The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 06-22-2007, 03:28 PM   #1
My Photos: (0)
Laptop or DashTop?
It seems I am either so thick that I cannot grasp simple thing or too much reading posts in this forum has made me brain dead!
I have a Hyundai Terracan (4x4) and I would like to install a carputer, simple really. I still don’t know what’s the best way to go about it? I like the idea of laptop but don’t feel comfortable leaving the laptop in the car, unless I go for some sort of ‘plug and remove’ option! The other option, PC, sounds complicated but probably cheaper?
Guys help me out to decide.
cheers
mandm is offline   Reply With Quote
Sponsored Links
Old 06-22-2007, 03:52 PM   #2
symon_say's Avatar
Vehicle: 05 Fiat Palio
My Photos: (1)
You can use a dock station for the laptop and make it plug n' play
Design [000000000-]90%
Parts [000-------]30%
Installation[----------]0%
Integration[000-------]30%
symon_say is offline   Reply With Quote
Old 06-23-2007, 05:23 AM   #3
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
You're not finding a post that says "This is the best way to do your project" because there is not rhead that says "tyhis is the best way to do your project". It's your project. You work with what you have to achieve the best results you can, plain and simple.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 06-23-2007, 07:28 AM   #4
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
do you already have any componets that you could use to start your project? if so, then you may want to start there.
in my case, I had an old laptop that I didn't use much anymore so I chose that as the base for my carputer project. I bought a docking station for $20 off ebay that allows me to remove/reconnect the laptop at anytime without having to individually hook/unhook wires/cables. to take the laptop with you, you just pull it out; to use it again, you just push it in; it's that simple. all cables are plugged into the docking station, not to the laptop itself.
it comes down to what you can afford... if you don't have any components already, there are plenty of laptops with broken screens on ebay. they can be a fast and cheap start for you (would be much cheaper than building a mini-ITX system from scratch.
good luck
FusionFanatic is offline   Reply With Quote
Old 06-23-2007, 02:31 PM   #5
My Photos: (0)
i like that idea, thanks mate
Old 06-23-2007, 02:33 PM   #6
My Photos: (0)
i agree with u mate, it just i need a starting point, somewhere i could get to see a light at the end of the tunnel!
Old 06-23-2007, 02:38 PM   #7
My Photos: (0)
good luck
hi mate, thanks for your detailed response, yep i have an old IBM laptop with a docking station so that's starting point. Now all i need is perhaps a screen and some sort of power option? and some cabling to get the lappie to be powered on/off and perhaps suitable location for lappie to reside
Old 06-23-2007, 03:50 PM   #8
My Photos: (56)
for the monitor I used a lilliput EBY701 ($115 on ebay)
my laptop/docking station is mounted in the trunk. I used 10' VGA, USB, and RCA cables to connect the monitor, touchscreen, and audio. I soldered wires to the docking station's power button and ran them to a switch, however most people probably run them to a startup/shutdown controller instead.
for laptop power I bought a vehicle power supply ($25 on ebay). the monitor is plugged right into vehicle 12v.
hope this helps... good luck
Old 08-02-2007, 06:14 AM   #9
Banned
My Photos: (0)
caheoo123 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
why does my laptop turn on? Efess Laptops, Tablets, UPMCs, etc. 19 07-02-2007 08:45 PM
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 23 09-01-2006 01:18 AM
Buying a laptop Rocky388 Laptops, Tablets, UPMCs, etc. 5 07-13-2006 01:13 PM
fix a broken dell laptop? kuo Off Topic 8 02-27-2006 04:58 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
