Go Back   MP3Car.com > Mp3Car Technical > Input Devices
Notices
Old 03-03-2007, 04:51 PM   #1
Unhappy touch screen
i have a gvision 15 in touch screen the back light was not working so i sent it back to the manufactur but I can not get the touch screen to work i down loaded the drivers from the web sit and it still wont work. i bouht the unit from ebay and as far as i can tell it is a touch. any help?
miller2000 is offline   Reply With Quote
Advertisement Sponsored links
Old 03-03-2007, 04:57 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
Do not cross post.
And when you hook it up, do you plug in VGA and USB/Serial/parallel?
Old 03-03-2007, 05:00 PM   #3
it's a vga and this is unrelated.
Old 03-03-2007, 05:05 PM   #4
2k1Toaster's Avatar
Ok, the screen is VGA, but is there any other wire!?
VGA only transmits video data. if it is Touchscreen, then it needs to use another COM port. Not unrelated.
Old 03-03-2007, 05:11 PM   #5
By post you ment wires on the gvision not not the two post i have going on now.yes there is two wires coming out of the screen and thay both have differant post one is a male and the other is female so i cant get them crossed. if i down loaded the drivers is the only explanation tht it is not a touch or is gvision just a bad screen?
Old 03-03-2007, 05:14 PM   #6
2k1Toaster's Avatar
One is male and one is female but male and female what? VGA, USB, Serial, Elephants?
Old 03-03-2007, 05:17 PM   #7
vga and serial do you wont to know what one is male?
Old 03-03-2007, 05:20 PM   #8
2k1Toaster's Avatar
No which is male doesn't matter. But informative questions are the only way to get an informative answer.
Since it is serial, it is very old. Have you tried TouchKit's drivers? You need to match the correct baud rate and everything to get it to work correctly. Have you properly configured it?
Old 03-03-2007, 05:27 PM   #9
I went on the gvision web site and down loaded the drivers thay had but from what you say i could of downed the new ones and not the older verson
is usb the new kind?
Old 03-03-2007, 05:30 PM   #10
2k1Toaster's Avatar
Yes USB is the new kind. They don't even make serial touschscreens anymore.
Try these: http://www.cartft.com/support/driver...4.3.7.3215.zip
Old 03-03-2007, 05:33 PM   #11
so i guess im going to be in the market for a new screen. any advice?
Old 03-03-2007, 05:38 PM   #12
2k1Toaster's Avatar
No serial screens still work, they are just not as supported.
Old 03-03-2007, 05:39 PM   #13
i will try the site you have.
In-dash touch screen vs touch screen overlay vxcarpc LCD/Display 7 09-22-2008 11:52 PM
Lilliput 8" touch screen backwards - FC4 DJBigShow Linux 9 08-04-2006 03:43 PM
Lilliput touch screen Help..please avn128 LCD/Display 2 08-03-2006 05:20 PM
Need touch screen advice sciff5 LCD/Display 0 05-29-2005 10:58 PM
task switching? touch screen only chuckctv Software & Software Development 5 09-04-2004 10:50 PM
