The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 11-01-2007, 11:26 AM   #1
Vehicle: 04 Honda Accord Coupe (6 MT)
My Photos: (0)
Questions about powering Laptop
( Before someone makes a wise comment about reading FAQs, let me tell you that I've already done that and I'm still a little confused about the setup that I'm trying to do. )
After getting dissappointed with Jetway and M2-ATX problems I've decided to go with a laptop for my new setup and following are the things that I want to have in my setup
* Toshiba Qosmio laptop
* 7" LCD
* Powered USB hub
Now the questions that have are
1) What would be the best source to power the three devices ? I've looked into inverters and auto/air adaptors and the former one seems to be a better choise for laptop but how do I power USB hub and LCD ?
2) Between an inverter and auto/air adaptor, which one is better ? Are auto/air adapters regulated ?
3) If I go, inverter route what would be minimum power requirement that I would need ? (was looking at this one)
3) Do all laptops power up with the lid closed ?
04 Accord Coupe Carputer
ajamils is offline   Reply With Quote
Sponsored Links
Old 11-01-2007, 02:11 PM   #2
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (71)
auto air adaptor is dc-dc, much better than an inverter
the lcd usually comes wit it's own dc regulator, & you could use a pol supply for usb like this for a simple easy setup...
also, depending on the voltage the laptop runs on, you may be able to adapt a regular dc-dc supply too, & have that also control startup/ shutdown...
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is online now   Reply With Quote
Old 11-03-2007, 12:47 AM   #3
Vehicle: 2006 Tacoma
My Photos: (0)
* 7" LCD
* Powered USB hub
Avoid inverters if you can.
here is how i did my laptop:
I used three separate regulators 5V (for USB) 12 V (for touch screen), and laptop Auto/air.
http://www.mp3car.com/vbulletin/show...-carputer.html
My auto/air powersupply warned against being pluged in while cranking engine but I have tank circuit so it is not an issue.
I'm using a docking station for the laptop,only issue is I have not hacked it to start laptop when I start truck, need to press button on docking station.
rac3pm is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Powering Compaq Laptop TheTreeHouse Power Supplies 1 08-24-2006 02:33 AM
Powering Slim External DVD - Laptop CarPC drPheta General Hardware Discussion 4 08-23-2006 12:56 PM
Powering Laptop Cardi Newbie 4 04-27-2005 08:46 AM
Powering questions... harrisonpowers Newbie 2 11-06-2004 01:18 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
