Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Notices
Old 03-01-2007, 08:12 PM   #91
RickS's Avatar
Awesome! It works great! I just spent 20 minutes converting/creating a VB.NET version of the demo but I didn't save it when I shut down the compiler so I lost the work. I'll post that when I redo it.
RickS is offline   Reply With Quote
Old 03-01-2007, 08:53 PM   #92
Great, let me know if you run into any problems. I take it you found the class fairly self explanatory? Or did you need to rely on the documentation much? If you would like, you can send me the VB.Net demo project and I will include it in the zip file.
armstrom is offline   Reply With Quote
Old 03-01-2007, 09:50 PM   #93
Not sure how I missed this thread until now, but this thing is sweet! Mine's ordered and on its way.
Too bad it doesn't have X and Y slide motion similar in nature to the Space Navigator or even a simplified version like the Logitech Nulooq. If someone does succeed in coming up with a solution for that shortcoming, and a "universal" interface is designed, sales for this thing should take off like a rocket.
"It's a blessing . . . and a curse."
Siezmik is offline   Reply With Quote
Old 03-02-2007, 08:41 AM   #94
RickS's Avatar
The class is extremely self explanatory and the documentation is excellent. I didn't have to refer to the docs at all, just glanced through it quickly before I looked at the code. I'll let you know if I run into any problems or have any other questions...thanks for making this!
Old 03-02-2007, 09:45 AM   #95
Glad to hear it's working out for you. What application are you using it for?
Zip-Lock is offline   Reply With Quote
Old 03-02-2007, 03:40 PM   #96
RickS's Avatar
I wrote the FE I'm using and I'm planning to tie it into that for scrolling through lists of songs, playlists, POIs, radio stations, etc and controlling volume. I'm planning to post some of the applications out here when I get them done...
Old 03-02-2007, 09:40 PM   #97
RickS's Avatar
VB version of Demo
Here's a VB.NET version of the demo using armstrom's managed DLL in case anyone else wants it.
Old 03-07-2007, 05:11 AM   #98
terryking's Avatar
Water PROOF! version of this type Encoder???
I'm very interested in this type encoder, because I need an input device that can handle relatively simple inputs, similar to a touch screen, that will work well while driving in bumpy conditions. The bumpy conditions will be in a boat underway. The other obvious requirement is that the device must be able to be salt-water-proofed...
I think that could be done, with the single-shaft property of this device, and careful enclosure and cabling.
I'm sure there will be outdoor applications for this in construction equipment etc.
Anyone seen info on Waterproofing???
terryking is offline   Reply With Quote
Old 03-19-2007, 01:23 PM   #99
I read through this and have a question:
I understand how the device works, I guess. But is it possible two code the driver in some way that the "dial" seen as a scroll wheel and the "press" is seen as a left mouse click? I know with Centrafuse, the scroll wheel is automatically integrated into menus and the left mouse click is just a select. Then as long as the unit could work continously as a "detent" pattern. Perhaps even click and hold to change volume?
pwntbypat is offline   Reply With Quote
Old 03-19-2007, 08:34 PM   #100
Keep in mind that the whole point of the device is to allow it to be programmable. If the driver simply exposed it as a mouse wheel with the button simulating a click, then it wouldn't really be worth the price, in my opinion. But, if you have already bought one I can write a little app that will use the encoder to do what you want. Does anyone else see value in something like this?
-Matt
Old 03-20-2007, 08:14 AM   #101
If you could make it so that the detents are adjustable for "size" and "feel", then I think a little interface like that might be worthwhile. It might draw in more people who don't have the programming skills to write their own interface.
Old 03-20-2007, 04:37 PM   #102
ok. I can do that. I'll start on it when I get home and should have something by later tonight.
One thing to keep in mind is that this software will not likely work on Vista. One of the new security features in Vista prevents user processes from broadcasting system-wide mouse events. To solve this in Vista I would have to write a device driver and I really don't feel like messing with the DDK tonight. I'll keep everyone posted.
-Matt
Old 03-20-2007, 08:13 PM   #103
Ok, slight delay. I have a problem with my development machine. Maybe tomorrow.
Old 03-22-2007, 12:38 AM   #104
Sounds good. I'm interested to see what you come up with.
Old 03-24-2007, 08:28 AM   #105
Would it be possible to get this to work on a Mac? I can program, but I don't know how to write usb drivers.
mustanglou is offline   Reply With Quote
MMI style rotary encoder install - details Tony G Input Devices 59 06-01-2008 02:41 PM
Jobs - Mp3Car.com Retail Product Specialist Fiberoptic Announcements 0 08-11-2006 01:33 PM
Route66 remove its Mac/PC product MacMobile MacCar 4 04-05-2006 09:46 AM
SMK Force Feedback Touch Panel e_z_street General Hardware Discussion 0 03-11-2004 07:01 PM
