The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Closed Thread
Thread Tools Display Modes
Old 07-11-2007, 12:55 AM   #1
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (64)
How can I use a laptop as a carpc?
Using a laptop or tablet as a carpc:
A laptop or tablet can make a good carpc, low power consumption and low heat generation are desired qualities for a carpc. Most laptops possess these qualities and are purpose built to be mobile and efficient. Some laptops are better suited for this use than others, although just about any laptop can be used. There are many different ways that a laptop can be used in a vehicle & there are a few unique challenges to a laptop install. A highly portable unit will generally be a better choice than a huge desktop replacement type laptop.
One trend that is sure to grow rapidly as performance rises & prices drop is to use an ultra portable mini PC, just slip it in its dock & the dock is wired to the car & the screen in the dash. Really down & dirty is to just mount it in a way that you just view the ultra portable itself, once transflective screens become more commonplace in these units this will be a good option for some to achieve an install without altering the vehicle much at all.
Choosing a laptop:
many of the laptop installs are done with a laptop that you may already have, but choosing the right laptop specifically for the install is sometimes an advantage. a PIII 1.2 will perform similar to a standard via board, it can get the job done if you like the minimalist approach & have a good handle on your running services and optimize your system for the performance you have. They are relatively efficient partially due to their speed step technology.
if you have a choice try to avoid Pentium 4 laptops, & this goes for p4m’s as well, they are the least efficient & generate the highest heat levels, suck large amounts of power just to create this heat, & then they also suffer as being more susceptible to being damaged by the heat they do generate, they require high airflow & large power supplies.
a good high performance choice would be a Pentium m, which is part of the centrino designation, these things are very efficient & have some of the highest allowable core temperatures of all processors, they deal with the harsh environment of a vehicle install very well and perform well under the most extreme conditions and are thermally protected, this, combined with speed step throttling & a very efficient design with low power draw makes them a great choice. There are 3 variations of the M chips, there are the regular M’s, then there’s a low voltage or LV, & finally there’s the ultra low voltage ULV.
A 1.2 ultra low voltage may sound anemic, but with their 2mb L2 cache & fast front side bus, they are very capable performers, a 1.2ulv will far outperform a common via board, it will even outperform a 1.8 p4 while using literally half the power, they generate so little heat that there are laptops that don’t even use a fan with this processor, you can install one of these almost anywhere without worrying about airflow or overheating. Also worth mentioning is the Athalon XP-M’s, another good choice as a mobile processor.
If your budget allows, you can opt to go core2 duo, which is inarguably the best mobile chip available at this time, while this would be considered way overkill by some, the core2duo’s are efficient enough to actually be an excellent choice, there is no processor family available right now that is as efficient, if your goal is to look towards the future & ensure more than enough performance no matter what you throw at it, a core2duo may be the way to go.
As a general rule, avoid Pentium 4’s , even the P4M’s are very inefficient, use a lot of power & build up excessive heat, add to this the fact that they don’t deal well with the heat they do generate, makes them a poor choice.
Installing the laptop:
For as many different laptops as there are out there, there are almost as many different ways to install them. This may be determined in part by your willingness to either partially or even completely take the laptop apart. The easiest way to install a laptop is probably by using a laptop with a docking station, a docking station can usually eliminate the need to disassemble the laptop at all, as the power switch is usually available & easier to access right on the dock itself. This can be an ideal setup if you have thoughts of using the laptop outside of the vehicle on a regular basis, the drawback to this approach is it adds the burden of always making sure you have the laptop or the inconvenience of living without it if you want to just take a quick run to the store or something, this can be less of a problem if you chose to retain a head unit.
The power switch:
Short of using a dock, most laptops will require at least partial disassembly to access the power switch, this is necessary to be able to remotely turn the computer on & off, having to actually go to the laptop & turn it on each time is not desirable or acceptable. This is usually the most intimidating part for most people who are not experienced with disassembling expensive delicate electronics, but it’s really not that difficult at all on most laptops, this is another area that some laptops are better than others with.
Some laptops with the power button on the area right above the keyboard can be downright easy, this panel is usually easy to remove without getting to intrusive to the assembly of the laptop case, most laptops that have their power switch on the side of the laptop will be just a bit more difficult, they will usually require separating the lower case completely. Another design that is commonly used is the power switch on the screen bezel, these will require disassembling the bezel of the laptop, which is generally easier than disassembling the lower half.
You will need to extend 2 wires outside of the laptop to be able to control startup & shutdown. Some have been creative in the way to achieve this, one very clean way is to just wire the power switch to the useless regular modem jack. You can then use a telephone wire plugged in to run a remote switch on the dash or just as a way to wire in a startup/shutdown controller. Worse case for the severely electronically challenged, drop it off at any local electronics repair center, you should be able to get a tech to wire the power switch to the modem jack for around $75 give or take.
one alternative to the power switch approach is a wake on ring or wake on lan type setup, but this only works on some boards & reliability can be a bit questionable, but if your dead set against opening the laptop this can be an area to explore.
The lid switch:
Another area of concern with a laptop install that will use a complete intact laptop is the LID SWITCH. This switch is what triggers the laptop to shut down or hibernate or stand by, many times it’s enough to just select the “DO NOTHING” option in windows & sometimes even in the BIOS, but some laptops may still have issues starting up reliably with the lid closed. This lid switch can be disabled if necessary, some may use a tiny pin switch at the joint of the screen hinge, some use magnet switches & some tablets have switches built into the hinge itself for auto rotation.
Custom case mods:
If you’re willing to use the laptop as a dedicated carpc you can choose to disassemble the laptop & remove the screen. You could then remove the keyboard & mouse pad, actually attach a plate & create the ultimate carpc case. Imagine a carpc around the size of a thick magazine, install possibilities are widely expanded when a laptop motherboard is chosen. Very unconventional locations can be used with ease. The plate can be the mounting system & brackets can easily be extended off of this plate even before the plate is attached to the lower half of the laptop. A laptop like this can be installed under a dashboard or sometimes behind the glove compartment, in a center console sometimes, ahead of the shifter, sometimes directly in the dash, if your creative there are other more far out possibilities, like in a headliner or seatback, of course this can also be installed in the trunk too. You should pay attention to airflow & make sure there is enough for the machine you choose.
laptop, screen & all:
There has always been interest in using a laptop screen for a carpc, well the absolute BEST way to use a laptop screen is to run it off of the laptop it came with. One major problem with this approach is most laptop screens are not very bright at all & will suffer in the daylight even more than the typical Lilli’s & Xenarcs & really be pretty useless for daytime bright sun use, but, there are exceptions.
A completely integrated & efficient install can be created by embedding an indoor/outdoor screened tablet in your dash, considering the single tablet will include your whole carpc including a transflective screen, motherboard, memory ram & hard drive & operating system this can actually be a pretty cost effective solution too, or at least on par with the alternatives.
This option may work well for those desiring screens of 10.4” & larger, but now even smaller screens are surfacing, like Fujitsu’s new 8.9” widescreen indoor/outdoor tablet. Virtually everything you need for an awesome carpc can be had from one of these tablets, right down to the touch screen & all, but it also is not for everyone to disassemble & install an expensive delicate & beautiful machine such as this, but the end result could be spectacular.
One major problem area in the “screen run off the laptop board” approach is dealing with the ribbon cable, these can be anywhere from not too difficult to totally impossible depending on the actual cable design, but if your determined enough even an impossible to extend ribbon can be dealt with, sometimes you may have to have a harness made for you even, but there is almost always a solution.
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline
Sponsored Links
Closed Thread
vB code is On
Trackbacks are Off
FS/FT: Dell Inspiron 8100 Laptop...CarPc emailthis1 Classified Archive 5 09-20-2005 08:59 PM
Hurry!!!! Laptop - Ideal For Carpc :) Paul_GPvR Classified Archive 5 11-04-2004 06:02 AM
Building CarPc: home PC or Laptop parts? oz-e Newbie 2 05-17-2004 01:19 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
