Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc.
Old 01-29-2009, 04:02 PM   #1
afshinmoshrefi is an unknown quantity at this point
Laptop boot switch
I am new to Carputer world. I am using a laptop in my car as a carputer. This laptop is placed under the passenger seat. I learned the hard way that a big problem in my attempt is how to switch the power.
I've scanned the Internet and this forum for solutions without a definate answer to the problem. Has this problem been solved in an elgent way that I missed?
Solutions :
1) Solder 2 wires to the power switch and place a boot switch in a visible location. This maybe the only solution that I can think possible in my situation. However the issue is that the laptop needs to be modified.
2) Use Wake-On-Ring : This could be an elegant solution. In my case, my laptop modem does not support WOR.
3) Use Wake-On-Lan : This solution may be workable if there was a device that could send the magic packets to the laptop either by pressing a button or by switching the power on. Has anyone heard of such device?
4) Use a mechanical servo from a remote control toy to press the power switch.
Afshin Moshrefi
afshinmoshrefi is offline   Reply With Quote
Old 02-01-2009, 09:00 PM   #2
FusionFanatic's Avatar
FusionFanatic is an unknown quantity at this point
soldering to the power switch is the best and most reliable method to control the laptop power on/off. if you don't want to modify the laptop itself then you may be able to get a docking station with a power button you could mod instead.
instead of a remote mounted power button you could hook up an SSC like this. or even better would be to power the laptop with a Carnetix DC-DC regulator (they have a built-in SSC).
FusionFanatic is offline   Reply With Quote
Old 02-01-2009, 09:42 PM   #3
North of the land of Hey Huns
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
To answer #3: http://www.mp3car.com/vbulletin/1288005-post19.html
malcom2073 is offline   Reply With Quote
Tags
boot, laptop, power, start, switch
remote switch for laptop powerup shawnmiller Power Supplies 1 08-10-2008 08:50 PM
M2 pic chip? can we program custom times? 89ragtopgt Power Supplies 7 01-22-2008 09:24 AM
New OBDII scantool - Beta testers? tmort Engine Management, OBD-II, Engine Diagnostics, etc. 173 01-08-2008 07:44 PM
Should I switch from DC-DC ATX to laptop? dmbrown73 General Hardware Discussion 2 03-05-2002 01:24 PM
