Decided to go laptop route...with docking station
Hi all,
Well, since I was able to score an old gateway 450sx4 computer with a busted screen from work, I've decided to go that route instead of the mini-itx route. Now I just have a few questions. I've done plenty of research and there seems to be a lot of differing opinions on this.
But basically I would like to know what my best bet in terms of powering the system and controlling startup/shutdown are. Again, this will be used with a docking station..
As per the gateway powerbrick specs, it states the output is 19v@4.74A. Input is 100-240v @1.5A.
This is a p4 gateway laptop. Does anyone have any suggestions for the most cost efficient way to power this thing?
And I'm still confused about the startup/shutdown control issue. I've seen threads where they have dedicated circuit boards to control startup/shutdown...then others where they say it can be done all with a simple soldering of power wires on the laptop itself?
Thanks for any help you guys may have in advance.
