The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 05-22-2007, 04:50 PM   #1
My Photos: (0)
Power a laptop dc power supply off M2ATX?
Right now I have my M2ATX connected to a regular M10000 setup, but I am wanting to switch to a laptop. Would it be feasible to connect a DC power adaptor from the M2ATX to the laptop? This would allow me to keep my regulated 12v for my screen, keep my shutdown controller, and not bother with an inverter. I like the features of the M2ATX, only problem is whether the 12v rail can handle it. What do you guys think? It would be more efficient too... 12V > 19or 20V instead of 12V > 120V > 120V > 20V
evilkokonut is offline   Reply With Quote
Sponsored Links
Old 05-22-2007, 05:18 PM   #2
Super Moderator
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Where would you get the 19 or 20v from the M2ATX?
It won't work., You're better off selling hte M2ATX and getting a Carnetix P1900 or P2140. You could also use a car power adapter for your laptop.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 05-22-2007, 05:44 PM   #3
My Photos: (0)
the 19 or 20V would come from a DC car power supply for my laptop... the travel adaptors or something
edit--
wow I just looked at the carnetix power supplys... I didn't know that they could do 19 or 20v... yeah that is probably what I need. Thanks... Now I just have to sell my current setup and get the laptop in my car.
Old 04-21-2008, 12:42 PM   #4
Vehicle: 2000/audi/TT
My Photos: (0)
A travel adaptor for your laptop would most likely be cheaper than the carnetix P1900, also smaller in size. That is what I plan to use since the Inverter is producing too much noise.
Abuelin is offline   Reply With Quote
Old 04-22-2008, 09:49 PM   #5
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (50)
as long as the M2-ATX's +12vdc rail can provide enough current for your laptop "travel adapter" then it should work fine. but even if it can't; you don't actually have to power it from the M2-ATX, you can connect the laptop travel adapter directly to the car battery and just use the M2-ATX as a startup/shutdown controller.
alternatively, you can build one of these laptop auto-power-on modules, or buy one pre-built from 'W3bMa5t3r'. (you will have to configure the the laptop to turn off when external power is disconnected)
a carnetix PSU would be the best option for powering/controlling your laptop. they are expensive, but there really isn't any other product that provides the odd voltages that a laptop requires and also has an integrated startup/shutdown controller.
good luck, whatever you decide to do
FusionFanatic is offline   Reply With Quote
Old 04-22-2008, 11:08 PM   #6
My Photos: (0)
I know for a fact that, even though you laptop power adapter may be putting out 19v, your laptop does not need that much. I mean, how much voltage does your battery carry??? Mine puts out 11.something. I have also had a Gateway laptop years ago that had a 19v power brick. It turned out that it would run straight off a cigarette lighter, not a travel adapter.
blackcobra487 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
DIY DC power supply??? lopan Power Supplies 17 03-23-2007 12:18 PM
Laptop and Xenarc screen, what power supply to get?!? spinedoc Newbie 4 02-05-2007 12:09 PM
FS: ITPS shutdown controller and PW-70a MINI-ITX power supply hanzacra Classified Archive 4 08-07-2005 10:32 PM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 12:13 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
