speed, but it knocked him off balance. No harm done, but it was scary. Aspecially since I only heard him and then stopped. I still could not see him. He was behind below waisteline...
Old 02-09-2008, 05:57 AM   #109
vull's Avatar
My Photos: (0)
well, there you go :P
these look nice, as they are not ugly lexus style:
Highslide JS
more oem look
where did you buy the camera from? any sample-images?
Old 02-09-2008, 06:54 AM   #110
bes51659's Avatar
My Photos: (6)
I bought it on ebay. In fact I bought two so you can get the other if you want. Send private mail.
I just made a search on ebay (rear view camera night vision) and found this
It looks exactly the same as mine.
But as I said. I've tried it in my flat but not on my car. It has a handly mounting feature. It can be tiped and mounted at a (small) angle
Sponsored Links
Old 02-17-2008, 10:57 PM   #111
My Photos: (0)
Quote: Originally Posted by shotgunefx View Post
I took a different tact and went inside. The *** of my car is high and there are a lot of blindspots, so I wanted it closer to center to cover the side rear quarters of view. It's mounted to a mini-servo so it can sweep left and right and mounted far enough back so no one will crack their skull on it in an accident, though I'm going to make a little sexy enclosure for it at some point.
2.5mb Divx here
The pylons show how much area I gained by putting it inside.
When the software is all done, the servo will allow me about ~ 300 degrees of view.
Nice camera setup you have there. Can we see a close-up of the camera mounter, etc. I'm really digging that placement.
Regards..
CarPC: Mini-MAC Coming Soon!
FS:: Lexus ES350: Complete Rear Seats
Creative0Mind is offline   Reply With Quote
Old 02-18-2008, 12:05 AM   #112
vull's Avatar
My Photos: (0)
i think it's not so good place because half of the screen is filled with your own car
Old 06-08-2008, 07:09 PM   #113
bes51659's Avatar
My Photos: (6)
Highslide JS
Soo enough there will be links to youtubes at http://web.comhem.se/bengt-olof.swing/youtubes.htm
Old 06-09-2008, 03:41 AM   #114
vull's Avatar
My Photos: (0)
rear view option rocks! do you need the ibus thingie to be able to see the rear view camera after shifting to reverse?
Old 06-09-2008, 04:39 AM   #115
bes51659's Avatar
My Photos: (6)
It does doesn't it :-)
My IBus thingie will pickup IBus message "going in/out of reverse" as well as "someone is swithing sideview mirror selector switch" etc and generate the AV enable input on my LCD panel.
So no, you do not need it. You can do that your self in hardware and connect to reverse light. But you cannot use any original buttons then like I do on the youtube.
Note. It is not the original BMW LCD in the Bordmonitor. It is a CID 650
The IBus thingie
Old 06-09-2008, 11:20 AM   #116
vull's Avatar
My Photos: (0)
cool.
but i don't really need to use the window switch option.. where do you connect the reverse light wire? to camera's power cable? and then it should automatically come up on the screen if the camera gets the power? i've got xenarc 700tsv monitor.
btw, you monitor looks kick *** in the stock interior! (black knobs and the lines - did you re-make the panel?)
Old 06-09-2008, 12:15 PM   #117
bes51659's Avatar
My Photos: (6)
Thanks!
(I took the standard BMW navigation monitor and fitted a CID 650 inside and a DVD. Very simple and straight forward :-))
I have the camera powered on at all times. I mean when USB has power. This to speed it up as it needs warming up. And in the winter it might keep the snow off it :-)
I do not know the interface of Xenarc nor if your rear light is active 12V or GND. You have to check that out in your car and I suggest you use a relay. I would not connect it directly without checking that the Zenarc can handle the noisy car supply. Maybe it does.
My CID 650 has two inputs. "Ignition" and "AV2 on". Both active high. When I want to have PC only "ignition" is high and when I have rearviewcamera I have both high.
Old 06-09-2008, 02:17 PM   #118
BLACKonBLACK98's CarPC Specs
My Photos: (0)
what a coincidence... i was just looking at cameras. any of you gurus want to take a look at these specs?
Image Sensor - 1/3" SHARP CCD Sensor Horizontal Resolution 420 TV Lines
Effective Pixels - 512(H) x 492(V) Minimum Illumination 0 LUX (w/IR LEDs on) / F:2.0
Sensing Area - 4.9mm x 3.7mm
Sync System - Internal
Horizontal Sync Frequency - 15,734 KHz
Vertical Sync Frequency - 60 Hz
Scanning System - 1/2 Interlace
Gamma Consumption - 0.45
Video Out Signal - 1.0 Vp-p 75 ohm
Power Supply - DC 12V
AGC - Auto
S/N Ratio - Better than 48dB
Electronic Shutter - 1/60 - 1/100,000 second
Weight - Approx 50 g
Dimension - Φ 31 mm x 48.5 mm
Built-in Lens - f=2.8mm / F=2.0
Cable Output - Standard RCA Video (Yellow) & DC (Red) Jack
BLC - Auto
White Balance - Auto
TV System - NTSC
Operating Temperature - -4°F - 158°F (-20°C - 70°C) / RH 95% Max
Storage Temperature - -40°F - 176°F (-40°C - 80°C) / RH 95% Max
Current Consumption - Max 200mA
Lens Angel - Wide View Angel 120°
BLACKonBLACK98 is online now   Reply With Quote
Old 06-09-2008, 04:32 PM   #119
bes51659's Avatar
My Photos: (6)
This one?
It looks just like mine with the following exceptions:
- is the picture mirrored? It need to be.
- mine is 110 degrees and if I recall the resolution is less.
Highslide JS
This is a very good picture at night.
My camera feels a bit lowres, and a bit easy to blind. If you are happy with yours I think I will replace mine. It seems like your is the never improved model.
The brackets are there so that you can mount the camera at an angle. You do not want to do that. It will make the lens stand out to much, and you will have to mount it on a plastic panel or it will damage the steel. The brackets are also difficult to set straight to get a stable and tight fix ont the nut. I am trying to find some more rubber washers for a tidier (rust proof) assembly.
The camera is a bit difficult to get horizontal.
Old 06-09-2008, 05:27 PM   #120
My Photos: (0)
this one
i thought they were all the same and this one was just overpriced but looking at the specs there are some differences.
i would think rubber o rings would do the job for mounting.
Sponsored Links
vB code is On
Trackbacks are Off
Can any camera work for rearview camera? polo6979 StreetDeck 5 09-27-2006 09:16 AM
Wiring help for Rearview Camera maxxell Newbie 9 08-05-2006 02:23 AM
rearview camera biomekanik Newbie 5 06-09-2005 12:23 PM
anyone used this rearview camera 6.5-Inch Tft Lcd Rearview Mirror Monitor RV18-65np raaaaaa LCD/Display 0 03-16-2005 01:41 AM
Is non-IR rearview camera visible at night with reverse lights on? hd54321 General Hardware Discussion 6 07-23-2004 03:21 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
