The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 04-28-2007, 02:05 PM   #1
"Speaker of the Truth"
veedubya's CarPC Specs
veedubya's Avatar
Vehicle: 1971 VW Beetle
My Photos: (10)
Laptop use in car
I have been toying around with the idea of using a laptop in the car. Is there a way to have laptop plugged into 12V via cog. adaptor but to run off the laptop battery until the battery hit a certain % then kick over to the AC.
Laptop plugged in battery at 100%-11% = running off laptop battery.
Laptop plugged in battery reaches 10% = running off AC plugged in.
I briefly searched for an Adv. Power Management Tool but found nothing
thanks
veedubya
"Geeks dont need girlfriends we can ping ourselves"
Sony Vaio 2Ghz 40G HHD, Routis 2004 GPS, 7" VGA TS Lilliput, BackUp Camera running RoadRunner with Simplistique Skin.
veedubya is offline   Reply With Quote
Sponsored Links
Old 04-28-2007, 02:22 PM   #2
gadu^'s CarPC Specs
My Photos: (0)
why not simply use a DC-DC converter and have it plugged into the 12V cig?
Me, myself and my car
gadu^ is offline   Reply With Quote
Old 04-28-2007, 02:34 PM   #3
veedubya's Avatar
My Photos: (10)
maybe the confusion was i referred to AC power in my last line.
clearer scenario
Laptop plugged in to cig. adaptor and battery at 100%-11% = runs off laptop battery while still plugged in
Laptop plugged in to cig. adaptor and battery reaches 10% = runs off cig. adaptor
Old 04-28-2007, 02:46 PM   #4
Nerd2's CarPC Specs
Nerd2's Avatar
Vehicle: Ford Mondeo 96
My Photos: (0)
Why would you want this?
I would think it may be possible to do in VB..... possibly.....
EDIT: Actually "AC" may be directly linked to battery, you'd have to have some sort of relay?
Nerd2 is offline   Reply With Quote
Old 04-28-2007, 03:13 PM   #5
lbridges's CarPC Specs
Vehicle: 2002 Toyota/MR-2
My Photos: (8)
It would help if the scenario for use was explained. For example, if all you wanted to do was have a way to sit in the car and run the laptop for an hour or so without draining the car's battery, then just insert a switch inline with the power cord to the cigarette lighter.
lbridges is offline   Reply With Quote
Old 04-28-2007, 06:33 PM   #6
veedubya's Avatar
My Photos: (10)
Laptop plugged in to cig. adaptor and battery reaches 10% = runs off cig. adapter
Not sure a better way to explain.
If laptop battery is bewteen 100% - 11% it will run off the laptop battery
If it drops below 10% then I would like it to run off the cig. adapter.
As it is i have a 2nd battery that will be used for laptop and possibly 7" Lilliput.
Just trying to think of a way to use laptop battery to a certian point before switching over to the 2nd car battery
Old 04-28-2007, 06:36 PM   #7
Nerd2's CarPC Specs
Nerd2's Avatar
My Photos: (0)
Errr, the question we have isn't 'what do you want to do?', it's 'why do you want to do it?'
Old 04-28-2007, 06:57 PM   #8
veedubya's Avatar
My Photos: (10)
does my reason need to be more clearer than this
Old 04-29-2007, 06:47 AM   #9
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
What's wrong with a manual switch? You switch it when the OS warns that your battery is low.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 04-29-2007, 07:00 AM   #10
gadu^'s CarPC Specs
My Photos: (0)
Also, a laptop can run on a car battery for a looong time...
I don't see any use of this...
Sponsored Links
Old 04-29-2007, 08:42 AM   #11
My Photos: (0)
I'm coming in late on this one but.....
If you constantly run your laptop off the battery discharging it continuously it will prematurely shorten it's life. In a few months you'll notice shorter run times before needing a fresh charge. Depending on the type of computer you have, say a desktop replacement, they aren't necessarily meant to run for significant periods of time on battery.
My suggestion is run your laptop off your car's power using an inverter or dc-dc adapter. Use your laptop's battery when the car isn't running.
Shai-Hulud is offline   Reply With Quote
Old 04-29-2007, 09:11 AM   #12
Registered User
spud42's Avatar
Vehicle: NISSAN 180 SX TURBO
My Photos: (0)
if you put power into the back of a laptop by what ever means you try, either the manufacturers dc adaptor to a cig socket or via an inverter and laptop psu . it doesnt matter. the laptops power/battery management system will use that power and also charge the laptop battery. in other words it is part of how the laptop is made and unless you modify the power circuits it cant be altered by software alone. the laptop battery wont be used unless external power is removed. you could make a circuit with a relay that is controlled by software and monitors the laptops battery level and then switches to ext power at the point you want . but as stated before the laptop battery isnt going to take a lot of deep discharge cycles ie down to 10% or less too often. i am looking at a dell d620 dual core laptop right now and its battery is 11.1 v and 85 WHrswhich means a capacity of 7600 mA approx. this gives me approx 3 hrs of use. your car battery would probably power the laptop for over 24 hrs straight. then when it gets low you would then have the laptop battery kick in and have 3 hrs to get the main battery recharged.. the laptop battery would act like a UPS.... if your second battery is charged via the car as per normal then you would probably never need the laptop battery. so why do you want to do it the way you said?????
NISSAN 180SX SR20DET 2lt TURBO red,5 spd 130Kw(175 hp) at rear wheels,gigabyte ga5ssm mobo,AMD k6 ii 450 Mhz,128 meg ram,4" sharp lcd,40 gig Hdd. IRMAN WinAmp , MElite.
ipaq4700 ,WM2003 SE,2 Gig CF,2 Gig SD,destinator 3.1,TCPMP
spud42 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
hooking up a laptop to car speakers? djomlas Newbie 3 11-24-2006 10:38 PM
VIA and Mini-box Announce First Sub-$300 Car PC Kit Goofus General Hardware Discussion 27 03-13-2006 11:28 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
