Laptop Power On - No Ignition Power
Initial Problem:
My car's fuse box is completely full with other peripherals. I took my car to two different mechanics who said the same thing, they can't run another power line that runs off the ignition. The second guy I went to said he could wire up the circuit if I really wanted, but that the Toyota wires would probably melt because they weren't meant to take that much load.
Current Setup:
So after much disgust I went ahead and just wired directly to my battery and put in an in-line fuse with a switch. I have a main power button in my dash that gives power to my laptop, and also triggers the power on of the laptop.
Aftermath:
A year later, I'm getting tired of remembering to turn off my computer when I turn off my car. A few times I have forgot and subsequently my car battery was drained.
Would anyone be able to provide any useful suggestions that I might be able to implement into my current setup that would allow me power-on with the ignition? I have search the forums on relays and possible solutions there, but they either require some piece of hardware which I can't guarantee will work, or some type of schematic that is way above my soldering skill level.
I need a simple switch that does the following:
- If I have power (from a in-dash light or something), then open the switch, if I don't have power, close the switch.
Thanks in Advance.
1996 Toyota Corolla - HP ZV5000
