Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Notices
Old 11-25-2007, 09:22 AM   #1
FTWRUBI's Avatar
Noobie with a laptop.
I have a gateway m275 that I would like to use for a jeeputer. What modifications do I need to do to make this work. Or would it be better to do a purpose built jeeputer?
FTWRUBI is offline   Reply With Quote
Old 11-25-2007, 03:28 PM   #2
Welcome LSJC member.. I thinking on getting a tablet PC to add to my jeep. Nothing too fancy just for entertainment and NAV.
dajeepman is offline   Reply With Quote
Old 11-25-2007, 04:11 PM   #3
Self proclaimed spoon feeder
TruckinMP3's Avatar
Think about where to mount it, how to power it and how to control it.
You are the only person that can say what is right for you.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 11-25-2007, 07:10 PM   #4
FusionFanatic's Avatar
you don't need to do any modifications to make it work... it already works (you wouldn't be using it if it didn't )
but seriously, you should start by reading How can I use a laptop as a carputer?, and Using a laptop as a carPC. the general FAQs should answer most other questions you might have.
there is nothing special about a jeep vs. any other car with regards to a carputer, the equipment install and setup is the same for any car. the only difference will be the monitor installation in your dash. check out the worklogs and completed projects forums to see other jeep installs if you need ideas.
good luck
FusionFanatic is offline   Reply With Quote
Old 11-25-2007, 08:38 PM   #5
FTWRUBI's Avatar
Thanks folks, dajeepman. so how did you know?
Old 11-25-2007, 10:58 PM   #6
GizmoQ's Avatar
Wow, a tablet in a Jeep.... biggest problem I can think of is off-roading. If you need GPS while off-road then you're gonna have to create a rigid mount, probably 3/32 stainless on three sides and latch the fourth. If not, GET ONE WITH A DOCK so you can easily remove it when the terrain gets rough or do like I did for my Mustang - build a rigid mount for the dock that somehow wedges the tablet in place and hope for the best. Tablets with docks are nice for multiple car installs and allow you to setup a test station at home.
HARDWARE: Fujitsu Stylistic 4121w/ WiFi & mini dock, Sierra Wireless Aircard 550, EXP PCMCIA Portable DVD-RW, Silabs FM, WinTV USB w/-26dB diversity antenna, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 USB joystick, BluSoleil USB Bluetooth
GizmoQ is offline   Reply With Quote
Old 11-26-2007, 08:21 PM   #7
FTWRUBI's Avatar
Well, I am going another route. I am looking at getting a purpose built unit due to the shock and vibration in the jeep.
How can I use a laptop as a carpc? turbocad6 Laptops, Tablets, UPMCs, etc. 0 07-11-2007 01:55 AM
HOW TO:use opus with a laptop...... turbocad6 Power Supplies 23 09-01-2006 02:18 AM
