The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 10-16-2007, 04:38 PM   #1
musters's CarPC Specs
musters's Avatar
Vehicle: 1996/Toyota/Corolla
My Photos: (0)
Laptop Power On - No Ignition Power
Initial Problem:
My car's fuse box is completely full with other peripherals. I took my car to two different mechanics who said the same thing, they can't run another power line that runs off the ignition. The second guy I went to said he could wire up the circuit if I really wanted, but that the Toyota wires would probably melt because they weren't meant to take that much load.
Current Setup:
So after much disgust I went ahead and just wired directly to my battery and put in an in-line fuse with a switch. I have a main power button in my dash that gives power to my laptop, and also triggers the power on of the laptop.
Aftermath:
A year later, I'm getting tired of remembering to turn off my computer when I turn off my car. A few times I have forgot and subsequently my car battery was drained.
Would anyone be able to provide any useful suggestions that I might be able to implement into my current setup that would allow me power-on with the ignition? I have search the forums on relays and possible solutions there, but they either require some piece of hardware which I can't guarantee will work, or some type of schematic that is way above my soldering skill level.
I need a simple switch that does the following:
- If I have power (from a in-dash light or something), then open the switch, if I don't have power, close the switch.
Thanks in Advance.
1996 Toyota Corolla - HP ZV5000
musters is offline   Reply With Quote
Sponsored Links
Old 10-16-2007, 10:46 PM   #2
DodgeCummins's CarPC Specs
DodgeCummins's Avatar
Vehicle: 96 Dodge Ram 2500 Cummins Diesel (turned up)
My Photos: (20)
It depends on how much power you are talking about.
One possibility would be to get an automotive relay, connect it to you ignition switch to control the power from the battery to your laptop.
http://www.the12volt.com/relays/relays.asp
So #85 to ignition switch power, #86 to ground (metal chassis ground)
#30 to your battery power, and #87 to the laptop power supply.
You can get relays mail order etc...but I was able to get one...with a nice wiring harness from my local car audio/ alarm dealer/installer.
current projects
DodgeCummins is offline   Reply With Quote
Old 10-17-2007, 09:18 PM   #3
sliturnek's Avatar
Vehicle: 95 Nissan Hardbody
My Photos: (1)
i ran a relay for mine but how do i set it to auto start when there is a active power connected?
sliturnek is offline   Reply With Quote
Old 10-18-2007, 10:15 PM   #4
My Photos: (20)
Perhaps in BIOS?
current projects
Old 10-18-2007, 11:06 PM   #5
My Photos: (0)
set the power settings in windows to turn off after running on battery for a time. i have my computer set to hibernate (no power draw) after 3 minutes of running on battery. to get there: control panel-display-screen saver tab-power settings.
auspiv is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Simple and Clean Remote Laptop Power Switch WarDriver Laptops, Tablets, UPMCs, etc. 25 07-23-2008 09:57 PM
Carnetix P1900/P2140 and IBM T40 Laptop Power Question l00kster Laptops, Tablets, UPMCs, etc. 14 01-24-2008 01:55 PM
linking into laptop power button corsamel General Hardware Discussion 18 09-06-2007 09:47 PM
Power button won't work when laptop lid is closed scotty562 Laptops, Tablets, UPMCs, etc. 4 09-22-2006 10:25 PM
Wanna power this laptop since I fried my system today. MikeHunt79 Power Supplies 6 07-07-2003 11:24 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
