Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc.
Old 04-28-2007, 03:05 PM   #1
"Speaker of the Truth"
veedubya's Avatar
veedubya is on a distinguished road
Laptop use in car
I have been toying around with the idea of using a laptop in the car. Is there a way to have laptop plugged into 12V via cog. adaptor but to run off the laptop battery until the battery hit a certain % then kick over to the AC.
Laptop plugged in battery at 100%-11% = running off laptop battery.
Laptop plugged in battery reaches 10% = running off AC plugged in.
I briefly searched for an Adv. Power Management Tool but found nothing
thanks
veedubya
"Geeks dont need girlfriends we can ping ourselves"
Sony Vaio 2Ghz 40G HHD, Routis 2004 GPS, 7" VGA TS Lilliput, BackUp Camera running RoadRunner with Simplistique Skin.
veedubya is offline   Reply With Quote
Old 04-28-2007, 03:22 PM   #2
gadu^ is on a distinguished road
why not simply use a DC-DC converter and have it plugged into the 12V cig?
Me, myself and my car
gadu^ is offline   Reply With Quote
Old 04-28-2007, 03:34 PM   #3
veedubya's Avatar
maybe the confusion was i referred to AC power in my last line.
clearer scenario
Laptop plugged in to cig. adaptor and battery at 100%-11% = runs off laptop battery while still plugged in
Laptop plugged in to cig. adaptor and battery reaches 10% = runs off cig. adaptor
Old 04-28-2007, 03:46 PM   #4
Nerd2's Avatar
Nerd2 is an unknown quantity at this point
Why would you want this?
I would think it may be possible to do in VB..... possibly.....
EDIT: Actually "AC" may be directly linked to battery, you'd have to have some sort of relay?
Nerd2 is offline   Reply With Quote
Old 04-28-2007, 04:13 PM   #5
lbridges is an unknown quantity at this point
It would help if the scenario for use was explained. For example, if all you wanted to do was have a way to sit in the car and run the laptop for an hour or so without draining the car's battery, then just insert a switch inline with the power cord to the cigarette lighter.
lbridges is offline   Reply With Quote
Old 04-28-2007, 07:33 PM   #6
veedubya's Avatar
Laptop plugged in to cig. adaptor and battery reaches 10% = runs off cig. adapter
Not sure a better way to explain.
If laptop battery is bewteen 100% - 11% it will run off the laptop battery
If it drops below 10% then I would like it to run off the cig. adapter.
As it is i have a 2nd battery that will be used for laptop and possibly 7" Lilliput.
Just trying to think of a way to use laptop battery to a certian point before switching over to the 2nd car battery
Old 04-28-2007, 07:36 PM   #7
Nerd2's Avatar
Errr, the question we have isn't 'what do you want to do?', it's 'why do you want to do it?'
Old 04-28-2007, 07:57 PM   #8
veedubya's Avatar
does my reason need to be more clearer than this
Old 04-29-2007, 07:47 AM   #9
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
What's wrong with a manual switch? You switch it when the OS warns that your battery is low.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 04-29-2007, 08:00 AM   #10
Also, a laptop can run on a car battery for a looong time...
I don't see any use of this...
Old 04-29-2007, 09:42 AM   #11
Shai-Hulud is on a distinguished road
I'm coming in late on this one but.....
If you constantly run your laptop off the battery discharging it continuously it will prematurely shorten it's life. In a few months you'll notice shorter run times before needing a fresh charge. Depending on the type of computer you have, say a desktop replacement, they aren't necessarily meant to run for significant periods of time on battery.
My suggestion is run your laptop off your car's power using an inverter or dc-dc adapter. Use your laptop's battery when the car isn't running.
Shai-Hulud is offline   Reply With Quote
Old 04-29-2007, 10:11 AM   #12
Registered User
spud42's Avatar
spud42
if you put power into the back of a laptop by what ever means you try, either the manufacturers dc adaptor to a cig socket or via an inverter and laptop psu . it doesnt matter. the laptops power/battery management system will use that power and also charge the laptop battery. in other words it is part of how the laptop is made and unless you modify the power circuits it cant be altered by software alone. the laptop battery wont be used unless external power is removed. you could make a circuit with a relay that is controlled by software and monitors the laptops battery level and then switches to ext power at the point you want . but as stated before the laptop battery isnt going to take a lot of deep discharge cycles ie down to 10% or less too often. i am looking at a dell d620 dual core laptop right now and its battery is 11.1 v and 85 WHrswhich means a capacity of 7600 mA approx. this gives me approx 3 hrs of use. your car battery would probably power the laptop for over 24 hrs straight. then when it gets low you would then have the laptop battery kick in and have 3 hrs to get the main battery recharged.. the laptop battery would act like a UPS.... if your second battery is charged via the car as per normal then you would probably never need the laptop battery. so why do you want to do it the way you said?????
NISSAN 180SX SR20DET 2lt TURBO 5 spd , gigabyte ga5ssm mobo,AMD k6 ii 450 Mhz,128 meg ram,4" sharp lcd,40 gig Hdd. IRMAN WinAmp ,TinyXP.ipaq4700 ,WM 6.1 ,4 Gig CF,TomTom 6,TCPMP edited 23/9/2008
spud42 is offline   Reply With Quote
Old 11-08-2008, 02:41 AM   #13
dmc_rider is an unknown quantity at this point
the question would have been more clear if only it was mentioned whether the laptop is going to run as a carputer or just a way of working during the drive to work. in either case, a DC-DC inverter or a car adapter would suffice, wouldn't it? that way, the laptop battery would provide a backup when the car was off. you could even set the laptop to shut down 2 minutes after turning the ignition off.
dmc_rider is offline   Reply With Quote
hooking up a laptop to car speakers? djomlas Newbie 3 11-24-2006 11:38 PM
VIA and Mini-box Announce First Sub-$300 Car PC Kit Goofus General Hardware Discussion 27 03-13-2006 12:28 PM
