Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Notices
Old 03-03-2007, 04:30 PM   #1
mouse
I wont to find a Lcd screen that works as a mouse to a bigger 15in screen for my truck.
miller2000 is offline   Reply With Quote
Old 03-03-2007, 04:45 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
You mean a touchscreen larger than 15"? They make 17" resistive TS's, and above that you are looking at digitizer touchscreens, or the IR screens.
Old 03-03-2007, 04:54 PM   #3
i have a 15n touch screen but i also wont a say 7 in screen i can use as the mouse so i dont have to move to get to the bigger screen, what would the name of that type of screen be called?
Old 03-03-2007, 04:56 PM   #4
2k1Toaster's Avatar
I have no idea what you are saying.
If English is not your first language, write in your native language. I can help you in French if needed. Others German, Spanish, Japanese/Chinese.
Old 03-03-2007, 04:59 PM   #5
Mouse simulator is there any thing called (Mouse simulator)?
Old 03-03-2007, 05:04 PM   #6
2k1Toaster's Avatar
I still have no idea what you are trying to say.
Any screen that acts like a mouse is called a touchscreen. If you want to use the touchscreen control without a full LCD too, it is called a touchpad. Or you can get an overlay.
Windows only sees 1 mouse by default. So you can hook up 1 million Touchscreens and it will still only have 1 mouse. So if you touch any of the screens on the top right, the mouse will go to the top right. Simple as that.
Old 03-03-2007, 05:07 PM   #7
what i wont is a 15in touch screen in the dash and a 7 in mouse screen n the arm rest so when i am driving i dont have to move to get to the 15 in screen. hope this helps a little better
Old 03-03-2007, 05:10 PM   #8
I understand what he's saying
One 15" screen (touchscreen or non, whatever he chooses)
one 7" touchscreen
Both display the same thing.
This should be fairly easy to do, just get a video card with two VGA outputs that is capable of cloning, send the same output to both screens. Just make sure to find a resolution and frequency both screens can handle. There are some programs that can give u more precise control over monitor settings, but i can't think of the names right now.
Good luck!
sdat1333 is offline   Reply With Quote
Old 03-03-2007, 05:14 PM   #9
i think you have it i wont to see the mouse arrow move in the 15in and not have to look at the 7in to. if what you say is true thank for the advice.
Old 03-03-2007, 05:18 PM   #10
shouldnt be too hard to keep the mouse pointer visibly and set it so that moving ur finger moves the mouse (rather than clicking)
Let's just wait on someone more experienced to confirm though
Old 03-03-2007, 05:19 PM   #11
i will keep my eye on the thread and thanks again
Old 03-03-2007, 05:22 PM   #12
2k1Toaster's Avatar
Like I said, you can have as many mice inputs as you want, but it will only work as 1 mouse. So connect it and you are good to go. Seems like overkill to have a full other screen just to push the screen. Sort of defeats the purpose of even having a TS on your 15".
Old 03-03-2007, 05:25 PM   #13
i have a 1985 ford f150 and the dash is not as close as a car
Old 03-03-2007, 05:28 PM   #14
2k1Toaster's Avatar
You can get touchpads (like laptops) so you can use the touchpad really close, and then the display on the 15". It would be a lot cheaper.
Old 03-03-2007, 05:32 PM   #15
so the touch pad is on a laptop and where can i get one and are thay easy to hook up?
GPS Mouse installed as Mouse?? vxcarpc GPS 9 06-24-2005 06:24 PM
PS2 3 Button(Rotary Wheel) Mouse Properties? nFiniteTuning Input Devices 4 03-12-2005 10:43 PM
Gonna throw my Deluo GPS mouse in the river! tom2112 GPS 4 02-15-2005 08:13 AM
Smallest Touch PAd Mouse... or Shuttle Mouse QUESTION!!! Boozshey General Hardware Discussion 1 01-23-2005 03:38 AM
usb mouse stops working corsamel General Hardware Discussion 3 10-18-2003 06:53 AM
