Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc.
Old 08-19-2009, 02:58 PM   #1
boelle is an unknown quantity at this point
remove screen and connect vga display
i have a medion md 98300 that i want to use for carpc
but can i remove the screen and connect a indash screen instead? and how is that done?
boelle is offline   Reply With Quote
Old 08-19-2009, 05:57 PM   #2
hailrazer's Avatar
hailrazer is an unknown quantity at this point
You remove the factory screen , unhook the lvds cable and the inverter cable. Put the laptop in the car where you want it. Run the external vga cable from the laptop to the dash mounted Vga screen and push whatever button combination on the laptop to activate the external vga monitor. Usually function and f4
My 2007 Yukon XL setup. http://www.mp3car.com/vbulletin/show...64-5000-a.html
hailrazer is offline   Reply With Quote
Old 08-19-2009, 06:02 PM   #3
sergatiuk's Avatar
sergatiuk has a little shameless behaviour in the past
also if you want your lappy to always recognize the VGA as the primary monitor, after removing the factory screen and attaching the vga disconnect all power, remove the battery, remove the little round battery on the mobo, wait a few mins, reconnect everything back, VGA should be primary screen now (;
sergatiuk is offline   Reply With Quote
Old 08-20-2009, 04:43 AM   #4
what i want is remove the factory screen and connect an external vga to the lvds socket so that i can have a dual screen setup
EDIT: Maybe this one does the trick? http://www.orbitmicro.com/global/lvd...0-p-10904.html
EDIT: my connector at mainboard:
EDIT: closeup at panel connector
whole panel
wires at the motherboard connector
wires at the inverterboard
wires at the panel connector
Old 08-20-2009, 11:40 AM   #5
in the part of the display cable that goes to the panel there are 4 twisted pairs and 5 single wires along with a screen
can any help out how i ident each wire?
Old 08-31-2009, 07:12 AM   #6
solved this one.. the ones who make the panel was so kind to give me the full spec sheet.. so now i can both make that lvds interface to an vga interface and make that panel an vga monitor
Old 09-19-2009, 04:50 PM   #7
Slimline's Avatar
Slimline is on a distinguished road
Can you provide the diagram? Take a screen print and upload the picture to Photobucket or something?
Slimline is offline   Reply With Quote
Old 09-20-2009, 03:20 AM   #8
there are no diagram, each laptop has it's own pinout on the panel
but i use the LVDS-VGA-R10 from tri-m systems and the pinout for that module are as follows:
you have to get the pinout for your panel and then match up each pin of this module
Use Ipaq Touch Screen Display As Carcomputer Lcd sullivan2002 LCD/Display 7 01-08-2007 02:31 PM
Connect vga touch screen and 2 headrest screens??? duglas MacCar 6 11-08-2006 06:57 PM
Xenarc 700TSV 7'' touch screen krazymarine Classified Archive 3 09-20-2006 11:55 PM
in-dash DVD HU with touch screen and VGA??? DaveB LCD/Display 2 01-21-2006 04:43 PM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 03:16 AM
