Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc.
Old 10-18-2008, 06:35 PM   #1
raxy is on a distinguished road
Car dashboard Foldable tray for netbooks
Hi,
I'd like to share my experience in building a homemade handle to put my netbook on whenever I cruise in my beloved car.
Excuse me if the look and color of the tray may hurt your eyes, but this is a first run just to validate the concept.
I've shot two videos :
tutorial support pour netbook (eee-pc 901) dans la voiture (logan) on Vimeo
You need to upgrade your Flash Player
and
tutorial (2) support pour netbook (eee-pc 901) dans la voiture (logan) on V
Comments and soundtracks are in french but the images are self explicit for all of us (I hope)
See you there and please give my some feedback on how I could improve it in version 2.
Tks
raxy is offline   Reply With Quote
Old 10-20-2008, 02:25 PM   #2
bump,
don't be shy, post your comments after you've seen the vidz.
Thanks !
Old 10-20-2008, 10:38 PM   #3
thebranded is on a distinguished road
first thing i'd do is paint that tray black or sumthing
design is ok but not pratical to me anyway, all the dash controls are blocked in the folded mode
Do you need the tray that big? maybe cut it so its exactly the size of the eee?
thebranded is offline   Reply With Quote
Old 10-20-2008, 11:05 PM   #4
booksix is an unknown quantity at this point
is this for real??
booksix is offline   Reply With Quote
Old 10-21-2008, 01:35 AM   #5
thanks for comments guys,
regarding the lacking job paint, I agree it would be better looking with some colors less crude than the bare orangish tray. I considerer this run as just a proof of concept and the look of the solution was not a primary concern.
This plastic tray might not be the ideal material for this job in fact.
It could be considered too thin and too large.
I think of using some sort of "molded" base plate just the size of the netbook so that its impact is minimal on the driving process.
This sort of crystal case,
http://cgi.ebay.de/8-9-Crystal-Case-...d=p3286.c0.m14
evenually reinforced with fiber or metal would fit perfectly and its transparency could be used to make it glow int the dark with appropriate led lightening.
Do you think the result would be more appealing while its fundamental function remains fullfilled ?
Old 10-22-2008, 04:05 AM   #6
if you were to use that crystal case, it would be much better.
Only thing is i'd have the case always fixed to the eeepc, and have the hinges connect into the crystal case. so when the eeepc is not inthe car you dont have a "tray" covering the dash.
also i'd have all the USB devices connected to a hub, so you leave everythgnin car and only connect the hub when you get in.
Old 10-22-2008, 12:01 PM   #7
Totally right
power supply cord could be routed along the black hinge, and also just one usb that would go into the dashboard and will output the 4 ports of a, usb2 hub somewhere else on the dash board , between the front seat and/or at the rear for the backseat passengers.
I stil have to find some sort of quick release latch to mate the crystal case to the folding metal hinge which remains bolted to the dashboard...
Any idea boyz n girz ?
Old 10-28-2008, 03:59 AM   #8
supra_161 is an unknown quantity at this point
one tea plz
supra_161 is online now   Reply With Quote
Old 10-30-2008, 06:22 PM   #9
tea will not come, sorry.
the concept is undergoing a redesign. i replace the tray with aluminum rectangular frame made of four thin L-shaped metal pieces. The hinge is also being replaced by something in the same metal as the frame and much wider than the previous black steel hinge.
i'll be back soon with version two of this solution.
the new support frame will be smaller than the base of the 901 and should be almost invisible under the latter.
stay in touch and thanks for reading.
Old 11-11-2008, 01:05 PM   #10
foldable car handle full metal frame
Hi boyz 'n girz ,
here I am again.
I'm back with some new enhancements to my previous solution.
This time, the tray looks much more high tech as it's made of metal (steel + aluminum),
take a look right here right now:
diy netbook handle tutorial for car dashboard, foldable aluminum frame on V
thanks.
Tags
901, carputer, dashboard, eee-pc, netbook
FAQ: Why not Home PC speakers for the car? RedGTiVR6 The FAQ Emporium 22 03-05-2008 04:35 PM
1987 Toyota Camry -- Complete Resurrection Sidewalksalvage Worklogs 96 01-11-2008 04:21 AM
What's your dream car? Aaron Cake Off Topic 172 10-02-2007 08:34 AM
FS - Assorted Car Pc Parts OriginalNick2 Classified Archive 9 06-23-2006 07:41 PM
Car Stereo Installation Video's for Sale johnram Classified Archive 2 09-05-2002 11:27 PM
