Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc.
Old 09-05-2008, 06:32 PM   #1
dhorst27 is an unknown quantity at this point
Help with laptop carputer
Hi, this will be my first install. I have tried to read many articles, but I'm having difficulty on getting the overall picture. I would like to install a carpc using an old laptop. I will gut the laptop and use the parts in a custom case. What do I need exactly?
Power supply / On-off controller: Is this one unit or several units? Can you suggest what I should use (cheap as possible)? I want DC-DC...no DC-AC-DC conversion.
Touchscreen: Are there cheaper/good units then the lilliput screens? I'm looking for a 7 inch. Can this be connected directly to the motherboard or graphics card so that the pc recognizes it as the primary display? How many cords feed off the touchscreen?
Can somebody help me out...perhaps direct me to an article that gives very concise DIY instructions. THANKS!
dhorst27 is offline   Reply With Quote
Old 09-06-2008, 09:06 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
I will first direct you to two resources where you really should do a lot of reading. The questions you asked are all answered in one of these to locations.
MP3Car FAQ: http://www.mp3car.com/vbulletin/advfaq.php
FAQ Emporium: http://www.mp3car.com/vbulletin/faq-emporium/
You're going to be fabricating a case. What you need is dependent on what you intend to use to fabricate a case. MDF? Plexiglass? Fiberglass? PVC? Sheet metal?
A Carnetix unit is your most likely bet. It all depends on the power requirements of your specific model of laptop. Check the output voltage on the AC power brick, and it should tell you.
You can get cheaper touchscreens, but you're going to take a risk as far as quality and/or reliability.
A touchscreen w/ VGA input will connect to the PC's VGA port, just like any other monitor, which would be the PC's primary display.
Generally three: VGA, USB (for touchscreen) and power/ground.
Nobody can point you to a concise DIY write-up simply because there is none.
Every install is 100% unique with its own challenges and hurdles.
That being said, you can glean a lot from other users' installations. I suggest checking out the Worklog area and the SOYP area to see what others have done, especially with laptop installs. Most users' are happy to answer questions and give advice.
One suggestion that I give to EVERY newbie to this hobby:
PLAN YOUR ENTIRE INSTALLATION BEFORE PURCHASING ANYTHING.
You're going to save yourself money and headaches, I promise.
Welcome to the madness and good luck to you.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-06-2008, 09:25 AM   #3
LinuxRacr's Avatar
LinuxRacr
My old setup was off of a laptop. Check my sig for the link.
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Current build! Here
Completion Progress Bar: [*********99%]
LinuxRacr is offline   Reply With Quote
Old 09-06-2008, 09:55 AM   #4
kwchan's Avatar
Location: Singapore - Smallest country in Southeast Asia
kwchan is an unknown quantity at this point
Is it necessary to get CarNetix for laptop?
I have seen much cheaper car to laptop adapter with selectable output voltage from 15 to 19V. It can plug direct to the cigarette lighter socket
I understand that the regulator circuit probably less solid and the voltage may drop during cranking
however, since laptop has its own battery...the laptop should run fine even if there is interruption to the power
kwchan is offline   Reply With Quote
Old 09-06-2008, 10:20 AM   #5
No, it is not necessary, however a Carnetix unit is a convenient solution.
In addition to the ability to survive cranking (which isn't that big a deal with a laptiop, since it can revert to battery power) it also includes a startup/shutdown controller for those who want that functionality.
Old 09-06-2008, 10:27 AM   #6
Thanks for all the advice. I'm still struggling understanding a couple things. For instance, what would be the difference between the Carnetix CNX P1900 and the M2-ATX? Don't they perform the same functions? Do some of these only provide 1 power output so I won't be able to power both the screen and pc off the same unit?
Another thing, I understand the touch screens have a VGA connector. So I guess this would be connected to the laptop and it would be recognized as a secondary screen. However, since I won't be using the laptop screen, is there a way to connect it as a primary screen directly onto the motherboard?
Old 09-06-2008, 01:40 PM   #7
http://www.mp3car.com/vbulletin/advf...iew&advfaqid=6
The Carnetix provides a single output voltage for a laptop or a miniPC (like the AOpen Pandora or a Mac Mini).
An M2ATX plugs directly into an ATX-compliant motherboard to power it, as well as the other components for the PC (HDD, optical drive, etc.)
The answer to both of those questions is dependent on your laptop make/model.
Old 09-08-2008, 11:09 PM   #8
WarDriver's Avatar
WarDriver is on a distinguished road
Why not just use a 12V adapter made specifically for that laptop? I have had one for my dell and my hp. (not that universal stuff - unless it is like the I-Go)
-WarDriver-
Server Administrator
Outdoor Nut
My DC to AC Inverter Mod
My Laptop Remote Switch
WarDriver is offline   Reply With Quote
Old 09-08-2008, 11:23 PM   #9
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Old 09-09-2008, 06:18 PM   #10
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
What's the best choice for a laptop carputer? skywise Laptops, Netbooks, Tablets, UMPCs, etc. 14 11-02-2007 07:16 PM
Help me power my laptop carputer...AUX line in noise when I use inverter tdawgedogg Laptops, Netbooks, Tablets, UMPCs, etc. 3 07-03-2007 05:57 AM
Laptop Hard Drive in carputer... Powers Newbie 7 05-08-2004 11:37 PM
Need help with install of carputer using a laptop... slimcubby General Hardware Discussion 4 04-27-2004 01:55 PM
