Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc.
Old 06-17-2009, 10:13 PM   #1
bass29 is an unknown quantity at this point
Thumbs up Broken laptop
Hello Everyone,
I have a question that I need to know if this will work or not. I have a broken Toshiba Laptop (The Screen is cracked) its a p4 with 1gb or ram and a 80g hard drive. Can I remove the screen and just use the rest of it for a car pc in my 2006 Chevy Tahoe or keep it as one piece and that. I want to say money and use that but will get a larger hard drive. But can it be done doing it that way.
bass29 is offline   Reply With Quote
Advertisement Sponsored links
Old 06-17-2009, 10:15 PM   #2
PaulF's Avatar
PaulF is on a distinguished road
If it still works.
My Car (Just the audio install as of now)
http://paulfurtado.com/car/
Worklog:
http://www.mp3car.com/vbulletin/work...-work-log.html
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
PaulF is offline   Reply With Quote
Old 06-18-2009, 09:02 AM   #3
Broken Laptop
It still works matter of fact I use it to connect to my 55 inch screen tv so it still works. I'm getting a new laptop but I do not want this laptop to go to waste.
Old 07-01-2009, 11:30 AM   #4
Broken Laptop
Can anyone give me some input on this ?? All I want to do is remove the broken monitor and use the base of it which holds everything. I'm getting real desperate with this.
Old 07-01-2009, 12:29 PM   #5
CMOS1138 is an unknown quantity at this point
what exactly is your question? lots of people on the forum have used laptops for a carputer, as far as I can tell the only issue is getting it to turn on and off with ignition.
CMOS1138 is offline   Reply With Quote
Old 07-01-2009, 12:56 PM   #6
Here is my question.......
I have a Laptop with a broken monitor and want to know ......
How to remove the monitor from it and use the connection to connect it to monitor. That is my question and for those who want to know its a Toshiba Satellite A75-s231..
Old 07-01-2009, 12:59 PM   #7
North of the land of Hey Huns
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
If your laptop does not have a VGA or S-Video connection on the back end, you can not remove the laptop panel and connect it to a normal screen.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 07-01-2009, 02:08 PM   #8
It has both connections
Old 07-01-2009, 02:52 PM   #9
Xygar's Avatar
Xygar is an unknown quantity at this point
I have a compaq presario v2000 whose screen recently went out. I googled it and found a pdf manual on how to disassemble it (initially I thought I might be able to fix it... I was wrong). I took it apart and ended up just removing the screen entirely (why would I want it, it doesn't work!). I now use the laptop (with the whole lid removed) connected to an external 19 in. monitor, and it works just fine. I use the VGA out off of the laptop though, not sure if you'd be able to connect an external monitor to the original connections, though if you can find a pin out...
Xygar is offline   Reply With Quote
Old 07-01-2009, 02:54 PM   #10
Than just remove the screen and plug whatever monitor you plan to use in the car into the vga port. Removing the broken screen should not be overly difficult, just use a screwdriver.
Old 08-20-2009, 02:00 PM   #11
sargeants's Avatar
sargeants is an unknown quantity at this point
removing the screen assembly on your A75 won't take much effort at all. 7 screws to have completely removed, 3 to temporarily remove while removing the wireless antenna and lcd cable from the systemboard. If you break the little hinge covers after taking off the strip cover you'll have a nice flat top machine.
make sure you've got some good cooling for that thing, it's a beast, also draws a lot of power being a full P4 - be careful.
03 Hyundai Elantra GT
HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
RideRunner; cmdRR tall skin (in creation)
Elantra Worklog
86 Pontiac Fiero SE 2m6
Sony MP3 CD deck
eventual carpc install
sargeants is offline   Reply With Quote
Remote laptop startup ambush Laptops, Netbooks, Tablets, UMPCs, etc. 47 11-24-2008 03:28 AM
New Laptop Project! LeeVD Laptops, Netbooks, Tablets, UMPCs, etc. 3 11-22-2007 01:59 PM
Broken Laptop Startup fabiolover2002 Newbie 4 11-05-2004 04:51 PM
Using LCD from broken laptop in car yakirz LCD/Display 9 04-20-2002 09:07 PM
