The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 08-29-2007, 10:19 AM   #1
My Photos: (0)
Laptop usb repair
I have a compaq presario r3000 and all 3 of my usb ports are busted. Is there any way I can repair these?
98gsxboosted is offline   Reply With Quote
Sponsored Links
Old 08-29-2007, 10:29 AM   #2
bbalazs's CarPC Specs
Vehicle: 2001 Renault LagunaII 2.0 IDE
My Photos: (15)
Are you sure that the PORTS are unfunctional?
Try to check the voltage first (side pins: 5V, gnd)
Perhaps it is just a fuse problem...
What does the driver tell in hardware section?
Does it consume any milliamperes?
bbalazs is offline   Reply With Quote
Old 08-29-2007, 10:31 AM   #3
My Photos: (0)
no they are physically dmgd. Bent inside the usb wont stay tight, it jiggles and loses connection..
Old 08-29-2007, 11:09 AM   #4
Para Laura
thanatos106's CarPC Specs
thanatos106's Avatar
Vehicle: Xterra SE supercharged
My Photos: (0)
Oh I thought you meant that when you connect a usb device, ot doesn't work...yes you can fix does, just desolder the bad ones and solder good ones (is been done before with anything in the back panel...vga, ps2, serial connectors)
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 08-29-2007, 11:25 AM   #5
Phatsacks's CarPC Specs
Phatsacks's Avatar
Vehicle: 2007 Corolla S
My Photos: (0)
All else fails, snag a usb hub that connects via pcmcia
Phatsacks is offline   Reply With Quote
Old 08-31-2007, 08:01 AM   #6
FUBAR_NZL's CarPC Specs
My Photos: (3)
buy a 4/5 port usb hub and hard wire it
FUBAR_NZL is offline   Reply With Quote
Old 09-08-2007, 12:55 PM   #7
My Photos: (0)
I repair laptops all day, and unless you are really good at soildering, then you'll have to buy a new mb for the laptop to repair those. Sometimes they are seperate, but most times it's all built into the mb.
Mrcat88 is offline   Reply With Quote
Old 09-11-2007, 12:31 AM   #8
WarDriver's Avatar
Vehicle: 4Runner
My Photos: (1)
Second this idea...its cheap, easy and especially since you can upgrade to USB 2.0 if you have an older laptop.
-WarDriver-
Real Men Pay With CA$H
Who needs an optical drive?
My DC to AC Inverter Mod
My Laptop Remote Switch
The Only Way to Search Craig's List
WarDriver is offline   Reply With Quote
Old 10-13-2007, 08:00 AM   #9
jonessc's CarPC Specs
jonessc's Avatar
Vehicle: BMW 320D M-Sport
My Photos: (0)
pcmcia as cheap, just be carefull as some of them (ie the 4 port versions) need a working usb port to draw power, i had one and it wouldnt work unless i had it plugged into a usb)
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
how to get laptop to work up by dash dhantiflag Laptops, Tablets, UPMCs, etc. 5 03-07-2007 07:27 PM
USB Laptop Startup flaVius Power Supplies 8 05-21-2005 02:32 PM
External USB Aluminum case for laptop hard drives jarubio General Hardware Discussion 9 04-19-2005 07:24 AM
laptop: which is better, USB audigy or pcmcia audigy? pesos Car Audio 25 01-14-2005 04:13 AM
2 external laptop hd enclosures FS USB 2.0 outragis Classified Archive 23 03-11-2004 05:05 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
