OK to begin with I don't have a Gremlin. I have a 2007 Honda Ridgeline. I use a Car2PC adapter to connect my Dell 5100 laptop thru the OEM head unit, mainly to play mp3s. (Yes, the 5100 is a brick & yes, it overheats & yes, I have thermal shutdowns on occasion.)
Here's the story: Running the laptop off battery only, everything is cool, except of course that the battery lasts less than an hour due to its age & the draw from the sound & hard drive. Running the laptop using a DC-DC cigarette lighter adapter (admittedly an el cheapo from eBay), again, everything is cool ... almost. The laptop runs fine & the sound is great. But after about 10-15 minutes running with the DC-DC converter, the Tire Pressure Monitoring System (TPMS) indicator comes on.
[For background, the Honda Ridgeline has a "TPMS" indicator that displays if there is a fault in the overall system, as well as separate indicators to show if a particular tire is low. If I unplug the adapter, the TPMS indicator will go back out. I have not used a Scangauge or other tool to read any fault codes that might be in memory. From my research, it appears that the individual tire sensors work on some radio frequency.]
Does this sound like an RF interference issue with the cheap DC-DC converter? Does anyone know what frequency the tire sensors might operate on? (Nobody on my favorite Honda board seems to know...)
I don't know if there's a solution, but the light is annoying. (And yes, the first time it happened I stopped & checked the tire pressure all around
T.I.A.
Joe
