The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 07-19-2007, 02:22 PM   #1
My Photos: (0)
Acer LCD question
I just took apart my Acer laptop since I'm going to be using it for a carputer. I'm somewhat of a newb when it comes to this field, but i do have a background in computers and in car audio. My question is this: I'm stuck on the part of extending the LCD cable to reach the mobo. There's about 40 tiny wires and a weird plug. The reason I want to use this monitor albeit it's a little big (15.4"), I want to do this project as a proof of concept and spend as little money as possible. Eventually I will upgrade to a touchscreen, but for now I want to get this work to prove I can do it. Now before everyone tells me to search the forums and google, i've done that already. I want to get all possible opinions and expert advice before I hack up the lcd cable. Basically I'm asking for suggestions on how to extend this cable.
Attached are some pics.
Connector on the mobo:
Connector coming from screen:
kostyanj is offline   Reply With Quote
Sponsored Links
Old 07-19-2007, 11:25 PM   #2
My Photos: (0)
Wire cutters, spare wire, and solder.
Time to break out the old soldering iron!
ctsoccer13 is offline   Reply With Quote
Old 07-19-2007, 11:28 PM   #3
My Photos: (0)
Or, if the wires are long enough, just cut the wires and splice in some longer wire. That'd probably be easier given that the space of the pins for the plug is so small.
Old 07-20-2007, 05:22 AM   #4
My Photos: (0)
I would cut it in half, get a parallel cable or some other thin cable and wire it in between each half to the desired length.
Remember to put the Inverter closest to the screen. It wont power the backlight of the LCD very well if the inverter is left at the laptop.
http://www.mp3car.com/vbulletin/lcd-...cable-faq.html
Ace-FTO is offline   Reply With Quote
Old 07-20-2007, 07:08 AM   #5
BiGGy's Avatar
Vehicle: 02 Mitsubishi Magna VR-X
My Photos: (110)
I think these wires have limits to how far they can travel. Im not sure tho, it may just be inverter ones that cant go far. I am also putting a 15.4" portrait screen in my car from a laptop, check it out.
Mitsubishi Magna VR-X - Whitsundays, Australia
Continued Worklog... Upgrades in progress:
*15.4" WXGA LED backlight touchscreen upgrade
*Custom fiberglass dash bezel
*768 X 1024 Narrow RR Skin
http://bigs.omfg.net.au/
BiGGy is offline   Reply With Quote
Old 07-20-2007, 10:21 AM   #6
My Photos: (0)
Thank you for the replies. I was thinking of splicing and that's prob what I'm going to do, but I just wanted to make sure. The wires are so small, they're higher gauge than the wires inside a parallel cable and there's more of them. There's 40 wires, should I still just splice them?
Old 08-09-2007, 11:33 AM   #7
My Photos: (0)
use 2 parallel cables
bastholio is offline   Reply With Quote
Old 08-09-2007, 11:36 AM   #8
My Photos: (0)
Thanks for the reply, but I've already decided to go with a touchscreen instead.
www.computer-forums.net
Sponsored Links
vB code is On
Trackbacks are Off
In dash LCD pivot question 2006Civic LCD/Display 2 05-29-2007 10:56 PM
LCD Controller Question Spindle LCD/Display 20 04-07-2007 12:00 AM
question about an LCD and controller Shaar LCD/Display 2 03-21-2004 09:19 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
