09-13-2007, 09:55 PM
#1
Vehicle: 4Runner
Simple and Clean Remote Laptop Power Switch
Laptop remote power on/off switch mod
This mod has helped me and I wanted to share it with the community. On 4-27-06 I posted the first hints of this project here. I've been meaning to convert it to a a how-to...so here it is.
Pictures, comments and improvements are welcome.
*The mod below also works great with my remote inverter switch mod*
Rational:
-I want to be able to turn off and turn on my laptop carputer from the driver’s seat of my car.
-I don’t want to hack up my laptop so it is un-useable or looks funny.
-I want the solution to be simple, clean and easy for a person of average skill to replicate.
-It has to be cheap
Parts I already had:
-Laptop - acquired for free because someone thought it was broken
-Old network cable for wiring
-Momentary on switch from some old project.=
Additional Parts Required:
Stereo audio jack female (Radio Shack $3 this or this)
Stereo audio jack male (Radio Shack $4 this or this)
Total $7
Tools Required:
Drill w/Bit
Soldering Iron
Solder
Electrical Tape
Muti-Meter
I would like to make it look as stock as stock and clean as possible. This is a simple idea, replicate remotely what the physical pushing of the power button will do to your laptop.
So to start lets gather the parts. A quick trip to radio shack and I’m ready to roll. I used the 1/8" because the nut shank on the 3/32" was too small.
Choose what is right for you. First you'll need to get to your power switch. I can' t help you there, but with a little patience and some help from Google I'm sure you can figure it out. If you can't get to your power switch that is probably a good indicator you shouldn't be doing this mod.
Laptops (typically) use a momentary on switch to initiate the boot, resume from hibernate or shutdown depending on how your OS is configured. Once the case is open locate the power switch and break out your multi-meter. Leave out the battery and AC connector and start trying to figure out which two pins "close" when you press the power button. I just used the beep setting on my multi-meter.
Once the pins are located, locate a good spot to mount the female stereo jack. I used a stereo jack because the left and right channels are insulated from each other and the common ground.
Strip the ends of some very small gauge wire, I used an old network cord I had laying around. It worked great. Fire up the soldering gun and connect one wire to each of the pins you located earlier. Make sure you use an overly long piece of wire, always easier to cut it shorter than to make it longer.
Drill the hole for the female jack in the spot you located earlier. I wanted to place my jack in the back of my laptop, but I could not get the space necessary, so I opted for the side. Test fit the jack in the hole. Create a test route for your wire, making sure it will clear all of your components once your laptop is back together. Cut the wire to length and solder to the female jack.
Solder some more old network cable wire to a male plug on the left and right channels. Strip the other end of the wire but make sure they don't touch. Reassemble your laptop enough to see if it will power on. Connect the male jack, put in your battery or AC plug and touch the wires together. If it fired up hold them together to see if it will hard stop it self.
If all worked as it should reassemble your laptop. Solder wire to your m your momentary on switch and mount it all in your vehicle. And now you have a custom remote laptop power on/off switch.
I ended up using a nicer switch, I just used the one shown for testing.
**This is a tutorial of what worked for me. I will not be responsible for any hardware failures because of this mod.**
-If this doesn't help you try this thread-
-If you are looking for a desktop power supply mod, try this-
09-15-2007, 10:56 PM
#2
Laptop, Tablets, UMPC Moderator
Vehicle: 2002 pontiac montana
hey man, cool mod, I usually try to use an already there jack on the laptop, most times it'll be the modem jack... I mean who plugs a phoneline into there laptop anymore anyway
could also be done thru a headphone jack or mic jack, if your willing to loose the original functionality of that jack. of course adding your own jack is also a good option if needed, just wanted to mention the other options available for this
09-16-2007, 02:03 AM
#3
Vehicle: 2005 Honda Element
What's a modem??
Failure is not an option....
It's installed by default on every version of Windows.
09-18-2007, 01:40 PM
#4
Nice mod...
09-26-2007, 02:02 PM
#5
Vehicle: Vauxhall Vectra B (Year 2000)
I did that to my tablet last year - Great minds hey!! used the same jack but installed a nice switch on the dash
Daniel
10-16-2007, 04:12 PM
#6
Vehicle: 1996/Toyota/Corolla
Nice Mod
I did the same mod on my laptop too, however, I ended up just having wires stick out of it that I connected with speaker clips.
I really like your speaker-like plug idea though, very clean!!
1996 Toyota Corolla - HP ZV5000
10-16-2007, 04:18 PM
#7
Vehicle: 4Runner
Thanks...the idea was to have it be fully mobile and hopefully look somewhat normal.
10-19-2007, 07:33 PM
#8
Hi Wardriver,
A question regarding your remote switch. Does its still work? Has it done any damage to the laptop once in the car. My concern regards electrical noise pickup and the laptop circuit sensitivity.
On my Dell, a 3v3 signal is always present for the power switch to work. I'm just wondering if I need to keep it well sheilded in the car environment.
I've also gone for a remote switch on, but gone for a different approach. I will have one button on the dashboard (which neatly fits the spare button slot on P11 primera dashboards) and route that to this control board I.ve built. On ignition startup, no button needs to be pressed, the controller checks the usb power, if the laptops off, it start the laptop, then turns on the screen, and to avoid audio thump as the soundcard comes on, it will power the amp last. The dashboard button can then be used with a quick press toggling the screen power, 2sec press simulated laptop power switch, >4sec shuts of the entire system immediatly (in case of lockup). All done with some relays and a freebie pic.
So far it all works on the bench, but in an electrically noise car environment, I'll just have to see.....
10-30-2007, 11:28 AM
#9
Vehicle: 03 Ford F-150 Supercrew
I just finished this mod! thanks for the excellent walk through. Works like a charm.....so far, and only four screws leftover!
10-30-2007, 06:30 PM
#10
Vehicle: 4Runner
Ahhh...they always put extras in there....
10-30-2007, 07:25 PM
#11
Hi Wardriver,
Thanks for the pics of your mod. Believe it or not I pulled my laptop part yesterday to start a mod similar to this but haven't done any soldering yet as I didn't know which points on the switch to solder to. The interesting thing of me is that your laptop is identical to mine and I no longer need to find a multimeter to work out which two points to solder to.
BTW, do you know what the other 2 points on the other side of the power switch are there for? I was going to wire all 4 points to my useless modem socket and work the rest out later.
10-30-2007, 09:11 PM
#12
Vehicle: 4Runner
You know...off hand I don't. Good luck with the mod.
WD
01-06-2008, 07:45 PM
#13
I'm new to this forum and to fabricating a carpc. I'm planning to use a Dell Latitude P3 laptop, and this schematic definitely is going to be of help. My question is, is a momentary switch the only possible means of controlling the laptop's power? I'd like to install a single pole, single throw switch into my dash to control the laptop's power. Is this possible, and, if so, would you happen to know what additional parts, if any, are needed?
01-06-2008, 10:08 PM
#14
Vehicle: 4Runner
A SPST switch would be the same as holding your finger on the button of your laptop while you try and work on it. All it would do is complete the circuit and hard stop the PC. You could flip the SPST switch on the off real fast to get it to kick on, but that would defeat the purpose of its design. If you are going for a certain look in your car like that row of lighted fancy switches you might want to think about putting one on your DC to AC inverter unless you are going to Frankenstein some sort of 12v automotive dell adapter...in which case I would put it on the hardwired ac adapter.
I'm not sure what other parts you are thinking of....then again, I've been VPN'ed into work for the past several hours and my brain is fried...
Hope this helps. Please feel free to ask any other questions.
06-29-2008, 07:55 PM
#15
Issue I'm having
I recently tried installing the the solution in this thread. The issue I'm having is that when I hit the Momentary switch the laptop power on and power right off like the actual power button is still being held down. If I hold down the momentary button the laptop power rights up until I let go the button. My technical guess would be that I'm using the wrong leads because I guessed it because I left my multimeter at work. Could it be possible that I need another type of switch. Any help here would be greatly appreciated.
| Thread Tools |
| Display Modes |
Linear Mode
