Quote: Originally Posted by
Josho
P4 is a laptop config.
I would use a MicroATX but then it is the physical size of the thing. All the cards would stick up quite high. Would have to use USB cards I guess.
I did however just see a MiniITX board on eBay that had HDMI output and 7.1 sound ect. which I liked. Socket 775.
I was going to mount under the passenger seat. I may still, if my dad could cut the middle support and weld two others in but just out the way, I could do it.
Maybe I'll just go MicroATX. Although I might be able to have or buy my brothers 1.6 Celeron M laptop. 512MB but I'd up it to 1GB. Could also stick a 2GHZ in there if I wanted.
The 1.6Ghz with one gig ram should be ample to smoothly play video without pegging out at 100 processor utilization most of the time.
I find that my single core 1.2ghz laptop, with one gig ram, has 25% enough overhead CPU clock cycles doing so on WindowsXP.
Do any of these laptops that you have, use an Realtek Audio Chipset? If they do, you should be fine with the audio side of things. Realtek's latest driver update has HD audio.
