Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc.
Old 08-08-2009, 11:25 PM   #1
moelsaied88 is an unknown quantity at this point
looking for alternative to W3bmasters auto power on module.
Hey guys, im looking for w3bmasters auto power on module but it seems that he's not making them anymore. can anyone recommend any alternatives please? thanks in advance
moelsaied88 is offline   Reply With Quote
Old 08-09-2009, 07:48 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
If you want to permanently install the laptop in the car, how about a Carnetix.
Someone wired up a plug for the motherboard power lead into the side of the laptop. That would work, as well and looks clean as hell.
If you want portability or a Carnetix won't work w/ your laptop, how about rigging up a means of providing a WoL or WoR signal through the appropriate port?
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 08-09-2009, 09:52 AM   #3
ive tried the WoL and it doesnt seem to work reliably on this particular laptop, but even so i would still need to press a button wouldnt i? i havent heard of WoR, any information on that particualr subject would be appreciated. As for the carnetix, i thought that was primarily for full size motherboards such as the P4? i just ordered the laptop car charger to power it and i have a switch soldered to the button controller of the laptop so i can push a button at the front of the car to turn it on and im using shutcontrol to turn it off. im at a loss for other ideas other than w3bmasters module, but ive been waiting for about 2 months now for him to become available again and it doesnt seem like its going to happen. thanks in advance!
Old 08-09-2009, 10:11 AM   #4
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
You need a time delay relay. When power is applied, it closes the relay for 2 seconds, then opens it. This site has a diagram of one and the second comment down is by a user who added a capacitor to make the circuit close for 10 seconds. Adjusting the cap would shorten the delay, I'm sure.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 08-09-2009, 04:38 PM   #5
i purchased a 12V SPDT 30 AMP AUTOMOTIVE RELAY on the advice of someone for this site, they told me that with this relay when power is applied to the circuit the switch will be triggered and turn the laptop on. now my concern is that power is applied when when i turn the key twice, once when it goes to acc then during the crank the power turns off then on again. is this going to hit the switch twice if i simply use the relay? i dont know too much about relays so its all new to me. and if this is the case, will the schematic you pointed me to take care of that particular problem? thanks in advance
Old 08-10-2009, 12:33 AM   #6
Bugbyte's Avatar
Probably. If you can figure out how to make it wait a few seconds, it will work.
The schematic I pointed you to should avoid that problem but read it closely. You want it to wait a few seconds before closing the relay, then close it for a short period of time, then release.
Want to:
-Where is the iBug?
Old 08-11-2009, 04:19 AM   #7
emintolga is an unknown quantity at this point
Lightbulb
I find this:
http://www.xobyte.com/
emintolga is offline   Reply With Quote
Old 08-23-2009, 04:15 AM   #8
boelle is an unknown quantity at this point
well i got the circuit diagram for w3bmasters module... if you can solder you should be able to make them by hand in 15 min
boelle is offline   Reply With Quote
Old 08-23-2009, 09:11 AM   #9
that would be SUPER appreciated. do you have the one with the usb cable that tells it not to send a signal when the computers already on? thanks in advance.
Old 08-23-2009, 09:19 AM   #10
yep
it's on his own page
Code:
http://w3bma5t3r.com/modules/coppermine/albums/userpics/10002/module_schematic_1-6-2007.jpg
Old 08-23-2009, 09:21 AM   #11
it says error 404 Not found when i go to that site
Old 08-23-2009, 09:24 AM   #12
it works here... hmm... pm me with an e-mail and i will mail the jpg to you
Old 08-23-2009, 09:46 AM   #13
k got it working but looking at it something doesn't seem right. it looks like there's 3 separate circuits here that aren't connected. one with the ground and +12 v, one with the USB ground and the other that connects to the power switch. are you sure this is a true schematic? has anyone been able to build the module off of this? Im not the best at reading schematics, but i have done it before (i'm a bio med engineer) and this doesnt make much sense to me.
Old 08-23-2009, 09:49 AM   #14
i will try to draw on top of it to make it more clear and then upload it
i just saw what might confuse.... read next post
Old 08-23-2009, 09:55 AM   #15
thank you, i appreciate your help!
Mac Mini Auto Boot - (bypassing power button) VinceC MacCar 19 10-04-2008 12:11 AM
What Power Supply for Laptop Install? D3LTR33 Newbie 6 08-04-2008 07:41 AM
FS: ITPS shutdown controller and PW-70a MINI-ITX power supply hanzacra Classified Archive 4 08-07-2005 11:32 PM
