Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc.
Old 02-13-2005, 12:27 AM   #1
TimStark is on a distinguished road
Angry Laptop Power On I've Searched Help Please
Ok guys well I lost my job so I am in need of money. So I pulled my itx system from my glove box and I am installing my laptop into the car. My plan was to install a small numeric keypad in my console so I could just hit a key to bring the computer back from hibernate or standbye. So I've pulled everything and just go finished setting the laptop up and I've found that the only way to bring it back from hibernate is to hit the power button and the only way to bring it back from standbye is to hit a key on the laptops keyboard. This isn't going to be possible since I am installing the laptop under the passenger seat. So basically I am losing my mind. I've seen people speak of taking the laptop apart and hard wireing a monetary switch. This isn't possible for me because I need to be able to remove this laptop and bring it places with me. Ok well someone please help. Here are the specs of the laptop.
Sony Vaio TR2A
1GHZ Centrino
512 ram
xp home
40 gig hd.
2 usb, modem, ethernet, firewire, pcmcia, sound, and monitor ports are all that I have available.
O wait I have a dc out port available that I have never been able to figure out what that does. Ok well please help someone. Thanks,
Tim Stark
TimStark is offline   Reply With Quote
Advertisement Sponsored links
Old 02-13-2005, 08:36 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Sony Vaio TR2A
1GHZ Centrino
512 ram
xp home
40 gig hd.
Centrino isn't a CPU. It's an Intel marketing term for their chipset/wireless NIC combo. Your laptop has a Pentium M processor.
I don't know a solution to your problem, other than turning the PC on once you get it in the car.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 02-13-2005, 09:50 AM   #3
Prem's Avatar
Prem is on a distinguished road
I see that money is an issue here, but have you thought about a docking station. These normally have a power switch on them. You could hardware the docking station into the car (keypad, power switch etc.), then you could take the laptop out at any time.
Prem
Re-boxed Dell Optiplex GX110 PIII 733 256Mb RAM
Modified Sproggy PSU
Custom made automatic start-up/ shut-down controller
Dual 2.5" HDDs
Laptop DVD Reader
D-Link FM Radio
5" PSOne LCD
Installed and working. 75% complete.
Prem is offline   Reply With Quote
Old 02-13-2005, 11:59 AM   #4
cavramair's Avatar
cavramair is on a distinguished road
Like the few guys above said, there reallly isnt gonna be an easy way to do this. A docking station would work. If whats holding you back from installing a second switch for power is the removability, you will just have to make a way to connect and disconnect it. Cut a small set of connectors onto the laptop case somewhere, and hook up the wires to the external switch when you get in the car. Thats the simplest, and cheapest way to work around this problem that I can see.
-Drew Taylor
2000 Grand Am GT PC
cavramair is offline   Reply With Quote
Old 02-13-2005, 05:24 PM   #5
crono35 is on a distinguished road
Most laptops can be brought out of standby through a usb device, such as a mouse. Unfortunately this means leaving your computer in standby, which consumes a decent amount of power (my laptop batteries die after rougly 2 days of standby).
crono35 is offline   Reply With Quote
Old 02-14-2005, 03:08 AM   #6
Yesterday 06:24 PM
crono35 Most laptops can be brought out of standby through a usb device, such as a mouse. Unfortunately this means leaving your computer in standby, which consumes a decent amount of power (my laptop batteries die after rougly 2 days of standby).
This is what I was wanting to do because I am in my car at least once a day and the inverter would recharge the battery during my drive time. But I cannot seem to get my usb mouse or usb numeric keypad to bring it out of suspend. Is there a setting in widows I can use to make this work. Thanks for the info and help.
Old 02-14-2005, 04:40 AM   #7
GingerPrince's Avatar
GingerPrince
An easy assumption. I bought one for my Fujitsu Lifebook for this very purpose. Did it have a power switch? Did it
GingerPrince
Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
Carputer Install - http://www.stuffandting.com/carputer/
CarBox Software -- http://www.stuffandting.com/carbox/
GingerPrince is offline   Reply With Quote
Old 02-21-2005, 05:56 PM   #8
wagonerd's Avatar
wagonerd is on a distinguished road
Here's an idea...
I just finished my laptop install and I was able to run the wires from the power switch to two of the modem pins. (who uses dial-up anyway?) I was then able to plug a phone cable in to the laptop and wire that to a momentary switch. This way I can just unplug the phone cable and take the laptop inside for updates or whatever. If you'd like I can get pictures...
wagonerd is offline   Reply With Quote
Old 02-21-2005, 06:07 PM   #9
phita23 is on a distinguished road
wagonerd - yes, please post pictures, and also tell us what two pins you connect to turn on the computer.
phita23 is offline   Reply With Quote
Old 02-21-2005, 06:39 PM   #10
mattress is on a distinguished road
keep us informed, i'm interested too!
mattress is offline   Reply With Quote
Old 02-21-2005, 06:46 PM   #11
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
That's a great idea! Way to go =) Then you could also connect the other end of the phone cable to an ITPS and automate the startup/shutdown. Nice!
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 02-21-2005, 07:00 PM   #12
Details! All the details please!
Old 02-21-2005, 07:03 PM   #13
zPilott's Avatar
zPilott is on a distinguished road
That is a good idea. And you could connect two fo the pins to the lid switch and two to the power.... hmmmmm
|V1 Virtual Display|
Hard work often pays off over time, laziness always pays off right now.
zPilott is offline   Reply With Quote
Old 02-22-2005, 09:21 PM   #14
javikid is on a distinguished road
i customized the laptop to have asses to the power button (removed the lcd screen from the laptop) and placed the power button on top of lcd cover....sice i have a 350Z i reach over the pass. seat and power it on. what do you guys think?
javikid is offline   Reply With Quote
Old 02-24-2005, 02:42 PM   #15
zPilott's Avatar
I bought a TCS OFF switch to replace the blank that was next to my VDC OFF switch and ran the power switch to that. It is a momentary switch, with a light in it that looks real clean. I like it because it is convenient to access, and it is completely stealth to anyone who doesn't own a Z (and I say TCS stands for The Computer System). I really like the idea of running the line to the modem port, I am going to have to look into doing that.
|V1 Virtual Display|
Remote laptop startup ambush Laptops, Netbooks, Tablets, UMPCs, etc. 47 11-24-2008 03:28 AM
New product - PC Power switch with wired remote hd54321 General Hardware Discussion 5 03-08-2006 11:48 PM
power options missing on xp laptop hotponyshoes Software & Software Development 2 12-13-2004 09:01 AM
quick question re: laptop power mkerr Power Supplies 6 10-22-2004 12:37 AM
prob with power to laptop cubanmoses Power Supplies 2 08-19-2003 09:21 AM
