The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Laptops, Tablets, UPMCs, etc.
Thread Tools Display Modes
Old 01-02-2008, 08:49 PM   #1
Vehicle: 1999/Toy/Camry
My Photos: (0)
Question advice for laptop carputer, IBM?
I've been doing laptops as my carputer for some years, started with a little
Sony Vaio R505 and that was ok except for lack of RAM (384Meg max)
My next laptop was a compaq X1000 which had the power/RAM but it's plugin video card is a bit delicate and the docking system is horrible (way too thin of connector surface)
I've gotten tired of buying video cards for these silly Compaqs and am pondering a new laptop for the car.
I first thought of a newer Sony as the dock design seems good for them but then I remembered IBM also did some pretty good design and discovered the docks are ALOT cheaper for the old T series.
So, after a little research into max RAM, it looks like the T series from T23 up into the T40s seems a good match for a carputer.
Anyone have any good/bad experiences with the T23, T30, T40, T41, T42, T43.
Looks like the same number sequence in the A, X, and R might also work.
Thanks in advance.
skywise is offline   Reply With Quote
Sponsored Links
Old 01-02-2008, 10:15 PM   #2
GizmoQ's CarPC Specs
GizmoQ's Avatar
Vehicle: Several
My Photos: (78)
I've been running a T-30 for the last 4 years as my development machine. It finally gave out last month (fan error, $85 replacement). Seeing as it was in a dusty basement, running 24/7 for 4 years, dropped at least once a year without damage, loaded to the gills with everything RoadRunner since Guino started working on it, it ran quiet, fast and solid the whole time. Video is good, audio is adequate - had it hooked up to a LCD and a TV, but never bothered to pipe audio to a stereo. . Don't know how it'll handle cold, but it can take extreme heat well as long as you don't cover any of the intake/vent holes.
The only thing bad I can say about it was the keyboard must be kept clean often - my keys jammed almost quarterly after the second or third year (I'm a messy eater, pretzel crumbs are the worst!)
Good Luck
HARDWARE: Fujitsu Stylistic 4121w/ WiFi & mini dock, Sierra Wireless Aircard 550, EXP PCMCIA Portable DVD-RW, Silabs FM, WinTV USB w/-26dB diversity antenna, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 USB joystick, BluSoleil USB Bluetooth
GizmoQ is offline   Reply With Quote
Old 01-03-2008, 11:29 AM   #3
My Photos: (0)
I've been researching more and I think an IBM will be perfect.
The docks are dirt cheap, the 2878 dock can be had for $20 or so on Ebay and has
4X USB, Audio I/O, Keyboard, Mouse, Floppy Connector, DVI, VGA, Parallel, Serial, Modem, Network
Perfect for a carputer, esp audio in from XM or sirius.
The dock fits anything from the 20 series up to the 40s.
Now I just have to figure out which ibm laptops can do USB 2.0, anyone know?
Old 01-04-2008, 12:42 PM   #4
Vehicle: 2006 NISSAN 350z
My Photos: (0)
Thanks in advance.
hey i used for my frist computer the X23 IBM it was was great. i was running media engine had GPS navi a 80 usb drive and blue tooth also ran a mic for hands free phone. i was running my music and all my movies on it it was a great system never failed me. the only reason i did not go with the T was that the screen was to big for the glove box in the 350z would not fit the T & X are great laptops for the car pc setup
IBM X23-P3 866MHZ 512 MEGS, 100GIGS 7INCH TOUCH SCREEN LILLIPUT USB 802.11G LINKSYS, USB BLUETOOTH ADAPTER
merk350z is offline   Reply With Quote
Old 01-04-2008, 11:14 PM   #5
My Photos: (0)
For those pondering getting a thinkpad for a carputer, here's a great resource, tells what every model is, what models fit a particular dock, even which models have USB 2 Vs USB 1.1
http://thinkwiki.org/wiki/ThinkWiki
Old 01-05-2008, 06:19 PM   #6
jontz's CarPC Specs
jontz's Avatar
Vehicle: 2001 Ford F-150 Ext. Cab
My Photos: (0)
Skywise, I have an IBM T30 I am about to put up on eBay. It is a P4 2.0, 1GB of RAM, 60GB hard drive, and I am including a 120V AC adapter, 12V DC adapter (for auto use), port replicator (dock), and a 4 port USB 2.0 card. The laptop had a bad RAM socket, but as we speak it is being repaired by IBM. Their fix is to replace the entire mobo, so the machine should be like new when I get it back in about a week. I also got IBM to extend the factory warranty because of the RAM socket issue, so it is under warranty until June of 2009. If you are interested, I will give you or anyone else here first dibs before I put it on eBay.
I have several of the same model T30's up and running at work, and they are very reliable machines. I work for an electrical contractor, so these laptops see a lot of abuse on job sites, and they never miss a beat. It seems like they would be a good fit for a carputer.
jontz is offline   Reply With Quote
Old 01-07-2008, 12:22 AM   #7
My Photos: (0)
Just missed it, I grabbed a T40 off Ebay for $250 and a minidock 2878 for $13
Should do the job just fine, I'll let everyone know how works out once I get it and install everything.
Old 01-07-2008, 11:35 AM   #8
jontz's CarPC Specs
jontz's Avatar
My Photos: (0)
Good buy on the T40. You will love it, I am sure!
Old 01-13-2008, 10:56 PM   #9
My Photos: (5)
i am currently working on getting my r50 working in the car. the biggest downside was that the power button on the laptop cannot be jumped, so you have to get the dock. my laptop is mounted vertically on the back of my backseat and the attachment between the dock and the laptop leaves much to be desired. its not really very sturdy and seems to wobble. i dont have the exact same dock as you but the latching mechanism looks to be the same, but basically when the laptop is docked it stays at an angle and there is a gap between the laptop and the dock. not the mention that i had to basically rip my entire dock apart to get to the power button, so with it went the latches. im going to have to devise a custom system to get the whole thing to stay together basically.
other than that, everything is working great.
hari-bhari is offline   Reply With Quote
Old 01-26-2008, 03:13 AM   #10
Vehicle: 2007 Honda Accord LX
My Photos: (0)
Anyone have problems using the integrated video chip on IBM T series or IBM laptops for that matter to get the 800x480 resolution on 7" LCD screens? I've yet to purchase my LCD monitor and just want to make sure I wont have problems gets the "standard" resolution..
-Learning to install a carputer using an IBM T23 Pentium III 1.0Ghz M chip with a whopping 256MB ram
-Lilliput or Xenarc 7" LCD touchscreen
[Planning+++20%------------]
rlpolo78 is offline   Reply With Quote
Sponsored Links
Old 01-26-2008, 05:08 AM   #11
john1701's Avatar
Vehicle: 2001 Ford Crown Victoria
My Photos: (1)
Quote: Originally Posted by hari-bhari View Post
\ i dont have the exact same dock as you but the latching mechanism looks to be the same, but basically when the laptop is docked it stays at an angle and there is a gap between the laptop and the dock. not the mention that i had to basically rip my entire dock apart to get to the power button, so with it went the latches. im going to have to devise a custom system to get the whole thing to stay together basically.
yes. even with my current setup, I too had to destroy my docking station just to get to the power button to solder two wires. What I did was daisy chain zip ties together to make one big zip tie then bound the dock to the laptop.
CAR:2001 Ford Crown Victoria
PC: Dell 600 NoteBook with Vista
CPU:specs
Memory:1G
Drives:usb 250gig
WI-FI:Cingular
misc:inverter 300w
GPS:IG 4
Screen:Xenarc 700TSV
The Florida Meets Thread
Simple Fix to Road Runner and Vista
john1701 is online now   Reply With Quote
Old 01-26-2008, 12:35 PM   #12
My Photos: (5)
actually i have an r50 with a radeon 7500 video card and i cant get it to display 800*480 even with powerstrip. im fine running at 800*600, i dont see what the big difference is for large font touchscreen applications
Old 02-11-2008, 06:02 AM   #13
Thefdog's CarPC Specs
Vehicle: 2002 Civic LX
My Photos: (0)
I mounted the docking station for my IBM R51 onto a board and placed the whole contraption into a padded plastic gun case. This holds the laptop securely in place and protects the whole shebang from damage in my trunk.
I have never had a problem in the heat, as I trimmed the soft foam from the sides to allow airflow. And the IBMs work fine in the cold. Been around 0 F here and no problems. The IBM also come with software to park the drive when it gets shaken too hard. Rarely if ever happens while I am driving, unless I hit a BIG bump.
Thefdog is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
99 Acura TL carputer project pics Darkshear Show off your project 15 08-23-2007 12:14 AM
Carputer TIME!! please HELP!! CoupeE46 Newbie 4 11-26-2006 05:52 PM
carputer install: I dare you... Cat Monkey General MP3Car Discussion 42 01-27-2005 05:34 PM
carputer newb, requesting advice therussman2002 Power Supplies 0 03-30-2004 08:33 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
