The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 07-03-2007, 01:09 AM   #1
Vehicle: 93 Mazda MX6
My Photos: (0)
Ideas where to put laptop
As the title says, what options do I have, I have a docking station, but I don't need to use it. Any ideas would be great, if it helps, the car is a '93 mazda mx6
thedog300 is offline   Reply With Quote
Sponsored Links
Old 07-03-2007, 06:50 AM   #2
greatwhite's CarPC Specs
greatwhite's Avatar
Vehicle: 2004 Chrysler 300M Special
My Photos: (1)
Ummm..... in the car?
J/K
Seriously, anywhere dry and clear of dirt accumulation. Any where it will fit.
If you need to get to the power buttons and such, then it has to be close to where you sit. Unless you don't mind running around to the trunk everytime you start the car........
Good luck
BJ
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 07-03-2007, 09:20 AM   #3
My Photos: (0)
my plan power wise is to have a power inverter connected to a source that powers on when the car turn on, and have it so that when the laptop loses power and switches to battery power it goes to hibernate mode and just runs that off the battery, when the car turns on, tap the screen and it wakes up. As far as placement goes, I was thinking glovebox or under driver seat. I was thinking trunk but then I'd have to run a usb cable and vga cable and I'm worried about signal loss that way.
Old 07-03-2007, 09:39 AM   #4
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Sounds like you have a solid plan, although I recommend using a DC-DC power setup over an inverter any day of the week.
A car adapter for your laptop would achieve the same thing and not bring about the potential of excess heat, ineffeciency and postential noise in the audio setup.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 07-03-2007, 09:51 AM   #5
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (71)
the signal loss from the trunk shouldn't be too much of a problem altough usb stuff can sometimes act up over 10', there are usb extenders though that boost that limit. the touchscreen wakey thing sounds good but you have to test it, not to sure how reliable that may be if it even works at all.
one advantage you'd have with the dock is you can hack into the power switch on it if it has one & have a hardware startup solution over a software one, which should be much more reliable & trouble free
also, I second about dc/dc power supply, much cleaner power & more efficient.
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is online now   Reply With Quote
Old 07-03-2007, 10:00 AM   #6
brad1011a's CarPC Specs
My Photos: (0)
Heat may be an issue in a trunk (sun on the flat surface can be brutal) unless you could give it its own insulated housing. Many trunks (and my van's side panel) have ventilation exhaust. I'm going to add a 12V PC fan to mine so the laptop will stay cooler.
Trunks are good for security too I believe.
brad1011a is offline   Reply With Quote
Old 07-03-2007, 11:47 AM   #7
My Photos: (0)
Well I tested my wake by touching screen trick and it didn't work so I soldered on a button connected to some speaker wire that I'll extent to my dash. The trunk is sounding like a better option, now here's my new problem. I created a Hibernate shortcut using the directory rundll32.exe PowrProf.dll, SetSuspendStat Hibernate and when I click on it it goes to hibernate, but I can't figure out how to make this shortcut an application in Roadrunner, what I have in the ini is
[GENERAL]
PATH = C:\Program Files\Road Runner\LAUNCH\Hibernate\Hibernate.exe
TryEmbeddedTimeOut = 5
WindowSearchString=hibernate
does anyone have any other ideas on how I can force it to hibernate?
Old 07-03-2007, 11:52 AM   #8
turbocad6's Avatar
My Photos: (71)
the most common way is to have the laptop hibernate when on battery power for X amount of minutes, that is, if your retaining the laptop battery...
also, if your going to use a startup shutdown controller this can be automatic by setting the power button to hibernate when pressed, then even if your not going to use a controller for this, you can still tap the same button you use to start it by the same method.
Old 07-03-2007, 11:55 AM   #9
My Photos: (0)
ya, i tried the timer, but winamp/roadrunner kept it from going. I thought of a new solution though, I just made the poewr button make it go to hibernate mode since Its already going to the dash anyways to take it out of hibernate mode.
Sponsored Links
vB code is On
Trackbacks are Off
Ideas for a laptop LCD "tablet install" Rezin385 LCD/Display 2 09-15-2006 08:45 AM
Intuitive in-car laptop ideas? wallus MacCar 8 02-20-2006 07:58 AM
My idea for a Laptop Switch for my MKIV Jetta. Can this work?!? Man Ace Power Supplies 47 05-03-2005 12:28 PM
Laptop vs desktop wei2cool General Hardware Discussion 17 03-17-2005 05:25 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
