Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc.
Old 07-01-2008, 03:33 PM   #1
cpc6128 is an unknown quantity at this point
VGA out (without BIOS/keyboard)
I've been given an HP NX6110 laptop (with busted screen) that I would like to use for an install. It has VGA out but the BIOS is extremely limited and there is no option to enable it by default. I would prefer not to have to press function-F4 on the keyboard every time the computer is switched on.
Has anyone found another way of enabling VGA output (on this, or any other laptop)?
My first thoughts were,
1) identify the signals sent from the keyboard when function-F4 is pressed (and replicate them when the machine is powered on)
or 2) is there a signal sent to the video part of the motherboard when function-F4 is pressed to switch VGA output on (and if so, can it be identified & artificially induced?)
any ideas?
cpc6128 is offline   Reply With Quote
Old 07-01-2008, 03:41 PM   #2
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
A lot of laptops can do the switch via software. What you could do is get windows loaded up on it, see what the steps are to change the vid over, and have a little startup script do it for you. Or possibly write a script that replicates the function-F4 keypress, but this may or may not work depending on what level of the PC is doing the controlling.
The hardware route will probably be a lot harder to do. One thing you might look into is modifying the bios. Depending on the bios manufacturer, there are a lot of tools out there to help. The other factors that might come into play is if the video bios is separate from the motherboard bios.
Tidder
Opinions pending
Tidder is offline   Reply With Quote
Old 07-02-2008, 05:30 AM   #3
Thanks for your thoughts! A BIOS modification is well beyond my abilities, and I suspect that to add in extra features such as this would mean a complete re-write.
I like your ideas for letting Windows handle the switch though. It's no use for this project (I'm using FreeDOS for near-instantaneous bootup) so I think I will just start over with a mini-ITX board but I shall no doubt get around to using the laptop for a Windows-based project in the future.
Old 08-07-2008, 09:54 PM   #4
Wizzard1 is an unknown quantity at this point
The Fn key is very hard to emulate via software, onscreen keyboards, etc I have found. If there is a utility to do it, though, you can always http://www.autoitscript.com/autoit3/.
Wizzard1 is offline   Reply With Quote
FS - Motorized 7" Widescreen In-Dash VGA LCD Lone07 Classified Archive 8 01-10-2007 05:04 AM
Connect vga touch screen and 2 headrest screens??? duglas MacCar 6 11-08-2006 05:57 PM
Laptop to Factory Nav Screen - VGA Detection Pin tejesh83 LCD/Display 2 06-14-2006 12:54 PM
Allbrite and controller work with RCA but not VGA alti LCD/Display 22 01-05-2005 12:47 PM
Splitting one VGA to 3 LCD and TV output lookinco LCD/Display 2 09-26-2004 05:19 AM
Powered by vBulletin® Version 3.8.2
Content Relevant URLs by vBSEO 3.3.0
