Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc.
Old 01-05-2009, 08:42 PM   #1
ado0o's Avatar
ado0o is an unknown quantity at this point
I need help with my Laptop diagram (re-upload the pic)
Heeeeeeeeeeey Guys
am kinda New with the Car-Pc thing
So ... am starting my own Project
and am gonna use an old Laptop
with a 10.4' touch screen
also am gonna add an auto reverse cam ( still dont know if its Usb or AV )
and i have no idea how am i gonna do it hhhhhh
I Just Draw the Car pc Diagram ...
tell me if it missing something
(re-upload the pic)
and any idea will be thankfull
ado0o is offline   Reply With Quote
Old 01-06-2009, 04:51 PM   #2
WuNgUn's Avatar
WuNgUn is on a distinguished road
Is your cam USB?
What frontend will you be using?
WuNgUn is offline   Reply With Quote
Old 01-06-2009, 07:15 PM   #3
ado0o's Avatar
am gonna put an auto reverse cam
and the frontend ...
mmmmm maybe RR
Old 01-06-2009, 09:24 PM   #4
FusionFanatic's Avatar
FusionFanatic is an unknown quantity at this point
there are no fuses in your diagram
FusionFanatic is offline   Reply With Quote
Old 01-07-2009, 07:41 PM   #5
ado0o's Avatar
the regulator is having a bulit in fuse
should i put an external fuse
if so .... tell me where to put them ??
Thnx Dude !!
Old 01-07-2009, 07:44 PM   #6
WuNgUn's Avatar
You should put a fuse at the main battery junction, and probably another one at your regulator and another for the touch screen....
Old 01-07-2009, 10:03 PM   #7
that fuse only protects the regulator itself
should i put an external fuse?
yes, an in-line fuse is required within a few inches of the power source. this is to protect the power wire from staring a fire due to a short circuit or drawing too much current. the fuse cannot exceed the ampacity for whatever wire gauge you use. this site has some good info on wire guage, ampacity, and fuse ratings.
you must put a fuse at the beginning of any power wire, and anytime you reduce wire gauge or split into two or more smaller wires (unless the smaller gauge wire can handle the current that the main power fuse is rated for).
remember, its always ok to downsize a fuse, but NEVER go higher than the wire can handle.
Old 01-09-2009, 12:16 PM   #8
WarDriver's Avatar
WarDriver is on a distinguished road
Does the screen you are using have a feature that automatically switches the video input to the composite input when voltage is applied? If so you are missing the auto part of your automatic reverse camera diagram. Generally you can pull 12v+ off of the reverse lights to accomplish this....but only if you want it to switch over every time you put it in reverse. You could also throw in a toggle between the reverse lights and the screen to disable that feature.
-WarDriver-
Server Administrator
Outdoor Nut
My DC to AC Inverter Mod
My Laptop Remote Switch
WarDriver is offline   Reply With Quote
Old 03-08-2009, 08:41 PM   #9
ado0o's Avatar
Quote: Originally Posted by WarDriver View Post
Does the screen you are using have a feature that automatically switches the video input to the composite input when voltage is applied? .
yeah it is
Planing ..................... 100%
Important Parts ......... 100%
Accessories Parts ......... 80%
Working ..................... 100%
Done!
My Project ( Lot Of Pics )
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 24 06-25-2009 07:31 AM
How can I use a laptop as a carpc? turbocad6 Laptops, Netbooks, Tablets, UMPCs, etc. 0 07-11-2007 01:55 AM
