Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Notices
Old 04-08-2007, 02:18 AM   #1
hypnotiq's Avatar
Laptop won't startup at ignition with carnetix
I have a dell 600m hooked up to a carnetix, but the laptop won't turn on when i turn on my car. I can turn on the laptop by pressing the power button though after the carnetix is loaded even without the battery in.
I know the ignition isn't the problem since i am just using a 12v source as the ignition.
Any idea what's going on?
hypnotiq is offline   Reply With Quote
Old 04-08-2007, 05:26 AM   #2
v8 scimitar's Avatar
have you connected the laptop power button to the power supply propery?
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit.
v8 scimitar is offline   Reply With Quote
Old 04-08-2007, 05:31 AM   #3
hypnotiq's Avatar
Sorry for my ignorance, but how do i do that?
The primary output for the carnetix is connected to the barrel connector for the laptop (ie. the ground and power for that connector). The secondary output is connected to the screen.
Old 04-08-2007, 05:40 AM   #4
Ah, well in short you need to open the laptop solder wires onto the switch and bring them outside the case. There wires get connected to the startup-shutdown controller.
For more detailed you best get searching as there are loads of posts on this subject.
Old 04-08-2007, 05:53 AM   #5
hypnotiq's Avatar
I can search on that, but it was to my understand that this wasn't needed for carnetix p1900?
Old 04-08-2007, 07:54 AM   #6
Neither darque nor pervert
DarquePervert's Avatar
That's what the green/whie wire is for.
I don't know where you got that little piece of information, but it is incorrect. The Carnetix has to simulate a press of the power button in order to initiate bootup.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 04-08-2007, 03:14 PM   #7
hypnotiq's Avatar
Hey,
Can anyone confirm is the following post is true?
Quote: Originally Posted by Curiosity View Post
The common tactile pushbuttons have 4 pins. The 2 on each side are connected together, so you need to solder a wire to either pin on each side.
Old 04-08-2007, 03:28 PM   #8
Raw Wave
shotgunefx's Avatar
If you don't feel like cracking open the laptop, I'd get a port replicator and hack that (or maybe the monitor stand to boot)
I have an inspiron 8600, which IIRC, uses the same dock/port stuff (double check). I paid I think around $45 for the port replicator (D/Port APR) and a monitor stand on ebay.
They are cheap and tons of them on ebay. I got the monitor stand for two reasons. One, two protect the laptop from crap rolling around my trunk, and two, it was so easy to remove the little power button board and short it out (on the inspiron 8600, this makes it boot when power is applied, you'd want to use the wires provided to pulse it, I used power management to shut it down when it loses "AC").
Here's a pic of the monitor stand and dock.
shotgunefx is offline   Reply With Quote
Old 04-08-2007, 04:07 PM   #9
hypnotiq's Avatar
I don't mind opening up the laptop, i actually already have just have. I just don't know what to solder since my button has 4 pins.
Old 04-08-2007, 04:36 PM   #10
Nerd2's Avatar
Just keep poking at it with a screwdriver until it turns on, then you've found the correct 2 pins to wire to.
Nerd2 is offline   Reply With Quote
Old 04-08-2007, 06:48 PM   #11
That's what they told Steve Irwin, too!
Seriously...
To be more clear, connect two pins on the switch. If that does nothing, then try a different combination of two pins. Repeat until you find the correct two-pin combination. Solder those two pins.
My Worklog
Old 04-08-2007, 07:41 PM   #12
Raw Wave
shotgunefx's Avatar
I think mine did too. Not 100% but I thought whichever two it was, were diagnol from each other. Might be remembering wrong too though :\
Old 04-09-2007, 12:58 PM   #13
Use a multimeter...
Place a multimeter across two of the four leads coming to the power switch. Press the switch and note which two leads are registered by the multimeter. Those are the two you need to solder leads to to turn on the lappie.
I used a docking station for an IBM R51 laptop with a power switch, so I didn't have to drill into my laptop. I drilled a hole in the docking station and put a female plug into the hole after soldering the leads. A male plug on the outside completes the circuit and allows you to easily remove the laptop if you need to. I also placed a momentary switch in parallel with the power switch and mounted in the dash so I can have control and also so I can hold it in for 5 seconds and force power of (windows you know ).
Use a small soldering iron on the switch if it is surface mounted. Tin your wires and touch only briefly to avoid frying your system...
Good luck
Thefdog is offline   Reply With Quote
Laptop automatic startup using a single shot relay jonee Power Supplies 13 10-28-2008 10:46 PM
Remotely startup laptop...? (wake on lan)?? Pro Laptops, Tablets, UPMCs, etc. 44 01-13-2006 07:57 AM
Laptop startup again - Yes I searched. shotgunefx Power Supplies 0 10-07-2005 03:52 AM
Carnetix startup help Bugbyte Power Supplies 6 12-19-2004 01:10 PM
