The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 12-09-2007, 02:31 PM   #1
My Photos: (0)
Powering laptop
How do you power a laptop to use it as a CarPC? Do you run wires from the battery back to the power adaptor of the laptop and power it that way? Or is there some other way?
g8m3rtag is offline   Reply With Quote
Sponsored Links
Old 12-09-2007, 03:18 PM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
There are a few options, depending on the power requirements of your laptop.
A car power adapter works well.
There are regulators like the Carnetix P1900 that work well with many models of laptop (but not all!)
An inverter will work, but isn't the ideal setup.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 12-09-2007, 04:50 PM   #3
My Photos: (0)
By car power adapter you just mean a charger that plugs into the cigarette lighter?
Old 12-09-2007, 07:35 PM   #4
My Photos: (26)
Yes.
My Worklog
Old 12-10-2007, 01:36 PM   #5
neilhart's Avatar
Vehicle: 2003 Corvette Z06
My Photos: (0)
Lind power adapters
I like the Lind DC to DC power adapters designed for autos. I use an automotive sytle relay latched by accessory power to cut fused 12Vs to the adapter. This then turns off the power to the DC to DC power adapter when you turn off the accessory power.
The laptop will still be powered by its' internal battery (but won't drain the car battery).
check out http://www.lindelectronics.com
Neil
neilhart
aka Neil
My Domain is www.sfba-corvette.com check it out!
neilhart is offline   Reply With Quote
Old 12-31-2007, 05:49 AM   #6
My Photos: (0)
okay, say you use one of them, what turns the laptop off after you leave the car? wouldnt it drain your battery keeping the laptop charged?
tacobandit is offline   Reply With Quote
Old 12-31-2007, 06:25 AM   #7
My Photos: (26)
You can get a startup/shutdown controller for this purpose. You don't need one, but it makes life convenient.
My Worklog
Old 12-31-2007, 01:43 PM   #8
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (71)
the best way to use a car adaptor with a laptop & no shut down controller is to simply wire the car adaptor to only have power with ign, then set the laptop to react with a shutdown or standby/ hybernate etc when on battery power for what ever length of time you choose. I've been meaning to write-up a comprehensive power guide for laptop installs for a while now, just haven't had the time
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is online now   Reply With Quote
Old 12-31-2007, 01:51 PM   #9
RipplingHurst's CarPC Specs
Vehicle: 06 Infiniti M35 & 07 Infiniti FX35
My Photos: (28)
That would be awsome! Can't wait!
RipplingHurst is offline   Reply With Quote
Old 01-02-2008, 01:42 PM   #10
My Photos: (0)
So what would be better: powering laptop through auto-adapter or using Carnetix PXXXX ?
SiburNY is offline   Reply With Quote
Sponsored Links
Old 01-03-2008, 09:05 AM   #11
turbocad6's Avatar
My Photos: (71)
depends, if your laptop can run off the voltage required for it from the ps, then it could certainly be used for it's sole power no problem. if you did that you might also need to use a seperate pol power supply for either your 12v accesories or 5v acessories, but that's not so bad really.
I like using a regular atx power supply & have that trip a relay to power a car adaptor for the laptop so then the atx power supply can be used to power all acessories you might add, the atx & the car adaptor should be more than enough to power anything you can add to your system. it may be slightly wasteful in that the 3.3v won't be very useful for much, but at least you know that you have enough power for everything else you might add.
I guess I would look at the whole system & decide what else I would be powering... if the ps you have in mind will power everything you'll add including the laptop then that's great, but if your going to have to add another ps for accessories anyway, then I would consider using an atx supply & a car adaptor.
if you used an atx supply tripping a relay for a car adaptor then it could still do the startup/shutdown for you... I've done them both ways & unless it's a minimalist system your building, I like the atx/ car adaptor solution better as it has more room for expansion & will allow you to grow the system without headaches, it sucks to try to add somethng to your install & realize that you don't have enough power for it. no matter what, you'll probably need 3 different voltages, 5v, 12v & whatever voltage the laptop runs at, of course the ps & a seperate pol can do the job, but if your going to add a lot of other stuff you could get to the point of needing more than one seperate pol's.. that won't happen normaly with an atx/car adaptor solution.
Old 01-05-2008, 01:01 AM   #12
My Photos: (0)
What if I were to wire a cigarette lighter plug in behind the dash to the ignition/accessory wire going to the headunit to power the laptop and then another one for the screen?
That way when the car was off neither device would be drawing power and killing my battery?
I only plan to hook up the laptop and screen in the dash area so adding things should not be a problem.
I got the Xenarc700IDT for Christmas if anyone has some personal experience with hooking one of those up.
Old 01-05-2008, 01:25 PM   #13
My Photos: (0)
I have the same setup right now, and I do have problems with it: if laptop is charging and my headlights are on, monitor screen goes blank occasionally due to power shortage/spikes.
Old 01-06-2008, 08:47 PM   #14
soundoff's Avatar
Vehicle: Lifted 1991 Subaru Liberty 4WD
My Photos: (0)
use shutcontrol
its in the software forum
soundoff is offline   Reply With Quote
Old 01-18-2008, 12:02 PM   #15
Vehicle: 2005 Ford Focus
My Photos: (0)
You could also configure the laptop to shut down after X minutes on battery power
eldouche is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
What could cause this problem? (laptop related) Rocky388 Laptops, Tablets, UPMCs, etc. 5 09-17-2006 03:17 PM
Powering Laptop fabiolover2002 Power Supplies 4 06-09-2005 07:20 AM
Powering laptop and 2 LCD's berniejr Power Supplies 6 03-01-2004 05:16 PM
Powering up a laptop remotely dmbrown73 General Hardware Discussion 2 03-07-2002 12:25 PM
Powering up a laptop remotely dmbrown73 Power Supplies 1 03-07-2002 07:40 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
